Question about Acer 4220-2346 Notebook
No memory hey i have got a prob i was forced to install windows vista on my acer extensa 4220 with 512mb ram it was ok but a little slow now i got a nother 512mb making a gig but the graphics was 64mb in idle before but now its 130 to 256 in idle even with airo theme turned off there is about 200 to 300 mb left which i cannot run even basic games like house of the dead without it freezing the graphics is a intel x3100 thanks
  • luke m
    luke m Jan 30, 2010
    i cannot install xp because the ac adapter is a universal and it only charges when its turned off so when its on all xp does is beep but xp i didnt have this problem with xp accept the beeping drives you mad
  • Acer Master
  • 2,517 Answers
OS Vista minimum want 512 mb ram for run. & yiur only 512 mb ram which is used for your all program. So incres your ram Atleast
1 GB. 2 GB is best.
Posted on Jan 30, 2010
Testimonial: "thanks i can do but the only problem is iv already spent quite a bit rebuilding it "
Acer Extensa 5620 running Vista Starter can't install or uninstall anything!
have advanced uninstaller installed and clean out everything with this excellent free tool.
Apr 11, 2014 | Acer Extensa 5620-6119 Notebook
How to install memory stixs
In an Acer Extenza 5420 series of Notebook PC?
Well you came to the right place
Here have a seat, and let me show you;
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Here is a Bottom view of your laptop,
http://www.ebay.com/itm/Acer-Extensa-5420-Case-Bottom-15-4-Black-Cover-Speakers-Original-Genuine-Laptop-/170983023419?pt=US_Computer_Cases&hash=item27cf61e33b
Bottom left corner shows the Battery has been removed.
Remove the large panel above it,
http://www.ebay.com/itm/Acer-Extensa-5420-5520-Hard-Drive-RAM-Memory-Bottom-Cover-Door-60-4T305-002-/190741766831?pt=LH_DefaultDomain_0&hash=item2c691862af
Looks to be 6 Philips head screws to remove.
The panel lifts up on the LEFT side. There are TABS extruded from this large panel, which go into the Base Enclosure, (Bottom Cover), on the Right side.
From the Specifications on Acer's Support website,
http://support.acer.com/acerpanam/notebook/0000/Acer/Extensa5420/Extensa5420sp2.shtml
,it states;
System Memory: -> Up to 2GB of DDR2 667MHz memory; upgradeable to 4GB using two SO-DIMM ram memory modules.
(Dual-channel support)
From what I can see, looking at the motherboard by itself; there are TWO ram memory slots,
http://www.ebay.com/itm/Acer-Extensa-5120-5420-7120-7420-TravelMate-5220-AMD-Motherboard-MB-TKP01-002-/350455821339?pt=Motherboards&hash=item5198cb741b
Towards the Top you see the White processor socket. Upper corners are cut off, and there is a single screw in the top/middle.
Right above it are two white Ram Memory slots.
EACH ram memory slot will support (Use) 2GB of DDR2 at 667MHz.
2GB = Amount
DDR2 stands for DDR2 Sdram, and is it SO-DIMM to fit in a laptop.
667MHz stands for 667MegaHertz.
The frequency rate ('Speed') that the Ram Memory operates at.
The TOTAL amount of ram memory for the laptop is 4GB.
That means you can use two modules, ('Sticks') of DDR2 Sdram at 667MHz.
Or also stated as PC2-5300.
Just make SURE it is SO-DIMM, or you will be getting the larger DIMM ram memory used in a desktop computer.
An example of SO-DIMM,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Side Notch on Each side.
The half-moon cutout.
Note the Locating Notch on the Bottom.
Also;
Everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the Bottom; is the BODY.
The Body is coated with a see-through protective plastic.
Handle the Ram Memory module by the Body.
Refrain from touching the gold plated contact pins.
[WORK on a table. {Or workbench} DO NOT work on a bed, couch, or directly on a carpet floor! High areas of Static electricity.
Static WILL fry out, (Short Circuit) computer hardware components]
If you have two Ram Memory modules, one will be stacked on top of the other one. You remove the top one first, then access the bottom one.
To remove a ram memory module, simply ease the spring clips on either side -> OUT.
Out away from the Ram Memory module.
This action takes the 'Bumps' on the Spring Clips, out of the Side Notches on the Ram Memory module.
DO NOT get carried away. Just ease one spring clip out, then ease the other one out. You can bend the spring clips if you are too rough.
When both spring clip 'bumps' are out of the way, the Ram Memory module will spring up slightly.
Remove AT THAT ANGLE.
Slide the Ram Memory module out, at the same slight angle, (30 degrees?), that it just popped up to.
IF you lift the Ram Memory module straight up, you WILL damage the gold plated contact pins on the bottom of the Ram Memory module; and the contact pins in the Ram Memory slot.
To install a Ram Memory module, look at the location of the Locating Notch on the Bottom.
This aligns with a Locating Lug, in the bottom of the ram memory slot.
ONLY goes in one way.
Locating Notch aligned with Locating Lug, slide the Ram Memory module in, in the SAME slight angle it came out at.
Make sure the gold plated contact pins of the Ram Memory module, are well seated in the ram memory slot.
(Ram Memory module is pushed in tightly, in the Ram Memory slot)
Then press down on the tilted up side, until the spring clips lock in place.
Here is a video demonstrating the above, but NOT your laptop,
http://www.youtube.com/watch?v=MbPaR1Ci-Ug
IF, you are ONLY installing ONE Ram Memory module, it MUST go in Slot 1. Also known as DIMM 1.
The Processor (CPU) reads what is in Slot 1 -> F-I-R-S-T.
Know this;
If you are using the regular Windows XP Home, or Pro; it is the 32-bit version.
If it is the Windows XP Pro 64-bit version, it will state so.
Either on the body of the laptop, or go to System Properties.
[Left-click on Start > then Right-click on My Computer.
Left-click on Properties at the bottom of the drop down list ]
Windows Vista 64-bit will state so also.
Point?
IF you have a 32-bit Operating System, your laptop will ONLY recognize about 3.2 to 3.5GB of ram memory; if you have 4GB installed.
Takes a 64-bit Operating System to recognize all 4GB.
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 06, 2013 | Acer Extensa 5420-5687 Notebook
Acer Crystal Eye Camera Not Working of extensa 4620
Please click on the link below:
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
2. Select Notebook-->Extensa-->Extensa 5620 (your Computer Model)
3.Now select the Operating System from the drop down box and download and install the Drivers.
4. If the Camera Driver is not available for download for Windows 7, then select the Windows Vista same version Driver and install. the Driver should be installed in the Computer as the Windows Vista Drivers should work with Windows 7 OS.
Jun 25, 2010 | Acer Extensa 5620-4020 Notebook
Acer Extensa 5620Z will not work with more than 2GB RAM??
parrotheadpc is incorrect in stating "you can only have a total of 2048 mb installed".
the 5620Z accepts 2 x 2 GB SODIMM RAM, the machine boots and shows the full 4 GB in the BIOS.
the full 4 GB works with the Ubuntu x64 installer.
Windows XP x32 goes BSOD on startup.
Windows 7 x64 install from DVD fails with same BSOD error.
conclusion: this is a Windows-Extensa 5620Z incompatibility that would require a fix by ACER at the BIOS level.
question: there may be specific memory modules 2 x 2 GB which do work--anyone have it work with Windows?
Oct 02, 2009 | Acer Extensa 5620 Notebook PC
Upgrading memory to 4GB failure
try to see if that memory is supported with your motherboard. The memory has something to do with that problem.
Jun 16, 2009 | Acer Extensa 5620 Notebook PC
Problem with upgrading my acer extensa 5620z memory to 4GB
Hi there.
I recommend you get another stick of SODIMM to replace what seems to be the faulty stick.
If you are using XP or Vista X86 (32bit) then the system will only recognize 2.8 - 3GB of memory, only 64bit operating systems recognize the full 4GB.
Good luck ad thanks for using FixYa!!
May 24, 2009 | Acer Extensa 5620 Notebook PC
Acer extensa 367 t
The only new hardware that you can install on that laptop is ram, and with a maximum of 80mb EDO you might be better off loading up a version of Linux that does not require a lot of memory. XP would be like molassas in January in Alaska. Vista would just not even get past the opening install screen.
Dec 10, 2008 | Acer Extensa 367T Notebook
Laptop speakers
you shouldn't have a problem, Vista uses Realtek high definition audio, assuming this is the sound make you use you need to install the normal Realtek audio driver, see below:-
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=6&PFid=6&Level=5&Conn=4&DownTypeID=3&GetDown=false
Aug 14, 2008 | Acer Extensa 503T Notebook
Install xp on acer extensa 4220 hard disk not detected
Acer Extensa supports two model of HDD installation 1) AHCI and 2) SATA.
Windows Vista get installs on both but for Windows XP you need to Enable SATA option.
For that go into Bios, Change option of Hard Disk from AHCI to SATA. After that you can install both XP as well as Vista.
Try it, and mail me update: ansari.yasser@gmail.com
i am using Windows XP on Acer Extensa-4220
Jun 21, 2008 | Computers & Internet
Vista SP 1 + second monitor: black and white
My vista ultimate uses around 1400MB of ram. while haveing just basic programs I use open.
I got 4GB ram. Well try to disable some of the visual features to free ram. Also vista ReadyBoost if i remember correctly uses alot of memory.
Vista ultimate?
Apr 17, 2008 | Microsoft Windows XP Home Edition
Acer 4220-2346 Notebook Logo
110 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
