Question about Samsung Audio Players & Recorders
HELLO PROTECTION When I want to switch on the HD 910, the display shows HELLO PROTECTION, then the HD 910 switch automatically out, no way to do something else.
  • fa430211 Jan 30, 2010
    Thanks for your answer.
    The speakers are disconnected, still the same message appears on the screen: HELLO PROTECTION.
    Apparently, according to your explanation, the amplifier is damaged.
    How to repair? I am in Phuket, Thailand.
    How can I be very sure that the amp is out of use?
    Regards
    John
  • fa430211 Jan 31, 2010
    Thanks for your helpfull comment.
    Appreciate the system.
    John
  • 547 Answers
"Protection" or "Protect" on the display means that the system has detected a short on one or more of the speaker outputs. If you cross the wires at one of the speakers, it can damage the amp output circuits, so it "protect"s itself when it detects this.
Disconnect each of your speakers from the back of the amp (label the wires with masking tape and a sharpie if they aren't already labeled!) and turn on the HD910 again.
If it still displays "HELLO PROTECTION" with no speakers connected, then the amp is faulty and needs repair.
If it turns on normally (obviously no sound -- you just unplugged all the speakers!) without the "HELLO PROTECTION" message, then the amp is fine, and one of your speaker wires has crossed. Inspect each speaker cable to see if something has scratched the insulation, or if a stray wire strand has touched the opposing wire.
Turn off the HD910, connect one of the speakers, and turn the HD910 back on again.
Keep doing this process until all the speakers are connected, or until you see the "HELLO PROTECTION" message again. If you get the PROTECT message, the last speaker you connected is the source of the problem -- you may need to replace that speaker's cable if you are unable to find a problem with it.
That's a lot of info, please feel free to ask questions if something isn't clear.
Posted on Jan 30, 2010
  • Rob C Jan 30, 2010
    If it's still going into protect mode with no speaker wires attached, there is a problem in the voltage output sensors or the internal power supply. Unfortunately I don't know how to find an electronics repair shop for you in your country, but you can be confident that it needs repair work to one or both of those systems, which are all inside the amplifier unit.
    I'm sorry it wasn't an easy fix for you this time, but at least now you know where the problem lies.
HOWTAVOIDAUTOPROTECTION
When the "Protection" indicator comes up the display panel of Denon ... In thermal cases, the circuitry will automatically reset after a few minutes of cool down
DC Protection is not something you can turn off..
Sep 04, 2015 | Denon Audio Players & Recorders
Protection mode
Protection on display usually means there is something wrong in the amp
May 29, 2013 | Audio Players & Recorders
Radeon hd6670 showing strange colours on my monitor occasionally
hello,
this "colours"appear becuase the graphic card cant display the image is too big to handle,check the spec for the game if your car is ok if yes maybe the graphic card itself has a problem.
Jun 11, 2012 | XFX Radeon HD 6670 - graphics card -...
My samsung automatic washing machine wa7584c1 is giving me a 1E error why ?
Hello, the error code is due to a water pressure switch error the service manual says
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. If you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s also before replaceing the pressure switch assure that the tube that comes off the switch that connects to the tub on the tub end has no debris or soap build up inside the hose this could also make the switch show as an error if the hose had something in the end of it. Thanks again
Aug 23, 2011 | Washing Machines
I have a 2010 Toyota Camry with a front passenger window problem. The window goes up and comes right back down sometimes when I push the button to roll the window up. The window will finally stay up...
Hello Susan..... What you are experiencing is the jam protection function: During automatic
closing operation, the window stops and opens half way if something gets caught
between the window and window frame. If the window receives a strong impact,
this function may work even if nothing is caught.
If the power window does not operate automatically or the jam protection function does not operate correctly, you should normalize the power window
To normalize the power window:
1. Push down the power window switch and lower the windows fully.
2. Pull up the switch until the windows close and hold the switch for a second. Make sure that the window open and close automatically. If the power windows cannot be operated properly, have it
checked by your dealer.
Dec 03, 2010 | 1995 Toyota Camry
Tomtom go 910
I have seen the green screen problem a few times before and this was caused by corrupted data / software or an error in booting up.
If you can't turn any TomTom off then perform a reset by inserting a paper clip into the rest hole and give 1 short press of the reset button ( it's a tactile switch so you should feel it click ) then try switching the TomTom on again the normal way. ( reset buttons are normally found through a small hole underneath the TomTom ).
If the TomTom does switch on but continues as before with the loading up problem , then it's best to format and reload all files from your backup copy.
A RED CROSS indicated a loading fault / corrupted files / incomplete files / corrupted or damaged media . ( media , meaning SD card or hard-drive )
Aug 05, 2008 | Tomtom GO 910
Samsung LTP326w
After few years of service with different TV providers I have problem with my TV. Last night my Samsung LTP326W just did the same think on HDMI connector and no mater what you do it will not turn HDMI video... it's connected to Verizon/Motorola DVR I called Verizon and they promptly replace DVR and HDMI cable but it didn't help at all, also sometimes when you power on/off I get message: The HD Content Protection of your display has been compromised Please use the YPBPR outputs for your HD connection...
When I switch to component cable it works just fine.
Feb 09, 2008 | Samsung LTP326WX/XAA 32 in. HD-Ready LCD...
KINGSTON pen drive is not responding
hi i am jimmy patel
i purchase a kingston pendrive but it is showing mall function and it is not working so provide me the solution
Jan 20, 2008 | Vantec 1 Bay NexStar 3 USB 2.0 External...
Back light of the LCD display is not working
Get a RMA by TomTom by callinging them directly (see on TomToms webpage) I've solved by shipping my unit to Neaderland with UPS at no cost, they replaced the motherboard (not the display, this  just remained the same!) I've received the repaired 910 after 5 days and I've spent no one cent! And I've got also the battery, AC power supply and software replacement! Other problems of the software are still present: the unit won't cange colors by night-light changes (only one time after a reset...), tryes to connect to phantom computers, after a power on it get off and then on if connected on the car support,... The 910 is a crazy device, not stable at all. I think I'll change it with the new model Go930T Ciao (sorry for my bat english)
Oct 23, 2007 | Tomtom GO 910
76 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
