Question about Standard Horizon Cpv550 Gps Chartplotter With Vhf
Integrating AIS, Radar, Autohelm 7000 and flux gate compass.
I'm considering adding to my new Autohelm 7000 (sailboat) the following. Which multiplexor will handle the (Black box) AIS demands as well as the flux gate compass so I can have chart overlays on the Standard Horizon cpv550 with the Sixtex Mds-8 radar?
    New Friend:
  • 132 Answers
ActiSense makes a programmable multiplexer that should do this for you. It is called an ActiSense NDC4 USB. Not sure is the Standard requires a separate compass signal, but if not, and the Standard can use a standard 38000 baud AIS data stream, the NDC4 will work for you. 847-746-0100
http://www.blueheronmarine.com/Actisense-NDC-4-USB-NMEA-0183-Multiplexer-with-USB-Port-6334
Posted on Jan 31, 2010
My tmq ap4 when on auto goes hand to port is the rfu not responding regards bill
Yep sounds like rudder reference failure or you have put something metallic beside the flux gate compass.
Sep 21, 2014 | Boating
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Need to reconnect a c-80 system. I think the MFD, radar, GPS, and depthsounder are connected via Seatalk
I think your best bet here would be to post your query on the Raymarine forum.
There are actual technicians over there to look after you.
http://forum.raymarine.com/
Hope this helps you out.
Aug 01, 2017 | Raymarine C80 GPS Receiver
Tp 30 keeps failing the calibration. Everything else seems to work fine. Tried numerous times using the instructions, doing the slow circles but each time it fails. I believe the internal flux gate compass...
I had the same issue.I opened up the TP30 to find that the wires from the compass to the circuit board had corroded and snapped.Trying to source a new compass unit now.Anyone know if they are the same as the new TP32?
Sep 18, 2010 | Simrad Tp22 Tiller Pilot Up To 36'
I have an old autohelm 800 analog with turn dial worked ok for three year on my 20ft sail boat Coreis but the other day it fully extended the arm and now it just 'clicks' and will not respond to turning...
I have a good one but need the mounting bracket that attaches to the side of the sailboat. So if u no longer need urs let me know price. Same for the electrical plug. Thanks
paul pebrown1@yahoo.com
Jul 10, 2009 | Raymarine Boating
I need to know what the signals on my radar detector mean
The following is a direct link to the PDF owners manual for your ESD 7000:
ESD 7000
Of note, this extremely inexpensive radar detector provides just about the worst performance of any radar detector product currently available from any RD manufacturer. I suggest that you visit radardetector.net to learn more about radar detectors.
Apr 20, 2009 | ESD 7000 Radar Detector
Furuno Navnet 2. Course up incorrect
you simply need an electronic compass hooked to it. without motion, the GPS does not know which way is up
Dec 19, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
My ais targets are out of line showing them out of the river
If the AIS targets are out compared with radar target then turn compass to superimpose radar on to AIS.
If the AIS info is out compared with chart then suspect GPS. This could be yours or theirs depending on how many targets are out and whether it consistantly in one direction.
Good luck
Mike
Dec 12, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Keeping course
Please check if the pilot is acting the right direction ,press +10 key and check if boat teers STB,
press -10 and check if boat turns PORT ,if it acts reverse, see handbook to reverse action.
Verify if compass course in standby is indicating correct course .
Do the calibration procedure as stated in in the handbook (360 degree turn)
If it still not indicate the correct course ,or is frozen, compass or printed circuit is faulty.
Check the resistance between the wires of the compass unit .(see google internet)
Good luck
Jean
Sep 11, 2008 | Raymarine RL70CRC GPS Receiver
Early Warning EW-3400 Radar Detector Digital Compass Calibration??
I looked at another simuilar Detector and read on Digital Compass Calibration and through the process of elimination found that if I Press CITY for 3 sec.'s COMPASS CALIBRATION showed on the display. Then it says TURN YOUR VEHICLE SLOWLY 2 TIMES to CALIBRATE. Then press the CITY button to complete the calibration. Done. It worked my Early Warning EW-3400 Radar Detector's Compass is now Calibrated.
Thanks for asking.
May 11, 2008 | EW3100 Radar Detector
Standard Horizon Cpv550 Gps Chartplotter With Vhf Logo
371 people viewed this question
Top Standard Horizon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Standard Horizon Boating Expert? Answer questions, earn points and help others
