Home | Garmin | Edge 305 GPS Receiver | Garmin Edge 305 - Unc...
Garmin Edge 305 GPS Receiver
Problem for Garmin Edge 305 GPS Receiver
Garmin Edge 305 - Uncommanded Power Down
By scudley on Feb 17, 2008
When cycling on bumpy or rough roads, my Garmin Edge 305 powers itself down occassionally without command from me. I can always power it back up immediately but I've lost some data.
Same Problem
May 21, 2009
-   When on a ride (don't think I've noticed it on a run) the device turns itself off.
I'm also having a (possibly related?) problem that the device won't "see" the USB port, take a charge, download its data to the software, etc.
I have to wait DAYS to use it again... weird.
-   jedimaste195
May 09, 2009
-   Mine just started doing the same thing -   Alpinist
May 01, 2009
-   I don't need to say much else. Same problem that everyone else is having. I love the product but hate having to power back up.-   Guest
Apr 24, 2009
-   moved it from my mt bike (with suspension) to road bike - no suspension, would power-off at the smallest of bumps, 20 times (or more) in 10 mile ride. It will stay on fine in my back pocket, though.-   Guest
Apr 10, 2009
-   Unit power itself down with minimum vibration.-   ckmramos
Best Solution
posted on May 28, 2008
Helpful)
monmak
Rank: Apprentice
Rating: 90%, 8 votes
I moved the battery wires to the main board, bypassing the spring contacts. No doubt my warranty is voided but at least the thing works now.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Apr 21, 2008
Helpful)
kfred
Rank: Apprentice
Rating: 88%, 2 votes
The problem is with the spring contacts between the two halves of the unit that carry power from the battery (back half) to the computer (front half). If your unit is outside warranty, you can follow instructions here: http://forums.motionbased.com/smf/index.php?PHPSESSID=000a201aaa94d328628ad489c9067181&topic=6566.msg42076 I did this, and it helped some, but I am still dropping power on very rough descents (like stairs), so I'm going to try adding a capacitor to the computer side so it can tolerate the brief disconnections from the battery. Making the contacts perfect seems to be a more daunting task.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Jul 28, 2009
Helpful)
sajoka
Rank: Apprentice
Call Garmin (800.800.1020), they have labeled this as a "known issue" and are now replacing units for FREE! Just sent mine off.
Was this helpful?
Yes
No
Solution #4
posted on Sep 11, 2009
Not Rated)
lmsdrywall
Rank: Apprentice
Rating: 0%, 0 votes
I also expierenced the unit powering down at the slightest bump. Called garmin support (be patient) they told me it is a defect;send the unit back. In less than a week I recieved a brand new 305.thank you Garmin.
Was this helpful?
Yes
No
Solution #5
posted on Aug 16, 2009
Not Rated)
HLaB75
Rank: Apprentice
Rating: 0%, 0 votes
I had the same problem an despite my edge being over 12 months old (18 I think) Garmin replaced it under warranty.
Was this helpful?
Yes
No
Solution #6
posted on Nov 14, 2008
Not Rated)
ddb2k1
Rank: Apprentice
Rating: 0%, 0 votes
I've done a repair along the lines mentioned in the Motionbased forum thread:
  • solder wires to connect the battery leads directly to the GPS board.
  • add a thin rubber spacer to the existing spacer underneath the small board that contains the USB port (on the battery side)
Using magnet wire (thin, coated, plastically deformable) to solder the battery leads provides a very reliable contact IMO - since I've fixed my Edge I've taken it on numerous hard bumpy mountain bike rides with good result.
The extra spacer adds some compression to the springs and improves the reliability of the contact. Besides the battery leads, also the USB contacts are guided through this connector to the GPS board, so you want to have this connector in good working order.
I've posted a bunch of photos and more detailed instructions on my site (below are a few)...
Was this helpful?
Yes
No
Popular Solutions for Garmin Edge 305 GPS Receiver
Questions and Unsolved Problems for Garmin Edge 305 GPS Receiver
Do you recommend Garmin Edge 305 GPS Receiver?
Answer
Answer
My edge 305 doesn't always pick up sallelite. I use it on my bicycle and it fell off adaptor onto... (More)
Answer
I will be riding a 340km 24 hr mtb stage race consisting of 6 stages in dec. How do I manage... (More)
Answer
my garmin edge 305 freezes up during the ride on occasion. the distance and elevation numbers just... (More)
Answer
Device shut off due to low battery and never charged again
22 Other Users Have The Same Problem - Continued
Comment by clocknutz, posted on Mar 07, 2009
Same trouble. Ruff road surface just keeps turning it off. Very, very frustrating. Have taken to putting it in my back pocket so I can at least get the information! Seems like Garmin should be sorting these out!
Comment by Guest, posted on Mar 04, 2009
Mine stops recording on its own.
Comment by bmolloy, posted on Jan 21, 2009
Same problem.  It is getting worse and even happens on smooth roads now.  Very frustrating.
Comment by bhouse4, posted on Jan 11, 2009
I had the same problem, shuts off while in use , I bent up the spring connectors, now the power stays on but cadence goes out any answers? I replaced the battery in the sensor, and lined it up the ride light flashes still cadence works intermittently???
Comment by Guest, posted on Oct 25, 2008
My shut-downs started after 3 months
Comment by bobr666, posted on Oct 12, 2008
Had the same problem that gradually got worse after two years of regular use. I tried the repair solution and that worked well until the first time it got very wet and then water got in. Once that happened, I didn't want to go through the repair again, so paid for an out of warranty repair. They gave me what seemed to be a brand new unit. Two and half months in and that one has now started to fail in the same way!
Fortunately, just inside the 90 day warranty, but a hassle!
Comment by Guest, posted on Oct 05, 2008
I have exactly the same problem: uncommanded power down when I encounter a bump (using mountain bike). I can power up again immediately, but I have lost data and the power up is risky, as I need to divert focus from driving.
Comment by Guest, posted on Sep 22, 2008
My Garmin Edge 305 shuts off randomly. It doesn't matter if I hit bumps or not. It may shut off after 5 miles or 15 but I can't finish a ride without it shutting off.
Comment by cavudaz, posted on Aug 29, 2008
My Garmin has started shutting off when hitting bumps. It has gotten worse. Today it shut off 6 times in 15 miles. Annoying!
Comment by Guest, posted on Aug 13, 2008
Same here- will try a software reset and see if that helps
Comment by yoopdog, posted on Jun 23, 2008
Unit first powered down by itself at the end of a road ride after going over some bumps (coincidence?). Notified Garmin, as the unit was still under warranty. Prior to sending out for repair, I downloaded the latest software. This appeared to fix the problem. Not so. The problem returned several months later. The unit is now out of warranty. I've notified Garmin again and I am awaiting my RMA return authorization number.
Comment by apsule, posted on Jun 19, 2008
I get this, very frequently. Sometimes I can sail over rugh ground without a hicup, someties it just powers down when I'm stood still. Not impressed, I want to ride my bike, not nurse the computer
Comment by Guest, posted on May 31, 2008
Does the same for me. Seems like a pretty poor design flaw given that it's a bike computer!
Comment by Guest, posted on Apr 05, 2008
same problem.
Comment by ciclista, posted on Mar 15, 2008
Same problem here. Frequent spontaneous power-downs for no apparent reason--bumpy roads not a necessary cause. This has made my 305 unusable. Reloading the latest operating system onto the unit had no effect. Neither did deleting all data from the 305. Plus, I bought my unit brand new from EBay, which automatically voids any warranty, according to Garmin.
Comment by rick1754, posted on Mar 09, 2008
unit turns itself off
Comment by halien, posted on Mar 05, 2008
The unit turns off on its own and I need to turn it on again (annoying!)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Garmin Edge 305 GPS Receiver:
Top GPS Device Experts
Rank: Guru Guru
Solutions: 14685
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more GPS Device Experts
Top GPS Device Repair
(281) 371-2722
GeoQuip is a "One Stop Trimble Repair...
Gulf Coast GeoQuip
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
