Question about Dell E152FP 15" Flat Panel LCD Monitor
Screen wont fire up, on/off button flashing in the on position.
No previous problems until this morning,turned the screen on and nothing except the on off button flashing.Pressed it in and out can just make out my screen saver for a brief sec very low resolution.pulled the leads and reconnected and no change.Help please Regards Andy.
  • 62 Answers
Monitor is toast, usually the power supply. If you take it apart you will find some of the capacitors are swollen up and leaking.
Posted on Jan 31, 2010
Testimonial: "that smells about right, thanks- Andy "
  • 141 Answers
Try rebooting in safe mode (turn PC off ,then on again, and then press F8 as it powers up until it shows the boot menu) If the monitor doesnt show anythingat all during bootup..... then either the monitor is dead or the videocard is dying.
Posted on Jan 30, 2010
Testimonial: "thank for your help, but still no joy"
Wii U gamepad touscreen and buttons won't respond
For other users that this solution may not have worked for and your wii u was working previously (not DOA), your problem may be as simple as a screen protector.
This was our problem, no buttons worked, the sceen didnt respond correctly but everything else seems normal. It seems that nintendo's hybrid resistive/capacative screen can sense the screen protector sometimes and will accept it as an entry.
Since the screen is always on, it can act similar to holding down a key down on a computer where no other entry will be excepted until the botton is released.... or in our case until you remove the screen protector. Removed and reapplied and all is well.
Dec 25, 2012 | Nintendo Wii U
Cold morning car wont start
If the anti-theft light is flashing, turn the key to the On position and leave it there until the light stops flashing. Turn the key off, then try to start the car. The Anti-Theft system can get tripped for no reason and cause this exact problem.
Nov 22, 2012 | 2001 Chevrolet Malibu
Ignition on and nothing happens, checked battery and is charged checked all fuses and breakers and all are ok, got underneath car and shorted across the starter solenoid end the engine would turn over but...
You may have a security system problem (Most likely caused by an ignition lock cylinder fault)
Is your SECURITY light flashing?
If so, do this:
Turn the ignition switch to the START position then release the key, leaving it in the RUN position.
Wait approximately 10 minutes untill the security light stops flashing, then without turning the key off, turn it to the START position again. It should start. If it does, then you should probably replace your ignition lock cylinder. The problem will gradually get worse until this method no longer works.
Jul 09, 2011 | 2002 Pontiac Grand Am
1992 jeep cherokee sport 2 door 4.0 inline six. Jeep was running fine except when you went to start it it took two cranks sometimes three then would start. Went to start it the other day and it took alot...
Sounds more like a timing problem than an O2 Sensor. Distributor out of Sync would be my guess. It ran better at Higher idles because the timing belt/chain was tight from tension at low idle the timing was off which caused your problems. Now the belt is either broken or so loose the timing is out and the vehicle won't fire. If it has a Distributor cap remove it and watch the rotor. If it turns the belt is intact but Timing may still be off.
Dec 27, 2010 | 1992 Jeep Cherokee Limited
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Standby flashing
Thats the protection circuit kicking in, overheating is rarely the problem, check your speaker wires for shorts. If it does that with nothing connected you have a bad amp board :(
Cheers,
Sep 12, 2009 | Denon AVR-95 Receiver
Printer error and load eject light on
Resetting the EEPROM
Press and release the On button to turn the printer off.
Press and hold down the Stop, B&W, and the Color buttons.
Then press and hold the On button until the LCD screen flashes three times
Release all the buttons. The screen displays Init. EEPROM
Press and release the Color button again.
Press and release the On button to turn the printer on.
Jan 31, 2009 | Epson Stylus RX500 All-In-One InkJet...
Swicthed on tv and its a blank screen..now it wont switch off.
Can you see the menus on the screen?
Can you hear audio (sound)?
If you can hear sound but no menu we need to check the backlight.
Take a flashlight and shine it on the screen, look very closely at the screen.
Do you see a video image?
Let me know what happens, I can assist further.
lone99star
Jan 09, 2009 | Samsung Televison & Video
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
Bulb replacement for Sigma EF-500 DG Super
So I had fixed the problem this morning, since the warranty has expired, I opened up the flash to take a peak on the inner workings, and found that a wire had come loose, got out the soldering gun and repaired the connection and all is good.
Sep 28, 2008 | Sigma EF-500 DG Super for Canon EOS TTL...
Dell E152FP 15" Flat Panel LCD Monitor Logo
293 people viewed this question
Alun Cox
