Question about Apple iPhone Smartphone
My iphone won't turn on it's just a plane black screen, it doesn't do anything and it won't charge either. please help me.
Reset the iPhone by holding the sleep/wake button at the top right of the device and thehome button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Resetting the iPhone should not remove or delete any data or settings.
pd
Posted on Jan 30, 2010
    Problem Solver:
  • 5 Answers
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
My iphone won't start or charge or hook up to puter
hold the power and home button in together! - HARD RESET
Mar 29, 2013 | Apple iPhone 3GS Black (16 GB)
Iphone won't charge unless it is completely powered off
Luckily, there are some tracks you can try to fix it.
iPhone wont charge when turn on
# Check Charging Accessories
# Clean Charging Port
# Hard Reset Your iPhone
# Using iPhone Recovery Mode
# Restore iPhone to Factory Settings
http://www.recoveryiphone.net/article/fix-iphone-wont-charge-when-turn-on.html
try practical methods to fix your problem, and if it still can't get your problem solved, just take it in for service at the nearest Apple Store in your area to get the help of the Apple employee.
Mar 20, 2013 | Apple Iphone 4s latest Model - 32gb -...
Bought my iphone 5 and am unable to charge using both the plug and computer. however am able to charge using the iphone 4 plug. please help!
Before you can charge your iPhone on the computer, your computer needs to install the drivers for it. You might have to reinstall the drivers for it. A good way to check if the drivers are incorrectly installed is to see if iTunes detects it. Try updating your iTunes since the old version of iTunes won't work with ios6 and all iPhone 5 are shipped with ios6
Oct 10, 2012 | Apple iPhone Smartphone
Iphone won't turn on
Hi
What happens when you try to charge the device?Won't charge?Switch chargers.
Try hard resetting it and see what happens.Here's a video tutorial on how to go about it.
Hope it helps.Thanks
Feb 21, 2012 | Apple iPhone 3GS Black (16 GB)
My lookbook won't turn on
Try letting it have a full charge. Occasionally this is the problem with a black screen. If that doesn't work, call kobo. They should replace your lookbook with little trouble. Just be patient if you go this route, it takes around a month to get the replacement, and the replacement is a refurbished unit as a heads up. Personally, I was more than happy with my replacement. No more problems! :)
Sep 03, 2011 | Sharper Image Literati Reader 16375680042...
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
I have an iphone 2g, and it takes forever to turn on, up to hours and the screen just apears with the apple and the loading sign, and it keeps turning off and on. and when it finally turns on and then...
Restoring your iPhone should help regain full functionality but please beaware this will completely wipe your iPhone memory so be sure to do a full sync and backup before you do anything.
  1. With your iPhone on connect it to your P.C/Mac using the USB cable
  2. Turn your iPhone off
  3. Press and hold the home button while turning your iPhone on
  4. Your PC/Mac should then detect your iPhone in "DFU mode".
  5. iTunes will also detect your iPhone in "DFU mode" and allow you to select restore.
This can take up to 2 hours so be patient.
Dec 01, 2009 | Apple iPhone 3G
My iphone wont turn on or charge!!
That happened to me. Push the home and on/off buttons simultaneously until the apple logo appears, then wait until it has fully restored the system. This should work. Good luck
Jul 28, 2009 | Apple iPhone Smartphone
My Iphone wont turn on
hold power button and home key as soon as u see apple logo let go of power button but keep holding home key this will put iphone in recovery mode then sync n recover
Apr 05, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
173 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
