Question about Toshiba SD-4000
Toshiba SD-4000KU DVD player - Won't recognize any discs.
Toshiba SD-4000 DVD player. 4 years old. Has been working fine, regularly cleaned, suddenly won't recognize any disc placed in it. Used remote to reset to factory defaults, still doesn't work. When placing a DVD into the tray, it closes, sounds like it's trying to spin up, but I only hear 3 very short sounds before it reads ''No Disc''. Even the cleaner disc won't spin up.
  • 244 Answers
SOURCE: Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Posted on Nov 17, 2007
jonniewalker
  • 1029 Answers
SOURCE: Toshiba sd-p1400 dvd player not detecting discs
i think the motor is bad since its nt spining u can change the motor
Posted on May 24, 2008
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
SOURCE: Disc loads but I get four dashes showing on DVD window
plis help me
Posted on Oct 25, 2008
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
Every DVD I put in to the SD-4000, has a 'no disc' sign come up and won't play. is it forever broken?
There are three things you can do that will eventually give you a working solution. Depending on the level of problem. Start with 1 progress to 3 until it works.
1. Use a cleaning disc. (one that use an alcohol based liquid)
2. If the cleaning disc does not solve it, you can use an ear bud, with some iso-propyl alcohol to clean the DVD lens on the drive directly. (you have to open the player and the drive)
3. The guaranteed working solution is to replace the DVD drive inside the player. This is quite a simple process, as most players use a standard IDE DVD-ROM or DVD writer.
You simply remove the face plate, (apply power to the drive, and press eject first) the tray will open. Unclip the tray face, and then with the tray open you can unclip the plastic face plate too.
Remove the old drive, and fit the new drive by reversing the removal procedure.
Once everything is assembled you should be able to watch DVD's again. If you can't find a cheap DVD drive locally, try ebay.
I have done this on over 50 players for my clients in the past. I use LG IDE DVD roms and IDE DVD writers for the DVD recorders, irrespective of brand.
Let me know how it goes.
Feb 28, 2010 | Toshiba SD-4000
Sound no picture with dvd player
Exchanged AmEx Rewards points for 3 Toshiba Model DS-4000KU DVD players in 2007. All stopped working. Two a year ago, one this week. Errors - can't read disc, bad disc, etc.
Warranty period is up. So I decided to open one up tonight since they were going in the garbage anyway.
Put on rubber gloves and took off the case. Unscrewed the player unit, lifted it carefully, and untaped lines from the botton of the unit.
Plugged the unit in and powered it on. Did not blow up! :>)
Jiggled some of the lines and connections. Put a disc in and it read it!
Attached it to the tv without putting the case back on. Received video. Yay! But no sound. Boo!
Jiggled the lines some more and tried it again. Working fine now.
Will put the case back on later and see if it still works.
Dec 09, 2009 | Toshiba SD-4000
I have a Toshiba SD-4000KU dvd player which worked fine but is now not loading and just says bad disc with a perfectly good disc what solution is there to rectify my problem. Thanks
Just wondering whether damp has affected the circuit boards.
Try putting it in a warm room plug it in and leave for 2 hours then try again.
Nov 13, 2009 | Toshiba SD-4000
Sd-v392 claims incorrect disc on most dvd`s
I removed the cover,the dvd unit and cleaned the laser lens with alcohal. The two back screws were loose on the dvd unit. It`s working like new again.
Sep 18, 2009 | Toshiba SD-V392 DVD Player/VCR
Erratic operation of DVD players after a few months of non-use
what you should do is to clean the OPTICAL LENS directly with a dry Q-tip , could be that it collected some dust and thats why its playing erratically, give it a try , AJ
May 29, 2009 | Toshiba SD-1800 DVD Player
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
MIXED SIGNALS?
I think, titels are changed other wise both are same signals.
Jul 26, 2008 | Toshiba Televison & Video
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Toshiba SD-4000 Logo
256 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
