Question about Jenn-Air JED8430 Electric Cooktop
Elecrical hook-up for cooktop
Hi I have a Jenn air cooktop ,model no# ccs446w-c, and it has five wires 1-red,1-black, 1-yellow, 1-blue and a solid copper wire. Can someone tell me what i need to know to install. Thanks
  • florient Apr 09, 2008
    thanks for your help i'm going to follow through with your suggestions
  • robert samples May 11, 2010
    this is not comming up as a valid model sure you dont have the serial num should begen with a j and look on the cooktop for the serial plate are you in the usa
    Scholar:
  • 148 Answers
Based on your description...it appears the Viking unit may NOT comply with UL and the NEC....but implies that some local Codes may permit the suggested connection...and it may indeed be permitted - if the unit actually draws straight 240 and does not require a neutral for 120 volts (some cooktops do need the neutral for 120 volt control switches...such as your Jennair). Code now requires that new 120/240 units that require the neutral (your Viking unit states that it does not) be a 4 wire assmebly....and your unit MAY be an exception to this requirement.
Under those conditions...then it more then likely CAN be connected as you (and Viking) suggest - black to black, red to red,green to white...and insure that the junction box is indeed well grounded to the supply bare ground wire - so that the metal flex will serve as a supplemental ground to the cook-top.The only other consideration will then be - IS the exisiting wire size and breaker that used to supply the Jennair correct for the new unit..? And if so - then you should be all set with your suggested hook-up...but without electrical nameplate data for both units for comparison...I have no way to determine that....both companies make several different models with different power supply requirements.
If the electrical data is compatible between the two units...then you should be all set as suggested - without having to rewire the cooktop.
Hope this helps...please follow-up if you need more details or have new information for me concerning this cooktop.
Posted on Mar 03, 2008
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
Do i connect the red and black wires together
No you do not. You have a 220 system. What you do to hook it up is. In the box in the wall you should have 3 wires. 2 black and one white. Then on the cooktop you have the 3 wires 1 black, 1 red, and 1 white. You take the black from the cooktop to the black in the wall box. Take the red to the other black in the wall box. then take the whites and put them together. Now if you have a green or bare wire that is the ground. Just hook that to the wall box.
If you have any questions please ask.
May 09, 2010 | Jenn-Air JED8230 Electric Cooktop
We have a jenn air outdoor cooktop. The right side didnt work so we took apart and blew circut breaker. Now we are trying to re wire but dont know where the green ( ground) connects. Canyou please help?
Hi, depending on your local electrical code:and I see that the unit is 240 Volts A.C., then RED=Power/Black=POWER(L1 & L2)/WHITE="N"Neutral/and GREEN=SAFETY GROUND,on the new unit, then use from the wall power BLACK = L1 and White= L2. then on the unit RED=L1 and BLACK=L2(either way you hook these 2 up there isn't a polarity issue on these 2 wires) on the units hook-up/then use the BARE supply wire as neutral and tie BOTH WHITE and GREEN from the unit together to this BARE wire..
Take care
May 01, 2010 | Jenn-Air JED8230 Electric Cooktop
Wire from circuit breaker is Black/White/Bare(ground). From Jenn Air is Black/White/RED/Green (ground). How do I wire? Jenn Air Black to Black, Jenn Air Red and White to White? Grounds (Jenn Air Green to...
Apr 29, 2010 | Jenn-Air JED8230 Electric Cooktop
Jenn Air cooktop has 4 wires Black, white, red, and green and my house supplies power with 3 leads white, black , & green. How are the wires hooked up to power the unit?
Old plug: green is ground, white and blace are both hot power. New cooktop: green is ground, WHITE is COMMON, black and RED are hot power. You are going to need an electrician to run a new circuit and plug for your new cooktop.
Aug 31, 2009 | Jenn-Air JED8230 Electric Cooktop
Jenn air model JED8430bdb
A similar concern on a different model (8230):
To my knowledge, the:
green - ground
white - neutral
black - 120 to ground
red - 120 to ground but between red & black, it should be 240. A Jenn-Air JED8230 requires a 3-wire, 120/240 Volt, 60 Hz Outlet.
Pls consult/confirm with your local electrical utility/codes the availability/applicability of this power/wiring system or reference National Electrical Code, NFPA No. 70
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | Jenn-Air JED8430 Electric Cooktop
Electrical hookup
no its 220 red to one 110 line blk to the other 110 line white to neutral should be a solid metel wire to take that to ground
Jan 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
754 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
