Question about Lexmark X4270 All-In-One InkJet Printer
Replacing an encoder strip in a Lexmark X4270
I have tried to put the strip back in b/c it's completely out of the printer following the instruction given by help support but is unable to locate the slots on the back of printer cart. door. Where exactly is it suppose to be put and will I have to replacre it if I continue to touch it? Thanks to whoever can help!!.
    Problem Solver:
  • 7 Answers
Hey jessies well the the encoder strip is which comes back of catridge carrier , just call back the customer care, they will help u out
Posted on Mar 01, 2008
Error 1200 is showing
The 1200 error could be caused by a cartridge not properly inserted in the carrier, encoder strip got unseated from its position or there's something blocking the cartridge carrier path. Try to refer to this article in the Lexmark website to determine what's causing this and resolve the problem: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
May 19, 2011 | Lexmark X4270 All-In-One InkJet Printer
The long clear stripe in my lexmark x4270 came out. i need to know how to put it back in
This article in the Lexmark website has some visual aids that can better guide you on how to reseat the encoder strip (long clear stripe) in your printer: Printer Cartridge Stalls or Is Blocked.
May 15, 2011 | Lexmark X4270 All-In-One InkJet Printer
I can't install my all in one printer
Try to use the updated Lexmark X4270 driver from the Lexmark website. Note: Lexmark X4270 works on Windows operating system only.
Go to this link to download the Lexmark X4270 Driver. Select your operating system version by clicking on change OS.
Click on FILTER.
Then, click on the Complete Driver under Recommended Downloads.
Download, execute the file and follow the instructions on the software.Thanks.
Dec 15, 2010 | Lexmark X4270 All-In-One InkJet Printer
We are not able to send faxes,the error message is 1200. The reference number for the fax is x4270.
The 1200 error indicates the cartridge carrier has stalled. It could be caused by a cartridge that's not properly seated or the encoder strip (transparent strip behind the cartridge carrier) is out of place. Refer to this article from the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One to help you identify and resolve the problem.
If you need additional assistance, please contact Lexmark technical support. Thanks.
Nov 18, 2010 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X2480 encoder strip completely fell off
Hello. If the encoder strip just fell off but not broken/ripped apart/torn, try if you can have your hand hook it up back to its place. I believe it just goes back in to a hook on the side. That might be difficult to do though since the hook is all the way to the side and there's not much enough space for your hand to move. But if your printer is still within warranty, try to call Lexmark and hope they can replace it for you. Hope I can assist you more on this.
Apr 10, 2010 | Lexmark X6170 All-In-One InkJet Printer
Lexmark x4270
The 1200 error is caused by a cartridge carrier stall. This can happen if the encoder strip is out
of place.
Please follow the steps given below:
1. Turn off the All-In-One by pressing the power button. Open the control panel and cartridge access
door.
2. Gently grasp the cartridge carrier belt in the area indicated by the blue arrow and move it to the
left
3. On the back of the cartridge carrier, there is a small slot that the encoder strip fits into.
Remove the print cartridges and then gently push the encoder strip down and then back up to get it
into the slot. NOTE: If the strip is completely out of the slot, it may be necessary to move it
first forward and then back.
4. Reinsert the print cartridges and slide the cartridge carrier back to the right. Then close the
cartridge access door and the control panel and turn the All-In-One back on.
5. Did the error message return?
If Yes, continue to 'Contacting Lexmark' below.
If No, the error is fixed.
Apr 08, 2009 | Lexmark X4270 All-In-One InkJet Printer
Replacing encoder strip om Lexmark X6170
First unplug your printer...
Lift your printer top, like you are going to change your ink cartridges.
Unplug your scanner & control panel by disconnecting the 3 ribbon cables
Then, you will need a screwdriver (philips head). remove the screws (about 4) from the inside housing cover.
After you have this cover off...
You should be able to see the sides of the cartridge. Take your encoder strip (gently) and thread it through the back of the cartriidges. Note: There are small slits on the side where you can thread.
If the encoder strip has come completely off (there should be tension if it is connected), you will have to located the right and left "pins" to attach it back to. I have a lexmark x-2500 so, mine are on the metal frame. The right end (arrow up) attaches to a metal strip which points straight towards you (a part of the metal frame) with a small notch at the right end and on the left end there's a type of "punchout" pin which is a part of the metal frame. I had to slightly bend the right end pin to the right, just enough to create some tension & keep the encoder strip from popping back off. The left end pin should already be bent out to the left.
Hopefully, this helps someone
Feb 07, 2009 | Lexmark X6170 All-In-One InkJet Printer
Encoder strip
Is it just loose or out of its slot or is it faulty and you need a new one?
Jan 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Encoder strip
This is the the brother inkjet forum. Plz post again under lexmark!
Jan 13, 2008 | Brother Multi-Function Center MFC-240C...
Lexmark X4270 All-In-One InkJet Printer Logo
61 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
