Question about Tomtom ONE GPS Receiver
Tomtom not turning on - Tomtom ONE GPS Receiver
    President:
  • 1,738 Answers
If your device is not starting up properly, follow the steps below:
  1. Soft reset your device.
  2. If your device still does not start up, then reinstall the TomTom application using HOME
Posted on Feb 04, 2010
My Tom Tom 1 had this problem, it was the ON/OFF button that was broken. I dismantled the device and soldered on anexternal switch instead, problem fixed
Posted on Feb 05, 2010
When i turn my tomtom on i only see tomtom anf symbol
If it doesn't continue to show the license and owner screen, it means that the TomTom (navigation) software is not running properly. Often it means that the software is corrupt, and it has to be repaired or replaced.
If you are able to connect the TomTom device to a computer (using the USB port), select the TomTom disk, right click and select Properties, and run the TOOLs to check and repair the (TomTom) disk. After completing the repair, disconnect it (from the computer), restart the TomTom - turn it off and turn it back on, and see if you get it going normally. If not, you'll need to restore your navigation software from your backup and see if it works. Or you can download the navigation software from the TomTom website and copy it onto your GPS device.
Aug 08, 2014 | Tomtom XXL GPS
Where is the reset button on the Tomtom xl340s
The TomTom XL 340-S uses the power button as a reset. With the unit turned off, hold down the power button for approximately 15 seconds, until the TomTom turns on. As soon as the unit turns on, release the power button. The unit is now reset.
Nov 21, 2009 | Tomtom XL 340S Car GPS Receiver
My gps tom tom turns itself on waht could be
If you search for "TomTom turns itself on", you will find that there appears to be a problem which TomTom will not acknowledge. Mine always turns itself back on exactly (to the minute) one week after being switched off and runs the battery down. Tomtom have got me to reformat and had it back for repair but the problem remains
Oct 10, 2009 | Tomtom ONE GPS Receiver
My tomtom doesn't turn on
the green light shows when i am charging my tomtom but it doesn't turn on.
Aug 19, 2009 | Tomtom GO 720 GPS Receiver
Restore to factory setting
n rare cases, your TomTom device may not start correctly or may stop responding. If this happens, try resetting your device. The only information lost on your device is the clock’s time zone setting. Select your device from the list below to see how to reset it.
Select your device: TomTom GO 940/740/540 TomTom GO 930/730/630/530 TomTom GO 920/720/520 TomTom GO 910/710/510 TomTom GO, GO 300/500/700 TomTom XL IQ Routes TomTom XL (30-Series) TomTom ONE XL TomTom ONE IQ Routes TomTom ONE 30 Series TomTom ONE 3rd Edition TomTom ONE 2nd Edition TomTom ONE 1st Edition TomTom RIDER 1st Edition, RIDER 2nd Edition TomTom ECLIPSE II TomTom DAIHATSU, TomTom ECLIPSE, TomTom TOYOTA Help Not sure which device you have? ico_close.gif Type the first two characters of your device's serial number below to find out.
To reset your TomTom device, do the following:
  1. Check that the battery is charged properly.
    Charge your device for at least 2 hours before trying to turn it on again. Make sure the charging light on your device is on.
  2. Remove the SD card
    If your device uses an SD card, remove it.
  3. Reset your device.
    Use a straightened paper clip, or something similar, to push the reset button for 15 seconds. See the pictures below for where to find the reset button.
  4. Turn your device on.
    Press the On/off button for at least 5 seconds.
  5. Insert the SD card
    If your device uses an SD card, insert the SD card.
The rest button is on the top of the GPS
Jul 23, 2009 | Tomtom GO 910 GPS Receiver
Tomtom Advert on Tomtom XL wont turn off
It's a default demo. You can remove it by changing it in your preferences, not by deleting files
Jan 20, 2009 | Tomtom One XL GPS Receiver
Updating my tom tom
Visit:
http://www.tomtom.com/support/support.php?ID=3&Language=1
Download/install TomTom Home software.
Make an account at TomTom here:
http://www.tomtom.com/myTomTom/myProfile/index.php
Connect and update after previous steps...
Apr 09, 2008 | Tomtom One Europe v2 GPS Receiver
Tomtom go 300
before you start take out sd card. 1 turn tomtom upside down. 2 see reset button? 3 use paper clip to press (press for 15secs) 4 now turn on tomtom (hold power button for approx 5secs. 5 re insert sd card. after a few minutes you should have signal. hope this solves your problem.
Mar 19, 2008 | Tomtom GO 300 GPS Receiver
Tomtom 700 turns then turns its self off again
STEP 1
Connect your TomTom to your computer via USB and open up your Windows Explorer and go to the drive. (It will be listed as TOMTOM (E) or some other drive letter).
Copy the Yellow Folders one by one to your PC. Ideally, save all the folders under a new folder that you name.
You may find that the folder ttntools and gns may not be copied. This is o.k. if they aren't.
STEP 2
Format your Tomtom via MY Computer.
STEP 3
Copy the Yellow Folders from the backup you made in STEP 1 back to the TomTom.
STEP 4
Open TomTom Home
Click on Upate Now.
Install the latest update onto your TomTom.
Once installed, switch your TomTom off, then disconnect if from the PC.
Thats it. From now on, make a full backup using TomTom Home prior to any updates.
Also note, that copying all the files will take some time.
Sep 29, 2007 | Tomtom GO 700 GPS Receiver
Tomtom ONE GPS Receiver Logo
353 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
