Question about Whirlpool Refrigerators
Drain freezing up and leaking water into refrigerator
  • 37 Answers
Turn the thermostat down to about half way, your fridge does not need to be that cold. It should stop freezing up and the thawing out and leaking.
Posted on Jan 30, 2010
Why is water leaking out evey day???
Is the water leaking from the refrigerator compartment or the freezer compartment? Can we assume the "leaking" water is more than some accumulated humidity/moisture (check your door gaskets)? Have you checked all water lines/fittings for the water dispenser/ ice cube maker (if you have one)?
If it is is the freezer section, the problem may be a clogged drain line (is there ice blocking the trough drain hole?) at the bottom of the freezer (evaporator) coils? You may need to defrost the freezer, check for any faulty parts (e.g., defrost time/ADC, defrost thermo, defrost heater), and clean the drain trough/tube. See Refrigerator Defrost Parts for illustrations.
May 22, 2014 | Roper Refrigerators
Water leaking from the freezer unit.
The drain hole is probably frozen over. When it goes into defrost mode every 10 hours or so, the evaporator heater removes the ice from the evaporator. There is a drain hole under the evaporator with a hose attached that goes down to a pan by the compressor fan where it is evaporated so as to not leak water on the floor. When it freezes over the drain, the water fills the bottom of the freezer until it comes out the door. A common fix to prevent the drain from freezing over is to take a bare copper 14 or 12 gauge wire and put a couple turns around the evaporator heater and stick the other end into the drain. This heats the wire enough to keep water from freezing b over the drain hole.
Dec 09, 2013 | Jenn-Air JFC2089HE French Door...
Msd2757ae freezer leaks water
Leaking Refrigerators Just What may Be Happening
I am pretty sure you are having a defrost drain blockage problem, and click here=>
Leaking Refrigerators! Let me know if helpful, Sea Breeze
Feb 23, 2012 | Maytag MSD2756G Side by Side Refrigerator
Started leaking water accumulated on bottom shelf in lower level. now top freezer takes 2 days to freeze ice, bottom freezer vent clogged.
The drain is clogged. When the drain clogs it can also clogs the airflow vents. Remove the back wall of the freezer to access the drain. Remove all the ice blocking the drain and the vents. Then use a trukey baser to force hot water down the drain until water flows freely. Then mix water with baken soda and pour it down the drain. http://www.appliance-repair-it.com/refrigerator-leaking.html
Sep 27, 2010 | Kenmore Top Freezer Refrigerator
Refrigerator ge profile model TFH27PR water leaking onto floor
Hi this problem could arise due to various reasons so lets find out what could it be the cause.
1)In the back of your freezer compartment is the drain hole. It's very common in GE for the drain to freeze up. With the drain hole plugged up, your freezer will continue to defrost the evaporator, but not the water in the drain hole. So the water builds and freezes, builds and freezes until it eventually overflows into the air diffuser for the fridge causing the leaky fridge problem."Heat Probe" that can be installed.This will prevent water from freezing up in the drain hole allowing it to drain as designed
2)Inspect the door seals and the sides of the refrigerator around the doors. If you see any beads of water or moisture, then the door seals may be failing to create an air tight seal which causes the cold air from the refrigerator to escape and form condensation around the doors. Sometimes you can solve this problem by applying a light film of gasket lubricant to the existing seals or just cleaning them of any debris with a warm soapy rag. If they still don't seal well after you apply lubricant, or clean them, you may need to replace the entire seal assembly.
3) If the water is coming from the freezer but you think that the defrost drain pipe is clear, then it may be coming from the ice maker. Check the ice maker for cracks in the unit's body or a misalignment of the water supply line. Make sure that the water supply spout in the freezer lines up with the ice maker's water supply cup.
4)Check the ice maker copper water supply line, your ice maker water filter, and the plastic ice maker water supply tube for any cracks, splits or connection leaks. If you find any leaks, remove the leaking part and obtain a replacement at the hardware store.
5)Your leaking refrigerator may just have a cracked or damaged drain pan. Your fridge regularly drains water into this pan to prevent water pooling in the fridge itself. Evaporation takes care of the rest. Look underneath your fridge where the drain pan sits and pull it out for inspection. If it has a crack or is otherwise damaged, contact the appropriate retailer about getting a replacement as soon as possible.
6)If your leaking refrigerator is draining inside as opposed to onto your floor, you're probably dealing with a clogged defrost drain. Your fridge is constantly producing condensation inside the freezer, and that condensation drips down the defrost drain into a drain pan underneath the unit. This defrost drain can become clogged with debris or, more often, it freezes shut. Look in your refrigerator manual to locate your defrost drain, and take the appropriate steps to unclog it (inundating your drain with warm water will often do the trick).
Note:Switch you Refrigerators for more than 8 hours and let the frost melt fully use hair dryer and now switch on and check you are getting leak.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 09, 2010 | GE Refrigerators
Water drain tube is plugged, leaks inside the frig
Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem.
Mar 29, 2010 | Refrigerators
Freezer leaking water and freezing
you probably have a plug in the drain line that normally drains the water when your freezer goes into the defrost mode. at the base of the refrigerator there is a evaporative drain tray where the water drains from the freezer into the tray and evaporates during normal operation of the unit. You should be able to see the drain tube just above the tray. Attach a hose to it and use compressed air to blow through it and clear it out.
Mar 16, 2010 | Refrigerators
Water setteling on bottom of freezer side and freezing also leaking. 2 fridges both doing the same thing . leaking on the inside and freezing and underneath water is leaking.
Clean out the defrost drain. There is a drain in the freezer that lets all the defrost water run under the fridge. If that gets clogged then all the water runs into the freezer and can even leak onto the floor
Sep 13, 2009 | Refrigerators
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerators Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
