Question about GE Televison & Video
Has power and sound no picture - GE Televison & Video
  • bdnoble Jun 09, 2010
    I was looking for a little more info on location of board and difficulty of job. And if it is worth fixing. Thank you for your time.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. This is often caused by failed convergence ICs. I don’t think the issue is with the power supply of the unit as the sound is coming fine from the unit. Also please check that the lamp is fine. Resistors will change value and burn. This will cause other components to become defective. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The typical cost to get this fixed by a pro is about $300-350. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Also the convergence board should be checked for cracked solders. If one IC is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Although it is worth to get it replaced but you may choose to buy a new set. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 09, 2010
  • 1 more comment
    Hello, Thanks for your help. So the y sustain board is not the issue? Why does the menu work, and the set up images display but no picture. It worked fine until some bad lightening came through. Would this be a cause for the problem. Do you have any suggestion where to get the parts, and do I just need model and serial number to order them. Thanks again, B. Noble. I also noticed that the three projectors are on, there is a white screen while using inputs. Like for VCR. Thanks again
  • Rylee Smith
    Rylee Smith Jun 09, 2010
    As it is a Projection TV there is no ‘Y’ Sustain board. However,
    you can order parts online from the link---
    Parts for Projection
    TV
    If you are not able to locate the parts for the brand and
    model no. of your projection TV then please let me know. Please do accept the
    assistance.
    Thanks
    Rylee
  • Rylee Smith
    Thanks
    Rylee
    President:
  • 1,099 Answers
The y sustain board is the most common reason for no picture but sound okay .
More than likely this will be down to your Y Sustain board has gone faulty, when the back is off your TV it is on the left hand side and will probably have a fuse that has blown, replacing the fuse will not solve the problem as it is the IMP under the heatsink that has gone faulty.
You should get the part number of the board at Ebay.com for a replacement.
Hope this helps...
    I see only one fuse, this is by the power in. Would a lightening storm be a cause of this problem, and is this something that I can fix on my own? Thank you for your help.
How do I fix a tv that turns on but has no picture or sound?
if it has no sound or picture then it must be the power supply .
Nov 22, 2015 | Televison & Video
No picture or sound
Looks like a power supply issue the only solution to fix this up is to get it repaired.
Goodluck..
May 03, 2008 | Toshiba 32HFX72 32" TV
I have a memorex. I am getting sound but no picture. When powered on, the memorex sign shows up but then no picture just sound. Also makes a slight screeching sound for approx 10 sec. when powered on.
I guess the blanket draped over the TV is intended to give it a "timeout". Anyway, you will likely conclude eventually that the internal power supply has failed.
Jan 02, 2014 | Memorex MLT1921 19 in. LCD TV
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
At first, no power, no sound, and no picture. I replaced the power source board. I have power and sound but no picture.
verify your connections you may have the video cable connected to a different input than your audio
Apr 14, 2009 | Televison & Video
No picture or sound?
hi i have a 42 inch plasma samsung tv i have picture and no sound
Nov 03, 2008 | Televison & Video
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
