Question about Radio Communications
President Harry 2 classic does not listen (receive)
Hi
i can only hear very week rumble/noise when im listening, volume is 10 and squelch 0...whats the problem?
  • tomppa-76 Jan 30, 2010
    Hi And thank you for help.
    But i can not find IC4 this radio the main board is text like UNIDEN 2004 PA-435AA 1/4
    I wonder that maybe their is different schematic?
    Internal speaker is ok , becaus turn on beep is hearing well.
    Transmitting is also OK.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initial tests:
  • if there is likewise no TX modulation, check / replace audio IC4 TDA1905;
  • if RX signal strength (S meter reading) is low, check RX + 8VDC;
  • try using an external speaker in case of a faulty internal speaker;
  • exercise the AM/FM switch.
If all of the above checks good, then signal tracing from the front end down to the audio amp. Would the schematics help?
Good luck and thank you for asking FixYa.
Posted on Jan 30, 2010
  • Louie  Role
    Louie Role Jan 30, 2010
    Appreciate the postback and additional information.
    The above schematics is for a President Harry using UT-322 board/chassis Uniden PA-259.
    I do not think that I have the schematics for a PA-435AA.
    Looks like signal tracing would be a good approach with attention to the IF filters for the RX problem of the Harry.
  • 10,865 Answers
Hello. leave the volume set at ten and then slowly increase the squelch until you get the clearest possible reception. Regards, Joe
Posted on Jan 31, 2010
Hello I have a RadioShack police scanner with frequencies on it I have had it for 5 years noe all of a sudden I ain't receiving any action and my squelch
The police and or fire department may have gone digital. an analog scanner will not pick that up. Often departments will switch their frequencies so the "bad guys" cannot listen in. They forget many of us "good guys" listen and can aid them.
Does the squelch make noise if you turn it all the way to open? Then you know the scanner is working.
Jan 31, 2018 | Radio Communications
I bought a set of 2 way radios to keep touch with hiking partners. I've never used 2 way radios before and I'm clue,es as to how they function
If you tell us make and model, you may get a better answer. The instructions may have a better answer too.
Basically:
  1. Charge or put in batteries.
  2. Turn both radios on.
  3. Turn the volume up.
  4. Tune both radios to the same channel. Pick a channel that is quiet. Quiet means very little chatter and very little white noise. You can make a channel more quiet by increasing squelch but increasing squelch decreases range.
  5. Both radios are now listening.
  6. When you want to talk, press the talk button and say what you want to say.
  7. Remember you are just talking to anyone listening on that channel, so be nice.
Sep 03, 2015 | Radio Communications
This is a confusing website. But my problem is with a pair of Uniden FRS 420 two way radios. Have replaced batteries, gone through manual, have every option set properly but still have no reasonable...
Are you stating the volume is not loud enough when someone talks or just idling. If if has a squelch knob turn it til it makes a hissing noise or rushing noise. then back to where the noise just quits. This is the proper setting. Then when someone talks increase volume to listening level you choose. If this does not work take them back and get your money back.
Dec 22, 2013 | Uniden 2 Way Radios Frs 420 Family,14...
Icom m36 will not receive. Speaker makes noise with squelch all the way up but just won't receive anything including weather.
You may have the CTCSS tone squelch enabled so unless a station you're listening to is encoding CTCSS tones, you won't hear the traffic you're expecting.
Oct 28, 2013 | Icom IC-M36 VHF Marine Radio
What is a voic box on a cobra 29 ltd? What is a good antt combo four a 29 ltd?
Cobra's LTD 29 model Citizen's Band radio features the full 40 channels allowed and a heavy-duty microphone. The radio provides 4 watts of AM radio frequency output with a switchable automatic noise limiter and noise blanker. Other features include Cobra's Delta-Tune function. Making a Cobra LTD 29 hear and receive better involves making changes to the radio's settings, including the settings specific to this brand.
M/F Turn the switch labeled "NB/ANL, ANL, OFF" to the "ANL" position and try the transmission again if noise is affecting reception. "ANL" is an automatic noise limiter function and reduces noise caused by the vehicle's electrical systems and electronics.
M/F Switch to "NB/ANL" to activate the noise blanker, which may also reduce noise if you continue to have problems. It's an RF noise filtration function and will help with ignition noise.
M/F Adjust the "RF Gain" knob by turning it clockwise to increase gain in weak signal areas if you have problems hearing radio traffic.
M/F Set the "Delta-Tune" function to capture a more listenable signal and get rid of adjacent channel noise. Rotate the knob labeled "Deltatune" to the center position for best tuning. Try micro-adjustments to the left or right as well.
M/F Turn the volume up if you still can't hear and as with any CB radio, adjust the squelch if the radio is noisy when there's no traffic. Turn the knob labeled "Squelch" all the way to the left to receive all signals, including noise and turn the control clockwise until the background noise stops. You will be able to hear the strongest transmissions without having to listen to weak signals and noise.
The service manual can be found here
Jan 23, 2013 | Lands Phones
This is something new to me, what do I set all the buttons and knobs to talk on channel 19,hi-lo band,10khz on or off ,pa-fm-am,e/a-f/b-g/c-h/d, e-tone thanks for any help anyone can give me.
Radio On Volume comfortable Listening level Squelch Open (Hearing Noise) Mic Gain Up unless told by receiving station to reduce it. 10 Khz Off pa-fm-am set to Am e-Tone to off I believe this model has CB on Band C which is switch down on Low and C position you will know when you hear truckers on 19 which band is CB
Aug 06, 2010 | Galaxy Radios DX-44V 40-Channels Base CB...
Do the Uniden walkie talkie (UHO36SX) on listening mode (RX) normally give out a loud rushing noise? It would be impossible to have it on in a quiet place waiting for someone to talk.
No, the radios should be silent (squelched) when not receiving a transmission. Appliances (computers, televisions, even refrigerators) can generate enough "hash" to break the squelch and give you that "rushing" noise. Make sure that the radios are at least 4 or 5 feet apart, and try moving them to different locations to clear up the problem.
Bill B
Jun 01, 2010 | Radio Communications
Cannot receive faxes
Hi:
I quick way to really determine if the line could be a problem is try dialing your fax from another phone ,like a cell phone and just listen. What do you hear, noise, a recording, or do you hear the squelch tone that your fax machines should be putting out. If not then the line could still be the problem. Also if you recently switched to a DSL line then you should get a DSL filter and install it inline on your fax line. Also does your fax ring like it's trying to pick-up? If so, do you have the reception mode incorrectly set to TAD or manual mode.
Good Luck
Andrew
Mar 16, 2009 | Panasonic Panafax UF-585 Plain Paper Laser...
How to scan frequencies quietly
Yes...adjust the squelch control. This is usually a knob adjacent to your volume control. This should eliminate the static noise and you will only hear audio when someone is transmitting.
Nov 17, 2008 | Uniden BC72XLT Handheld Scanner
Little to no sound
There is a very tiny switch on the back of the set near the external speaker terminals. This switch has likely gotton put in the wrong postion.
Aug 02, 2007 | Toshiba 55HX70 55" Rear Projection...
Radio Communications Logo
1,800 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
