Question about Husqvarna Viking 1
Sewing machine can't seem to put the bobbin and casing back in the right way
    Problem Solver:
  • 6 Answers
I've had these machines - with students learning to sew - There are SEVERAL shuttle systems with this brand - if you have a two piece back case that the bobbin shuttle sits in -- these "STORIES" will work.
If not maybe post again - I'll see if I can help - the system is set BACKWARDS no matter the style of bobbin or where it is located on the machine.
You don't the opening location so I'll give you the stories for - front load below needle. The steps will also work with the topload - you just don't have to lie the machine down - if topload you should STAND BEHIND the machine to STACK the parts in as listed below.
If you are looking at the manual - you are looking at the entire process BACKWARD...Even with no manual it is a backward process.
Please don't laugh as you read through this - I taught young children - so this is how I have it memorized...I'm not attempting to "talk down" to you - these are my stories for 15 years with my kids.
Two ways to set this up - depends it you like to sit or stand....and on the size of your machine....and if you have to worry about belts/oil.....please pick what works for you.
- You can lie the machine in your lap or on to of a table - either way make sure it doesn't try to "escape" Sewing machines that get very slick and try to slip away from you.
- the machine thread spindles are facing you (where the thread goes) there are making every attempt to get close enough to poke your hip so you don't let them...(keep kis from breaking or bending spindles)
- handwheel (the circle) is on your left
- the bottom of the machine (the base is far away from you) because no one likes to see a bottom...
- pretend you are a CRANE operator placing parts of steel building parts near or on each other to make a building
- YOU wiill be starting with the swimming pool
- remember a crane operator NEVER sees the same building being built as the workers on the ground do - he sees everything in reverse and backward.
START THE CRANE!!
- first pick up the big flat base - put it into the hole to the right of the driver - up like a broken swimming pool - it faces up and on your right. HOLD ON HERE COMES ANOTHER PIECE.
- here comes the other half of the pool facing up the spike diving board is near the base - like a shark hiding (your model may have the HOOK (shark fin) towards your body
-don't let the pieces slip onto the top of each other like bricks because the ground is a little uneven- the pieces of the swimming pool might not set just perfect yet - that is okay - you might have to put one finger in the middle to help steady the load
- now set the ring in be careful there is a small part sticking out and you need to fill the extra space (the metal prong fits into the notch the
- line up the ring and fill in the small existing hole
- now frame the pool with the frame -be careful look at your
black FLIPPERS on each side - you may need to have the bumps up on the frame to hold the pool in place (the frame will fit one of two ways - bumps up or down - the "flippers" should sort of move over and it has a feel of a speed bump - then the pool is secure.
- ONLY AFTER THE FLIPPERS ARE SET is it "safe" to move the pool.
- If you did it wrong - the pool will fall out in your lap or on the table when you set the machine up. If your pool falls out - start again.
Her is a way that works for MANY KIDS - I JUST GET A HEADACHE:
Turn machine AWAY from you - lean over the top a replace parts in "opposite order to what the picture looks like. (I may miss a step I don't have an exact parts list in front of my face- so adjust as necessary
REMEMBER MACHINE IS TURNED AWAY FROM YOU (and I taught young kids - so please pardon my reference points....
- it goes - SANDWICH TIME - SANDWICH OF STEEL!
- case (SOLID HUNK OF BREAD( back of shuttle (more solid back - GOES IN FIRST open faced out away from your belly button ON RIGHT SIDE OF YOUR belly button )
- the HOOK half of shuttle it will be ON LEFT-hook on top sits to LEFT of your belly button (may face up towards your face or down to the table
- a little on top of other piece...hold BOTH PARTS IN - like you have a very fat piece of cheese and you are pushing on it so it won't tip off the bread)
- now take the round ring (may have a metal mini TOOTHPICK sticking up - guide the Toothpick into the spot between the "teeth" there is a "notch" sometimes on the bottom - sometimes on the top depends on model
- move the fingers OFF your cheese - let the ring take over the job (of holding two pieces into the sandwich)
- then like a well made sandwich put the BREAD on top of the entire sandwich. the "front plate - often a square frame that fits -
- bring up the BLACK BRIDGES (the two flippers olives) to NAIL the entire sandwich into the table) NOW LET GO. If it all falls out we didn't have our SANDWICH meat smooth enough. Try again.
Hope this helps.
Mrs. G. :) (sorry for any typos - I'm up working way TOO EARLY or WAY TOO LATE!)
Posted on Feb 18, 2008
I have a singer 7468. THE BOBB IN CASE KEEPS POPPING OUT. CAN THIS BE FIX?
the sewing machine may need a new bobbin case,, but I would
suggest take the sewing machine to a repair shop to see if there
is something wrong with the hook & hook race,,that may be why
the bobbin case is coming out.
Oct 06, 2012 | Singer 7468 Mechanical Sewing Machine
The needle tension seems too loose while the bobbin tension is way too tight. I am attempting to free-machine quilt so the feed dogs are down but the sewing seems very jerky. The machine also seems to...
Undo the screw on the bobbin case anti clockwise about a quarter of a turn and test and repeat if necessary until you get it right, put the top tension on 4 or 5 first.
Aug 24, 2011 | Kenmore Drop-In Bobbin 16231 Mechanical...
How do you load the bobbin properly?
Well you may please follow the steps below -
1. Remove the bobbin from the sewing machine. Note: whether you have a drop-in, front or side-loading bobbin on your sewing machine. A drop in bobbin will load from the top, may be via a removable bobbin case cover near the machine-fed dogs. A side or front loading bobbin needs to be loaded into a removable bobbin case under the machine.
2. Choose the right size bobbin for the sewing machine.
3. Wind thread onto your bobbin. Your sewing machine should have a standard thread spool to hold the thread and a short, squat post wide enough for a bobbin.
4. Put the thread and empty bobbin into position on your sewing machine. Wrap the thread around the bobbin to start it. On most machines, disengage the needle by turning the smaller hand-wheel on the machine toward you. Push the bobbin post into position, securing the bobbin into place. Press gently down. Thread should begin to wind neatly onto your bobbin.
5. Break the thread, push the bobbin post back into an inactive position and remove the bobbin. Tighten the hand-wheel. Thread your sewing machine again if necessary before loading the bobbin.
6. Remove the bobbin case cover and put the bobbin into position. The thread should slide through a catch on the bobbin case and up through the cover.
7. Access the bobbin case for a front or side mount bobbin. Lift the catch and remove the removable bobbin holder. Put the bobbin into the holder and run the thread through the holder, bringing it to the front. Lift the catch and slide the bobbin holder back into the case. Hold your needle thread gently forward with your left hand and turn the hand-wheel. The needle thread will pass down into the machine and catch a loop of the bobbin thread. Pull this loop up and slide both threads to the back before beginning to sew.
Good Luck!!
Thanks for using FixYa!!
Sep 22, 2010 | Euro-Pro Shark 60 - 384
I took out parts of bobbin to clean and when put them back the needle hits the metal of the bobbin case and i cant sew. it doesnt seem to be properly aligned.
Perhaps remove the bobbin case and check that you have put it back correctly. Check with the sewing machine manual to see how it is done correctly. Make sure that the top of the bobbin case is at the top of the bobbin case holder and make sure you change the needle as it will probably be dull or bent from hitting the metal of the bobbin case.
Aug 27, 2010 | Bernina Activa 130
I have a CE-4000 model. In the middle of sewing,
When you put back in the bobbin case, there is a little "knub" that sticks out with a flat spot on the right (on the top side of it) that you need to ensure it rests gently to the left of the position finger bracket (silver metal piece, in the square of the bobbin case area its on the right closest to you).
When you put in initially, it was probably twisted clockwise and there was a gap between the knub and the position finger bracket and when you put the needle plate on in jams that bobbin case in that position and the needle just takes chunks out of it..
You might need a new bobbin case, try sanding out the needle marks with sandpaper.
-Chirs
Jun 04, 2010 | Brother CS-100-T Computerized Sewing...
Re-curring loose bobbin case
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Apr 24, 2010 | Singer 7442 Mechanical Sewing Machine
Can't put the plastic bobbin holder back into position
make sure the needle is all the way up and the bobbin is in the case the right way. check to be sure there is no lint or dirt impeding the case. you may have to take out the piece the case fits into to do this. i have found this to be the problem more times than not.
May 11, 2009 | Yamata FY700 Mechanical Sewing Machine
Wrong type of stitch/tension not working
Found a solution to my own problem.... hope this helps someone else. Make SURE the bobbin case is seated correctly! (follow the instructions carefully). Don't put the cover back on right away after you put the bobbin case in. First check and make sure it doesn't move when you turn the hand wheel.
Also, when threading the bobbin make sure the thread passes down through the tension adjusting spring of the bobbin case.
May 14, 2008 | Brother CS-6000
Sewing Machines Logo
257 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
