Keyboard doesnt work right, i press a key one time and it types 3 and some of the keys dont do anything or they will turn the caps lock on and off.
  • 22 Answers
Well, if it were just a few keys that do not work, I would say take it in to a Mac store and ask them to see if there are crumbs or dirt under them. They could take the keys off an clean under it and it would not cost you much, if anything. (Dirt under keys can cause that problem). However it seems to be more than that. You may need a new keyboard for the laptop..or it could have something to do with the circuitry in the computor itself (no liquid was dropped on it I hope!). Whatever, this is something that needs a certified Apple repair place..preferably a real company Apple Store. You can go to Apple.com and find one in your area.
Posted on May 06, 2010
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
I can`t get any upper case functions to work on hp 2011 keyboard what key do i press
1.Make sure the "Caps Lock" key is not on. Though this will be obvious to most people, if your keyboard is typing in only upper-case letters it can't hurt to check. Look at the "Caps Lock" indicator light on the top right corner of your HP keyboard. If the light is on, strike the "Caps Lock" key on the left side of your keyboard. This will turn the "Caps Lock" off, allowing you to type in lower case letters again.
2.Make sure the "SHIFT" keys on your HP keyboard are not stuck. Dust and dirt can build up on a keyboard over time, which can cause certain keys to stick. If either of your keyboard's "SHIFT" keys get stuck, your computer will type in only capital letters. Use a toothpick or cotton swab to remove the gunk from the key, which should help it return to its normal position.
3.Unplug your HP keyboard and then plug it back it. This will remove the device from your operating system and then automatically add it back in. This can have the same effect, essentially, as restarting your computer. If your keyboard was typing in capital letters due to an error being stored in your operating system's memory, that error will now be cleared and the HP keyboard will function as normal again.
4.Update your HP keyboard driver. Click "Start" and then right click on "Computer." Click "Properties" and then "Device Manager." Right click on the listing for your keyboard and then click "Update Driver." This will update the computer software that is associated with your HP keyboard. If your keyboard was typing in all capital letters as a result of an error with this driver, the error will now be fixed and you can use your keyboard normally again
Mar 01, 2011 | HP D8597A Keyboard
Caps lock key not working - held down the key for
Press shift key for at least five times and then release when you hear a peep sound, On the Keyboard tab, uncheck everything and click Ok, if this doesn't solve, then again press five times and uncheck everything and click Ok. I also like to know if you were typing on some program like Ms-Word when the problem occurred. is the caps lock led on? Please let me know so that I can help you better.
May 06, 2010 | Microsoft Windows XP Home Edition Service...
I can not get lower case
Check for a light on the keyboard, caps lock could be on.
The caps lock key might be sticking press down on it a few times might loosen it a bit.
Jan 22, 2010 | Acer NSK8458AN Keyboard
Keyboard locks into all CAPS
Just a thought...one time I had a button that kept stiking itself with out me touching it...I removed the keys aroud it, only to find a tooth pick had found its way into my keyboard. Everytime I would hit any of the keys around it, it would also hit that button too. Dont know if this is your problem but worth a look!!
Sep 18, 2009 | HP D8597A Keyboard
MY KEYBOARD DOES NOT WORK WELL. FOR INSTANCE, I CAN NOT TYPE M WIthout holding the right side shift.
brand new Compaq 620 the keys stopped working. FIrst with 6,7, "_", then some other character keys also stopped working. Please let me know how to fix it.
Jun 20, 2009 | Computers & Internet
Caps lock won't turn off by pressing the caps lock key
Ok, here ya go.
Start-->Control Panel-->Clock, Language and Region,-->Change keyboards or other input methods
Once the window pops up...
Change Keyboards -->Advance key settings-->Now select "press the CAPS lock key" option
Hit apply and OK.
If this works, don't forget the "fixya" rating! Let me know okay?
Apr 03, 2009 | Computers & Internet
My typing goes uppercase without hitting the caps lock
I have the HP Pavilion and cap locks does the same thing.
THIS WORKS EVERY TIME. Hit both the right and left shift lock simultaneously about 5 to 10 times. It immediately disengages the cap locks. It is a little bit of a hassle, but I'm just used to it. It may happen 3 times per week, but I LOVE the machine, so I just fix it this way!
Oct 20, 2007 | HP Pavilion dv8000z Notebook
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
