Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Samsung tantus 1080i
Displays 3d like picture. but green is like a bowl feature looking in. Suspect resistors and projectors bad. how much to fix .. or should we just throw it out?
  • 5 more comments
  • Anonymous Feb 18, 2008
    Hey, Ihave the exact same problem. HELP!! I can't stand the 3-D I'm going crazy!!!!!!!!!!!!!!!!! Anyone with an answer??
  • Anonymous Feb 19, 2008
    Weird, I have the same tv and mine just started doing the same thing yesterday. No idea why.
  • Anonymous Mar 04, 2008
    Same issue, but with Red. I am just going to toss as it appears to be an issue that takes hundreds of dollars to fix unless you know what you are doing.
  • jules05 Jun 07, 2008
    Hi, i have a simular problem, the green has taken a shape of a bow-tie, using convergence does very little to help, i have a samsung tantus 56". Can anyone help or suggest how to fix, im fairly handy tech wise but graphics and guilde would help heaps including what parts and working materials required. thank you. Go the All Blacks.
  • Anonymous Jun 21, 2008
    t.v has 3d colors not al
    all 3D no HD Green is off tryed magic focus it stops when it gets to green.
  • georgekaytod Apr 11, 2009
    My samsung Tantus model no is SP-62J8HF K839-ser no-31CRA00010M The convergence RED has gone and gives a double veiw, my tv guy says it is the power board and a resistor is burned. Is it fixable and can I buy new components
I had the same problem and paid $300.00 cdn to fix...1 or 2 of your clolr cards are done...they usually last 3-5 years. Its worth the fix. Try adjusting the colors through the convergence setting.
Posted on May 21, 2008
Hi i have a 47" samsumg tantus tv and i haven problem with the screen. has some red lines
Posted on Mar 11, 2008
Yes i have a tantus samsung 40" tv and my problem is that the colours are out of alignment red green and blue so your almost watchonf 3d almost can this be rectified can it be fixed
If this is a tube set--and it sounds like it it--it likely needs convergence chips. IF the color and picture was ok before this happened--it is worth a look, but if it was getting dull and fuzzy, BEFORE the convergence problem--it needs tubes and is NOT worth repair.
May 07, 2014 | Televison & Video
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
How do i fix my samsung 1080i hdtv. It has a double picture and is red and blue, and also looks like a bow tie effect
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved pictures convergence problems.The shop,will cost u like $300-$350 for parts and labors.
Nov 21, 2010 | JVC AV-48WP74 48" Rear Projection...
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
3d picture and looks like bow tie
Bad STK ICs replace both ICs will have part number on them STK392-110s if this is what you have upgrade to 150s! ICs are Big black ICs also ck 2.7 ohm resistors near ics.
Sep 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung rear projection tv smells
I would first suspect bad connections and/or a defective convergence IC. The burning is the current limiting resistors getting hot. I would stop using the set and get it repaired. Replacing the convergence ICs should have a pars cost in the $40-$60 range. The few resistors that should also be changed should only add a few $$ to the cost. Add in the local labor rate for the total repair cost. Also, request that the ICs be changed rather than the whole convergence board. It will be less expensive and won't require a complete convergence adjustment. Dan
Jun 12, 2009 | Samsung Televison & Video
My picture on my samsung 42 inch 1080i is 3d
you have bad convergence chips or blown convergence resistors or fuses
Oct 21, 2008 | Televison & Video
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Dan
Jun 04, 2008 | Televison & Video
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
1,417 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
