Question about Canon PIXMA MP760 All-In-One InkJet Printer
Canon Pixma mp760 - won't power up or initialize
Printer/scanner etc always worked great altho I didn't use it too much... I always left it on and never had a problem... then one day I shut it off... next day when I went to use it I had trouble powering it up... when I unplug it and replug it it powers up but I keep getting this message:
"DATA ERROR: TO INITIALIZE THE MACHINE PRESS OK"
When I press OK it powers off and won't power up again unless I unplug it and replug it... does anyone know how to fix this? I don't live near a repair facility nor do I have the money to fix it... Canon was no help at all... Printer always worked great and I didn't abuse it or overwork it... HELP...
My Printer Canon PIXMA MP760 gives Error message Printer Head has Wrong Type Whithout any Changes. Is there any Reset of that message or do I have to bye a new HP-printer.
Posted on Jul 27, 2012
I found this on another forum it'll clear the EEPROM so give it a go.
MP750 / MP780 waste ink counter reset instructions..
1. Service menu: Menu -> Scan -> Copy -> Scan (one at a time in sequence)
2. Select "TEST MODE"
3. Select "[8] ETC.."
4. Select "[4] EEPROM CLEAR"
5. Select "[1] INK COUNT"
6. Press the [OK] button.
7. Press the [Stop/Reset] button (returns you to the TEST MOD sub-menu))
8. press the [ON/OFF] button (which resets the printer)
TIP: Don't rush the printer as it can often take considerable time to respond to your commands. Frantic button pressing will just push the printer into snail mode (ie: slow as heck!).
Patience :)
Hope that helps... :)
try that, i stole it off http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40 <http://www.stevesforums.com/forums/view_topic.php?id=87060&forum_id=40> -----
Posted on May 17, 2008
Tip
Canon Pixma Mp760 Drivers and dcuments for Windows and MAC OS
Here I will show you where to find drivers and manuals for the Canon Pixma Mp760 photo all in one printer.
Drivers for this printer are available for Windows 98, windows ME, windows Xp, Windows Vista, windows vista 64bit editions, windows 7 and windows 7 64bit editions.
On the Mac side drivers are available for Mac OS X 10.2/10.3/10.4/10.5/10.6
A full on screen manual, quick start guide and other instructions are also available.
To download these drivers and or documentation for your printer please visit
THIS PAGE
Note the picture reads MP730 but the actual linked page will be for your MP760
1. Click on Drivers & downloads
2. Select your OS ( Operating system, windows, mac etc )
3. All available drivers, documents etc will be available below.
For some of the documents a PDF reader may be required to open and read / print them.
To obtain a PDF reader, read this page
PDF Documents. Pdf reader(s)
Thank you for reading and I hope your printer is up and running again.
-Ekse
on Mar 11, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Paper won't feed from tray canon mp760
check in your front panel the button "Feed switch"
If you press the butto, the led change to show where the printer get the paper
If led up, you must place paper on Autosheed feeder
If led down, you must place paper on tray Cassete
If the error continue. check if they are Jam paper .
Is important for people who share their knowledge, know your comments. If the answer is helpful, rate my answers
Sep 27, 2011 | Canon PIXMA MP760 All-In-One InkJet...
Canon mp760 will not come. have power to it.
try a power flee.
Steps:
Unplug all the cables including the power cable
press and hold the Power (On/Off) button for 20 seconds. This will release all the static from inside. plug back the cables and then try.
May 07, 2010 | Canon PIXMA MP760 All-In-One InkJet...
Canon Pixma MP760 no error code
First you must remove the printhead and power on again, if it only has printhead error then printhead is the culprit. Otherwise you must press a key sequence to display the numerical error code and know what part of the printer is failing, purge unit, feed assy, or dirty encoder strip.
Please rate my response!! Thanks, SF
Jan 28, 2010 | Canon Office Equipment & Supplies
ANTS NEST IN SCANNER BED
Hello Mandb,
I also have ants in my PIXMA MP760 multifunction unit, I have just pulled it apart and reassembled it after removing several black broken bits relating to the hinges at the back of the scanner lid. The ants have seemed to have left home (wishful) but I would recomend you take to it with a phillips screwdriver, (carefully) or, if you don't want to do the surgery, take it out in to the sunshine and leave it there for about an hour, no longer.
Give it a bump every 10minutes or so, just to give the ants a help along.
If this dosent help, try coaxing them out with some ant food, but be there in person to stop them returning afta, a feed.
Failing this, take it to the repairman.
Do NOT spray bug spray into it, if the ants die in there, they will decompose, in the process it will corrode any fine copper tracks on the PCBs, it will only be fit for the dump then.
BTW, food colouring seems to be a cheeeep excellent ink replacement :)
Jun 11, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Canon Mp760 Error 2,178,0
unplug the scanner for a few seconds and plug it back in
Apr 28, 2007 | Canon PIXMA MP760 All-In-One InkJet...
Open Questions:
See all Canon PIXMA MP760 All-In-One InkJet Printer Questions
Canon PIXMA MP760 All-In-One InkJet Printer Logo
1,063 people viewed this question
old marine
old marine
