Question about Sony KP-57HW40 57" Rear Projection Television
What kind of bulbs does it take? - Sony KP-57HW40 57" Rear Projection Television
  • vollan27 Jan 31, 2010
    there is a white one and its not working
    i have actually 3 bulbs. the white one dont work
  • 2,335 Answers
This is a CRT rear projection model. It uses 3 CRTs. The part numbers will vary depending on whether your serial number starts 90XXXXXXX or 80XXXXXXX. Regardless, parts for these TV's are getting very difficult to source.
Posted on Jan 31, 2010
  • 8,197 Answers
HOW TO FIX HEAD LIGHTS
Are you sure you replaced the right bulbs you may have replaced the high beam bulbs unless you have the type of bulb that has both high and low in one what make and model do you have
Mar 05, 2016 | Cars & Trucks
Kitchenaid Superba KERC607 oven light bulb is out.
Try tightening it first clockwise just a little then undo it,sometimes you have to get a bit physical with these things! make sure the main switch/isolator is off,take out lamp,note type and replace.
Jan 10, 2014 | KitchenAid KERC607 Electric Kitchen Range
I need to replace a headlight bulb on a 2003 Tacoma on the drivers side. Is this an easy project or should I take it to the shop ?
Yes. It's an easy problem to fix. First, open the hood of your vehicle and look at the backside of the light you would like to replace. You can look at your owner's manual to find out the right kind of bulb you need or while look at the backside of the light, look at where the wires go in. All you have to do is turn the backside of the lightbulb holder clockwise or couterclockwise with a little pressure. Once doing that pull the bulb out by pushing in and turning one way or the other. The kind or bulb should be written on the light bulb itself or you can take the bulb to an auto parts store and for a couple of dollars they will pick the right bulb for you. I hope this helps. Scottn4444.
Feb 22, 2011 | 2003 Toyota Tacoma
How to change the light bulb in the tach and speed in a 2001 yzf 6r yamaha how do you get to the bulb what kind of bulb
i had to take the whole cluster out and pullout hard on the rubber booth, the the bulb pulls out...its flat plug insertion kind.
Sep 27, 2009 | 2000 Yamaha YZF-R6
How to replace the left head light bulb
I assume that you are talking about a 98 Explorer.
First you have to disconect the electrical connector in the rear of the bulb. It's kind of hard to get to because the battery and battery case are kind of in the way, but it can be done. You may need a small screwdriver to lift the tab up to release it.
Next you turn the retaining nut counterclockwise then pull the bulb out.
CAUTION! Do not touch the new bulb with your bare skin. You will leave an oil residue on the bulb causing it's life to be shorter. I use rubber gloves. Also be careful not to drop either bulb because they are under pressure.
Good luck and please rate my advice.
Thanks!
Jun 30, 2009 | 1998 Ford Explorer
Xenon bulb
Very rare for a xenon bulb to fail , check charger unit on headlamp , i would swop bulbs left to right first to check bulb , good luck kev
Apr 17, 2009 | 2003 Mazda Mazda6
How do you replace turn signal bulb on 2001 Izuzu Trooper?
NOT SURE IF IT IS TRUE ON THIS KIND OF VEHICLE, BUT USUALLY WHEN CHANGING A BULB YOU NEED TO GO UNDER THE HOOD ON WHATEVER SIDE YOU ARE CHANGING...AND THERE WILL BE A KIND OF PLUG INTO THE BACK OF THE ACTUAL LIGHT FIXTURE, IF YOU GIVE IT LIKE A QUARTER TURN IT WILL PULL OUT YOU THEN CHANGE THE BULB AND PROCEED WITH PLUGGING BACK IN. MAYBE THIS WILL HELP!
Jan 10, 2009 | 2002 Isuzu Axiom
Sony KP-57HW40 57" Rear Projection Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
