Question about Stoves Ovens
Newworld dfeo 90 main fan oven not heating - fan works! - which part most likely faulty
  • Stoves Master
  • 3,463 Answers
If it is an electrically heated fan oven, then I would suspect the oven element has failed, this is at the rear of the oven compartment behind a removeable cover.
If it is heated by gas, then I do not have an answer for you,as I have no knowledge of gas ovens.
Hope this helps.
Posted on Jan 30, 2010
My new world double oven fan makes a loud noise and now the large oven does not heat up
Newworld model 444447289 made a loud bang and doesn't come on. The top oven oven is ok. What could the problem be
Oct 11, 2013 | Ovens
My buttom oven is not working but top is working
If it is a fan assisted oven, and the fan is working, then it is likely to be a faulty heating element.
This should be located behind a removeable cover at the rear of the oven compartment.
If the fan is not working as well, then could be a faulty thermostat, even without the element or fan not working, there should be an indicator light on to show that the power is on,
Also make sure the main oven is set for manual operation, and not set on auto, as this will prevent the main oven coming on if it is.
Feb 12, 2011 | Tecnik TKC8522 Electric Double Oven
Neff single oven won't heat up. Replaced the main element and grill heats but when switched to fan oven the fan and light comes on but no heat?
If the fan is working o/k, then the element is faulty, or it is not getting power to it, you need to test with a meter for a supply to it.
Sep 23, 2010 | Neff Ovens
The main oven, fan assisted, blew the fan element. I replaced the element but the oven will not heat up. I have replaced the timer assy. & the thermostat assy. but it still will not heat up. When the...
You to check the element with a meter to ensure if you are getting a sapply to it, if you are, then the new element is faulty, if no supply, then probably ythe thermostat is faulty, also check for broken or bad conn ections.
Aug 14, 2010 | Hotpoint Ovens
Faulty main oven
If the fan is working in the oven, and it is electrically heated, then it will be a faulty oven element.
This is located at the rear of the oven behind a removeable cover.
Feb 10, 2010 | Zanussi Ovens
New world DFEO 70, fan oven not working but top oven is? Why? No power at all on fan oven & no time showing (not lit up)
oven timer seems to be stuck - oven only comes on for about min. and then cuts out to 'pinging'
how do we reset the timer to 000 ?
please
Jan 23, 2010 | New World Ovens
It would appear that the main oven element is not working. I had a power cut whilst using the oven recently and have only just realised that the oven will not heat up. Everything else is working ok. If it...
If it is a fan forced oven, the element is round in shape and goes around the fan blade on the back wall of oven.
To replace: Turn off power!!
-Remove side racks from oven, then remove rear panel.
-You should now see fan blade and fan element.
-You need to remove oven from cavity, then remove rear outer panel.
-You can now access element- it will be held in place by 2 small nuts either side of element wiring connections. Disconnect element wires, unscrew nuts. Element is now removed!
Reverse procedure to reassemble and test. If oven is heating OK, also check main oven thermostat is regulating temperature (ie clicks on and off), as sometimes thermostat can fail if element has blown
Aug 10, 2009 | Smeg Ovens
Fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Jul 28, 2009 | Ovens
Main oven not heating.
You need to replace a faulty main oven element.
This is done by removing the rear cover in the main oven,
there you will see the element, disconnect and replace.
It is not a difficult job , and is not too expensive.
Plz frate my solution.
THANKS.
Jan 06, 2009 | Zanussi Ovens
My oven turns off on me after only a minute never heating up fully
Could be caused by either of following;
1. Faulty thermostat.
2. Faulty thermal cut out switch. (controls power to cooling fan).
3. Faulty cooling fan (not fan inside oven).
Test thermostat by setting thermostat to low temperature like 60 oC. If oven gets much hotter then its a faulty thermostat.
To test cooling fan and thermal switch take oven out and remove top or rear panels to expose components.
When oven gets hot the cooling fan should turn on. If it doesn't then check to see if there is a mains voltage present.
If mains current exist but fan is not turning then replace fan. If mains voltage is not present then its the thermal switch.
Jun 19, 2008 | AEG B1180-4 Electric Single Oven
Ovens Logo
224 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
