Question about Canon PIXMA MX310 All-In-One Printer
Hi I have a Canon JX510P brand new! I am having problems with the settings! ie when the phone rings twice the fax works pefect, but when the call is a phone message the fax kicks in during the coversation. My son in law has tried several of the timed settings without success. Its a brilliant looking piece of equipment and very quiet during the sending and receiving of fax. I would like assistance if its possible to help with the correct settings? 1. fax to read then either print or switch off 2. Phone to ring and not be interupted with the fax? Many Thanks Brian Welch
  • Canon Master
  • 2,517 Answers
Please watch the link.
http://www.canon.ca/english/index-softwaredownload2.asp
or 1st make defult your canon settings and run . if you face problen then visit mentioned link. thx.
Posted on Jan 30, 2010
Where can I get a copy of the User Guide for a canon jx510p fax/answer m/c ?
You can download and print the instruction manual in PDF format by clicking these links:
User Guide
Setup Guide
Adobe PDF Reader is required to view the manuals. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manuals.
Thanks for using FixYa.
Mar 01, 2011 | Canon Office Equipment & Supplies
Have a Canon JX510P fax/phone. the phone line is working to the machine but i constantly get line in use message and cannot send or receive faxes.
Is there a software reset for this device? Consult your manual, and reset the printer to try and clear any software problems that coud be ocurring.
This could be a problem with the phone jack, so try the machine on another line, if possible. This will point to the machine or phone line in (noisy, etc.).
If the printer has a problem, you will have to take it apart to repair it. If you take it to a local computer repair shop or contact Canon Support, get an estimate first, since it can be high.
Here's Canon's Support site:
http://www.usa.canon.com/cusa/consumer/standard_display/support
Good luck, and hope this helps.
Feb 17, 2011 | Office Equipment & Supplies
How do you set up the telephone lines for sending a fax
hi, i have the canon jx510p and I cant seem how to change the settings on fax for distinct ring.. I have this fax system ina duet line
Please help
Apr 13, 2010 | Canon PIXMA MX310 All-In-One Printer
Setting jx200 to manual and have ansewring machine connected.
I normaly set all my fax machines on fax only,but I change my incomming ring count to more than 7 rings,but less than 11 rings,this allow you to have time to answer you call before it goes to fax.But you can set it for manual.
Press the "receive mode/resolution button untill it show on the display-manual,fax only or ansering.
Yes you can use the fax and answering machine when you are out of the office.
Set you answering machine to pick up after one ring,the message must not be longer than 15 sec.
If you leave set your receive mode to answering mode
Hope this will help you
Jan 08, 2009 | Canon FAX-JX200
Turn off fax ringer - turn on phone ringer Laserclass 2060P
Hi
You can set it for manual mode.
Or set it for fax only but set the incomming ring count to more than 8 times that will give you time to answer a call before it go to fax.
Jan 05, 2009 | Canon LaserClass 2060P Plain Paper Fax
Canon Fax Phone
It sounds like Tel/Fax mode is not set, but that the machine is likely in Fax Only mode. The JX200 has four modes of fax receipt - Fax/Tel, Manual, Answering Machine, and Fax Only. The Fax/Tel mode, which you have indicated is your desire, is meant to let the fax machine automatically switch between fax and voice calls. Documents are received automatically, and the machine rings for voice calls.
Set the mode by pressing [Receive Mode/Resolution]. Every time you press [Receive Mode/Resolution], the mode changes cyclically. If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings:
• Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting).
• Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting).
• Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting).
1. Press [Menu].
2. Use arrows to select <DATA REGISTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>.
3. Use arrows to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>.
4. Use arrows to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>.
5. Press [Start/Copy]. The LCD displays <8SEC.>
6. Use the numeric buttons, or arrows to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. (This is the time the machine spends checking for a fax signal before ringing for the call to be answered as a telephone call.)
7. Use the numeric buttons, or arrows to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>.
8. Use arrows to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6.
9. Press [Stop].
Setting ends and the fax returns to standby mode. The machine will now handle calls as indicated in the settings you input.
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 12, 2008 | Canon FAX-JX200
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Canon mx310 fax noise
This seems to be a problem more with cable digital phone lines.  I have the same issue... driving me nuts.  I will keep looking for a solution and post again if I find something.
Jan 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Brother 1270E won't receive faxes
make sure the phone line is plugged into the port marked "line" not "phone"
Jun 14, 2007 | Brother IntelliFAX 1270E Plain Paper Fax
Canon PIXMA MX310 All-In-One Printer Logo
445 people viewed this question
old marine
old marine
