My ext hdd maxtor basic 1 TB is not recognized by windows 7
    Scholar:
  • 94 Answers
You can follow the instruction on the following link:
http://seagate.custkb.com/seagate/crm/selfservice/search.jsp?DocId=211931&NewLang=en
Posted on Jan 30, 2010
My Computer doesn't recognize my simpletech 2TB ext HDD
check USB connection i think you have 2.0 usb connector and 2 TB HDD required 3.0 USB port so check it first
Sep 28, 2011 | Computers & Internet
My hard drive is recognized in bios but windows will not format for windows 7 install
You have to have the current drivers loaded on the motherboard for the HDD to be able to load your operating system.
Jul 16, 2011 | Seagate Barracuda St31000524as 1 Tb...
How can I install the driver for My Passport WD External HDD 500GB online?
It is a "plug-and-play" device, and Windows XP/Vista/7 are "plug-and-play-aware" systems.
So, just connect it, and Windows should recognize it.
Are you getting any error-messages?
What is happening?
What is not happening?
Nov 11, 2010 | Western Digital My Passport Essential SE...
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
UPGRADE DRIVER FOR MAXTOR 3100 EXT HARD DRIVE
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 17, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have a Maxtor Personal Storage 80GB and my Windows 7 does not recognize it.
is this device being hooked up exactly the same way as your last OS , make sure you have both cables hooked up , make sure your
device is spinning up to the max RPM , if max RPM is not reached
the HDD will not work on any system , also if your windows 7 is
a 64bit version the utility disk that was provided will not work
from the old 32bit windows OS even if you were using windows
XP 64bit , go to Maxtor online inquire about 64bit windows 7 drivers
for that device .
Jan 14, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor One Touch 4 is beeping when I connect it by usb
Does the HDD spinup?
My slightly educated guess... the Ext 2.5in HDD requires more power than it is getting from the single port.
1. Try another port
2. Try it on another computer (all USB ports do not provide 250ma to a load)You may be sharing this avail voltage with all plugged in devices and will have to pull 1-2 others to get the HDD online. Since STARTUP current is high, the HDD pulls all it can from the ports (logical) then settles down and uses 1/3 to keep spinning. After the HDD is up and online, try plugging the other USB devices back in, 1 at a time. If it stalls the HDD - you know the why
3. Take it back and find something a bit less power-hungry (Like Hitichi or Toshiba)
Jan 16, 2009 | Maxtor OneTouch 4 Mini 120GB External USB...
Windows XP stopped recongizing eGo external Hard Drive I just installed a new iomega eGo 1 TB desktop Hard Drive yesterday, got the bugs worked out and my Dell w Windows Xp seemed to recognize it, Today,...
2 things... the USB port is bad, or the USB cable is too long and the HDD isn't getting a good signal.
1. Try another port and see if that works
2. Nip over to WalMart, Circuit City, Micro Center, PC World or Best Buy and get a shorter, Thicker USB cable of the same type - a cable which can provide the signal strength your ext HDD requires.
Also a possibility... The HDD may be 'lost' as Win cannot accept one of that size or the label/signature fell off and it is an orphan. It MUST have a driveletter, and it MUST have a special WIN signature byte on the HDD for it to work.
Bootup as normal, let everything get quiet, then plug in the ext HDD
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass icon and wait. This forces your OS to 'Look' for any new devices.
When it finishes looking, look again under My Computer to see if your new HDD is now there. It will have to be formatted and have a driveletter for this part to work. Jump down to Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-) If it is not, use a shorter, thicker (more wires) USB cable and try again.
Windows doesn't like Any HDD without win signatures on them - aka:'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it, then Rt click it and give it a Diskletter.
Jan 15, 2009 | Computers & Internet
Maxtor One Touch External HDD not being recognized by PC
Try to use other running usb connector or check the HDD inside the external if is plug it will.
Nov 01, 2007 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
