Question about Philips 200S4SS (Silver) 20.1" LCD Monitor
Power problem with LG L204WT Flatron
Hello, friends!
This is the situation:
My monitor is about 2 years old. When I try to turn it on, no matter if it is connected to a computer or not, it just starts a very quiet electrical noise and thats it. But after it stays like this for 20 minutes for example, when i unplug the power cable and put it back again, it starts(used to start) normaly! And works fine till i turn it off, or it goes to "power save mode"... and then the same thing over again.(it works only when i start the power by the cable, not by the power button!)
But now its been two days, and that method doesn't work anymmore... i try to turn it on... starts a noise, but quieter than before, and nothing can make it work properly.
Any ideas ? I hope that's reparable :(
Thank you in Advance!
    Problem Solver:
  • 12 Answers
If your LG L204WT will not power up all of a sudden, or takes long to power up, or dies after a while and it has not been exposed to lightning damage then in all likelihood the Electrolytic capacitors in its power supply has started to fail.
Unplug the unit from mains. To open it up, remove the 4 philips screws at the back. Then starting at the bottom corner use a small flat screw driver to wedge the front bezel loose. After removing the bezel the rear casing will also come off the panel. The circuitry case is taped to the panel with silver tape. Loosen the tape, lift the power supply. Carefully unplug the two sets of backlight cables, and the front panel controls to completely remove the circuitry case. Now remove the 4 screws holding the power board and then replace the following capacitors:
You can order caps from most electronic component stores.
You will need to replace:
C105: Electrolytic Cap, 47uF 50V 105 degrees C
C106: Electrolytic Cap, 1uF 50V 105 degrees C
C202,C206: Electrolytic Cap, 680uF 25V 105 degrees C
C203,C204, C205: Electrolytic Cap, 1000uF 25V 105 degrees C
You can always use a HIGHER voltage and a slightly HIGHER uF, and HIGHER temp rating but never lower.
Make 100% sure to observe the polarity when replacing the caps. Electrolytic caps have a clear negative marking stripe on the side coinciding with a black mark on the board.
Posted on Mar 23, 2013
  • 732 Answers
Unique_m_m, Your LG l204WT has a possible bad "switch-mode-power-supply"/"CCFL inverter circuit" that will need to be repaired. The sound that you hear can only come from the circuits mentioned. The SMPS supplies dc voltage to the INVERTER supply and it changes it to a high voltage ac to light-up the "cold-cathode-fluorescent-lamps" (2) that are hung on the reverse side of the lcd panel you look at. You will need a tech type to investigate the units SMPS/inverter board for bad (swollen,leaky) electrolytic filter capacitors and "cold, frosty looking solder joints of the surface and through hole mounted electronic parts soldered to the circuit board. Here is cost to repair. DIY if handy with soldering pencil would be less than $20. Farm out the repair $35 to $65
More if new replacement board is required. I would certainly get on PHILLIPS case and yell and scream about their product's poor quality and short lifespan. Let us know if they give you the "bird"and a "you bought it you own it toyota" attitude. A service life of only two years is totally unacceptable! You could ask phillips if they have a refurbished unit swapout program?? Let us know what happens by doing additional comments to original posting. Bye for now. 12fixlouie
Posted on Jan 31, 2010
  • magicyoum Dec 21, 2010
    I had exactly the same problem. Changed 5 capacitors on the power supply board that were swollen, now the monitor work like a brand new! Cost about 5$ Thank you very much!
Blue light flashing but cant picture on screen
Your LCD screen is not recieving a signal from your computer. See my published guide, entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
In this situation you would want to make sure your screen is working by trying it on a friends computer or connecting your computer to a friends screen.
All the best!
damnor01
Dec 11, 2010 | LG Flatron L1951S-SN 19" LCD Flat Panel...
When it's on power off it make's a beeping sound, not one tone but it's fast. and when i am trying to turn the power on it wont start untill i pressed the power on/off button in 4-5 min. and yesterday the...
robin almen, If date code on rear is 2006, you will explor these options: 1 DIY refurbishment of units internal power supply printed circuit board. 2. See if LG (lucky Goldstar) has a cash+old unit swap-out program??? 3. Contract out the repair work. ($30 to $75) 4. Trade L204WT for new monitor. 5. Do some reading in the fixya profiles and follow the links you find there, to see if you might be able to do your own repair. Then visit YOUTUBE for repair video clips, searching using this: "lcd monitor disassembly" and "lcd monitor repair" Now it's up to you! What will you do? What will you do? Bye for now. 12fixlouie
Aug 27, 2010 | LG L204WT LCD Monitor
Lg Flatron L226wTQ, power button failing
This problem is usually caused by a failure in the power supply board which in turn is caused by a failure of the filter capacitors. We have a repair guide article posted on our web site at: http://www.ccl-la.com/blog/index.php/lg-l226wtq-bf-monitor-repair/ Check out the article and then open your monitor up and look for the failed capacitors, replace them if found and you should be back going again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
May 16, 2010 | LG 22" FLATRON LCD Monitor
My LG Flatron L1717S wen I power up it flashes good for 2 sec
are you getting a check signal cable message? any on screen instructions?
try the cable, if it works on another monitor, then sorry to say but your monitor is fried
Sep 01, 2009 | LG Flatron L1750S 17" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
LG Monitor Problem
What I did?
are you interested?
nothing is opened on my monitor,
it's just sort of reconfiguring with the tool i downloaded from LG website.
If you're interested email me at xerrose@yahoo.com OR
just buy a new monitor and throw the defective(you think).
Sep 01, 2008 | LG Flatron F700B 17" CRT Monitor
LG L1751S Flatron Screen
My sister's monitor wont turn on at all. She was shutting her system down due to a storm rolling in, and it said windows shutting down installing updates, while she is shutting it down. She turned it on today and the little light came on then it went off and hasn't been on since then. The Tower works fine but the monitor isnt turning on at all. What should she do? She has had the monitor at least 2 years no more then 2 1/2 years! And it is a LG Flatron 20". HELP
Apr 25, 2008 | LG Flatron L1751S-SN 17" Flat Panel LCD...
LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
Nov 27, 2007 | LG Flatron 995FT 19" CRT Monitor
Lg flatron l1510s
Try hooking the monitor up to another computer to see if the symptom remains the same if it does you might be needing a new monitor
Nov 01, 2007 | LG Flatron 775FT 17" CRT Monitor
Philips 200S4SS (Silver) 20.1" LCD Monitor Logo
1,190 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
