Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag dryer doesnt heat
My Maytag Electric Dryer does not heat up. I have checked all of the circuit breakers and they are good. The light comes on for a second when I release the door switch. I hear a click and the light goes off. Both worked fine friday and then not on saturday. Any ideas, i would be grateful. thanks
  • 1 more comment
  • kcman Apr 07, 2008
    My Maytag Electric Dryer does not heat up. I have checked all of the circuit breakers and they are good. The light comes on for a second when I release the door switch. I hear a click and the light goes off. It worked fine Saturday and seems to have stopped on Saturday night after a power outage. Any ideas, i would be grateful. thanks
  • Anonymous Dec 20, 2008
    heater doesnt come on
  • Linda Bramer-Holman May 11, 2010
    My Maytag Electric DE713 Dryer does not heat up. I have checked all of the circuit breakers and they are good. Replaced the Tumbler Sensor (looked worn) that did not solve the issue - no heat
    Novelist:
    Scholar:
  • 70 Answers
Maytag dryers have an electronic circuit at the base that controls the heaters. There is a fuse in that circuit that is very sensitive to power fluctuations or component failures. I have tried to replace the fuse (as an electrical engineer I think I'm qualified) only to have it blow out again. This is usually an indicator that there is something else wrong with the board. After looking at the schematic (wiring diagram) and the board. Figuring out what it does and what was said by others at other sites, I decided that the best solution was to have Maytag replace the board....
After taking out a second mortgage on the home to pay for it the machine worked fine. My advice...replace the board or buy another brand. We were able to buy another dryer and had money left over based on the cost of this board.
Sometimes it is just better to take your losses and replace the whole machine rather than go to the expense and time of a costly repair. This was one of those times for us.
Posted on Jun 22, 2008
Dryer won't heat maytag neptune mde 5500 ayw
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Sep 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
I own a Maytag Atlantic that is only blowing cold air no matter what cycle I set it in also when I open the door the light is not turning on, could this be related and what the causes may be?
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, If one is blown, the dryer may still operate but not heat. Alternatively, the dryer may heat, but it may not heat up as hot as it should. Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Rating the solution is highly appreciated.
Jul 03, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Will not get hot
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker. Make sure that the lint filter and exhaust duct is clean.
Another common cause of a dryer failing to heat is a faulty heating element. You will need to replace it.
Jun 30, 2010 | Maytag SDE3606A Electric Dryer
My Maytag Bravo Steam Dryer runs for about 5 minutes and gets hot and then kicks the breaker in the breaker box. HELP!!
Hello there:
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:It could be also wired backwardes so make sure to have this checked'
If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician. If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box.
May 21, 2010 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
No heat coming from dryer
Double check the circuit breaker for the dryer (Electric Neptune). Turn it off, then turn it back on. Its possible that the breaker may have tripped for some reason, but wasn't able to trip all the way.
Does the interior of the dryer get warm at all? You could have a 1 of multiple heating elements that has shorted. If no heat at all, the likely a heating element has opened up. Unplug dryer from wall (turn off circuit breaker first!). Use a ohm meter to measure and check continuity of the heating elements.
There may also be a sail switch in the air path of the dryer. The purpose of the sail switch is to keep the elements turned off until there is enough air blowing through the dryer. This helps prevent fires, as well as shrunken denim.
Jan 04, 2010 | Maytag Neptune MCE8000AY Electric Dryer
MAYTAG PYE2300AYW ELECTRIC DRYER running but no heating
you need to take it apart if you'd like call 417-926-0106 i'll walk you through it Jim
Feb 27, 2009 | Maytag PYE2300AY Electric Dryer
No power to maytag duet dryer...no light no power I have checked circuit breaker plugged/unplugged??
most maytag "performa" dryers with no power h appen froma blown thermal fuse. It is located under the top and beside the heating element. you can take an ohm meter to both terminals.If you do not get a reading, the part is bad. It comes as a kit with a new safety tstat
Feb 19, 2009 | Maytag PYE2300AY Electric Dryer
LD 8410 MAYTAG DRYER .... DRUM TURNS .... NO HEAT......HOW DO I TAKE OFF THE BACK
  • before taking it apart, if it is an electric dryer, then check the circuit breaker in the house. sometimes only one side of the dual breaker will trip leaving you with a running dryer with no heat.
  • maytag dryers are accessed from the front. look for 2 screws on the front panel near or at the bottom. these hold the front panel on.
  • let me know if you need more help
Jul 04, 2008 | Maytag Dryers
Maytag model sde305dayw
Check your fuses or breaker...If you have fuses, replace both 30 amp fuses. If you have breakers, flip breaker to OFF then back to ON, then try your dryer to see if it heats.
Mar 20, 2008 | Maytag HYE3657A Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
310 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
