Washing machine says door is open and stops
I have a Whirlpool 6100 Washing machine. It starts the cycle and stops and says door is open, when in fact it is locked. Any clues???
  • Anonymous Mar 23, 2014
    The hatch open and the machine is stuck
  • 767 Answers
I would make sure the door latch and door lock are both clean and free of debris as this will cause the machine to fault out from the latch not hitting the switch properly. If cleaning it thourghly doesn't do the trick you may need a new door latch/lock mechanism.
Posted on Jan 30, 2010
Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Nov 01, 2008 | Whirlpool AWM6100 Front Load Washer
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Why does my whirpool wwdc 7410 not start cycle?
you may have a bad door switch. I would check that the wires are still connected to the switch and that they are not broken or damaged.
May 12, 2014 | Washing Machines
I have a whirlpool sixth sense washing machine. the door open light constantly flashing although the door is well shut. No programmes work
We had the same issue: the cycle would start then stop, with the door open light coming on. It turned out to be a faulty contact in the door. Took a technician 15 minutes to fix.
Aug 04, 2011 | Whirlpool AWM8143 Front Load Washer
Changing brushes on whirlpool awm 8145/3. Washing machine stopped working and ''door open'' light keeps coming on and cycle stops. Cannot locate brushes to see if changing would help.
this door open light has nothing to do with the motor brushes its the door switch/s there are two of them try pushing your knee on the door if it starts working again change the switches and the brushes go into the motor?
Mar 10, 2010 | Whirlpool Washing Machines
Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
Washing machines door open light is on, but door is shut
Found it for myself - F7=motor fault. New motor brushes fixed it. This error code will come up if the motor fails to turn on demand at any point in a program, be it filling, in a wash cycle, or spinning.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
May 23, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool Washing Machine Quitting during rinse cycle
I would say that based on your problem description that the lid /door switch has a loose or faulty contact .. If you open and close it a few times..it starts to spin and yet when you open it.. it doesn't always stop the spinning.. It is either the switch or the actuator that bumps that switch.. That is where I would begin diagnosing the problem... Hope that helps..
Aug 30, 2008 | Washing Machines
Washing Machines Logo
60 people viewed this question
Top Washing Machines Experts
