Question about JVC HD-61Z575 61" Rear Projection HDTV-Ready Television
Audio failure..... I turned on the TV and the sound came on for a split second and then spike off like a short. It never came back!
  • 54 Answers
Maybe your tv ecounter audio has short circuit, or maybe your speaker became busted. Need a repairman to fix it.
Posted on Apr 21, 2008
Sanyo DP50741 50" Plasma TV - After a power failure audio no longer works on any input however video is fine. What is the likely issue/component?
Are you speaking of audio through the TV speakers or through your sound system? If through your TV speakers , I would go into menu and make sure speakers are set to ON or TV. Settings can sometimes be reset or changed due to spikes or surges. Recheck all settings to eliminate the obvious. If everything is fine then it's possible an electronic component such as an IC is blown. This would not be very expensive to fix. Hope this helps.
Oct 01, 2015 | Sanyo Televison & Video
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
Sanyo DP 42849 42'' lcd tv no audio no video
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 03, 2017 | Sanyo DP42849 42 in. HDTV
I want to plug in a game console but my tv will not show all the input options. Simply has "TV" Video" and Cable... It all runs through surround sound, so I'm wondering does the surround...
connect video and audio to tv - when it works, split audio to both units (tv and surround system), reason for it might be ground problems or sync failure
Feb 07, 2011 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have a new Sanyo TV with a build in DVD player. I have started having audio issues. I have not had the TV for a year yet and the audio has started spiking loudly out of now where for a couple of seconds...
Pl. check the variation of volume while you listen the sound,if no change than the problem is with the circuit,contact company service center.Also check by tapping on the speaker grill with your hand if the speakers are jammed than the sound will come intermittent,replace speakers.
Jan 15, 2011 | Sanyo Televison & Video
Monitor comes on for a split second , and then off
Most common failure in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed Dell monitors to get some ideas what goes wrong: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
Mar 31, 2010 | Dell E152FP 15" Flat Panel LCD Monitor
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Tv comes on and shutts off immediately
he was checking to see if the set stayed on with the ICs out if it did the ICs are shorted. Its easier to unplug the convergence yokes and try it but some techs do it differently
Apr 29, 2008 | Philips 43PP9202 43" Rear Projection...
Rca tv wont turn on after lightning storm
it is high voltage section failure
better call skilled tech to fix it.
Oct 15, 2007 | RCA F32450 32" TV
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
JVC HD-61Z575 61" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
