Question about Hotpoint RB525BC Electric Kitchen Range
Power lights come on burners do not, oven does work
All four burners do not work
  • mt8712 Feb 18, 2008
    Thanks that was totally it! Its fixed.
    President:
  • 1,314 Answers
Then check your voltage if you have 220 at the out let (and don't assume you do check it!) if you have 220 there pull the back cover off the cord and see if the cord is loose or burned . but before you pull the range out in this situation turn off the breaker for safety in case the cord has burned out all theese componts are on separate circuit's and only thing that will stop them all is a power problem of some kind if you dont find nothing turn the breaker back on and try the range again if the cord is burned this is caused by improper tightening of the cord during instalation and there is no fault in the range install new cord properly and it will be fine
Posted on Feb 18, 2008
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
My Maytag Gemini Gas Range works fine as far as the four burners, the bake on the top and bottom oven, but the broiler on the top oven does not work. Is this a pilot issue? I really appreciate the help,...
If the broiler burner is not coming on it may be a bad ignitor or the ignitor may not be getting power. Observe the ignitor when you turn in on ans see if it glows at all. If not then test for power to the ignitor if you have power and not glowing or lighting replace the ignitor. If it glows but does not light the ignitor may just be weak replace it.
Nov 02, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Kenmore model number 91193412000 burners went out
Its almost impossible to tell you how to repair it without being there to view what is going on. by what you are saying, it looks like you have a short between two or more wires, possibly stuck together from heat. After switching off, remove cover at the back and follow the wiring to the clock and the burner switches and look for anything obvious. Look for a wire possibly burned off and leaning onto another electrical wire.
Jul 19, 2010 | Kenmore 91112 / 91114 / 91117 Electric...
Viking range burners won't light
All of these ranges have a spark module at each burner sight and they all click when ever you attempt to light one burner. Therefore, it can not be assummed that the spark module for those nonworking burners are actually clicking. Remove the burner covers and actually look for the sparks. If there is no spark make sure the connections are nice and tight. IF they are, you most likely need to replace the spark module.
Apr 30, 2009 | Viking VGIC485-6G Gas Kitchen Range
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Gas Burner spark on other location
When you turn a burner to the light position, all burners should spark. If one is not, clean burner head area where the burner is not sparking. (dirty from boil overs)
Sep 02, 2008 | GE JGRP17 Gas Single Oven
GE Profile Spectra XL44 burners taking long time to light
Turn the power off to the oven.Gain access to the burners on the oven,at the end of the burner there are orfices.Slide the burners out and remove the orfices (they will have a hole in them) or get a paper clip and clean the holes out.Also where the ignitor sparks at on the burner,look at the burner holes and make sure there clean,let me know how you make out.
Nov 25, 2007 | Kitchen Ranges
Frigidaire Stove elements not working
First thing I would check is see if you are getting 220 volts to the stove.  Must be a constant 220.  Let me know what you find.
Oct 15, 2007 | Frigidaire FED300AS Electric Kitchen Range
Hotpoint RB525BC Electric Kitchen Range Logo
98 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
