Question about Microwave Ovens
Can i safely open my microwave to see why its not turning (pacific PDS2001)or is it best to get a new microwave. cheers bigslim .
  • Microwave Ovens Master
  • 3,740 Answers
Hi there and welcome to Fixya bigslim. Your turntable not turning is not a major repair and it most likely is the turntable motor that has failed. It is not an expensive repair if you can do it yourself. Most
If I have my model numbers sorted out this is a UK region microwave, probably 220V and rated at 800 watts. Correct me if I am wrong.
Before you get too deep into this make sure the splines have not stripped on the turntable drive arm assy. under the turntable. It should just lift off the spline. If that is ok then read on....
If your going to do your own repair attempt just be advised the only real danger inside of the unit with power off is the HIGH VOLTAGE CAPACITOR.
P O W E R O F F! (as in disconnected)
To gain access to the inside of your unit remove the 4 screws in the sides (2 ea per side) and 6 screws in the back of chassis cover. Then lift the back of the cover and pull it rearward while holding it 15 - 30 inclined. The interlocking side tabs will dis-engage easily form the fornt of the chassis and the cover will come free.
Locate the large capacitor.
While holding a screwdriver way up on the handle.... short across the 2 terminals at least 3 times so it does not ruin your day.
TURNTABLE MOTOR
You can do a resistance check on the turntable motor and it should read less than 20 Ohms. Sometimes the winding fails and reattaches itself somewhere else in the winding so this can be misleading.
The other test to do is with power on knowing full well that high voltage capacitor could ruin your day if you get to close to it. Set the meter to 250 VAC and check for power to the motor. If you have power when the unit is operating with at least a cup of water inside the cooking area the turntable motor has failed.
Most Appliance parts supplies will have a turtable motor. If you walk in with your turntable motor in hand you should walk out with the correct replacement.
Posted on Jan 30, 2010
I would like to Know the cubic capacity of the above ,and is it possible to change the light
Know the cubic capacity Mike, Pacific PMW2 microwave 700w / 17 liters capacity.
Mar 28, 2016 | Microwave Ovens
Why doesn't it turn on?
The internal fuse may have opened.
Sep 25, 2015 | Microwave Ovens
I heard a boom noise and discovered a crack in the back wall of my Tappan microwave oven. Is it still safe to use?
NO becaus the boom you heard was from a leak in the high voltage insulator of the magnetron or a MOV exploding from an electrical surg from the grid any way IT IS NOT SAFE TO USE the microwave oven... they are are so sheap replace it
Cheers!
Jan 18, 2011 | Tappan Microwave Ovens
Power just died on microwave
There is no real safe fix. When appliances like that go bad like that it would be best advice to just get a new one to be on the safe side. You can pull off the cover with 4 screws and look to see if anything has been fried. But again, being safe is number 1
Feb 07, 2009 | Sharp Microwave Ovens
Microwave: Box seam is separated - Is this dangerous?
Better safe than sorry.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
The unit made a pop noise and started smoking and smelled like burning rubber. Is the unit done?
I WOULD SAY SO! Most likely the power inverter board shorted out.
Sounds like perhaps someone put something with metal inside the unit without knowing and turned it on. Doing this tends to overheat the power inverter board causing a short in the system.
Be safe than sorry, replace the unit with a new one for around $100US. Lowes Home Improvement centers have some that are very inexpensive and are available in brushed stainless steel to match most kitchens.
Cheers,
Keith
Jan 02, 2009 | Sharp R-1492 Microwave Oven
Will not heat
The magnetron or one of the smaller components like a resistor(s) or capacitor(s) may be kaput.
Best to take it in for servicing by a qualified professional, as opening the microwave can be risky and hazardous to health, if you are inexperienced in these kind of matters.
Cheers
IrishDruid
Apr 28, 2008 | Emerson MW8107WA Microwave Oven
My Emerson MW8115FS 1450 Watts
hi your door has hooks which activate switches.one of the switches is called the monitor switch .the purpose of this switch is to close the mwave circuit[complete the circuit] indicating your mwave is safe for use.at present your mwave circuit is open therefore your functions arenot working .check if door hooks are making contact with the switch ,check if the swith is testing continuity.ihope ihave been of assistance let me know cheers
Feb 05, 2007 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
