Question about HP DeskJet F380 All-In-One Printer
After pausing a printing job, my printer has gone offline
After pausing a printing job and switching off, my printer has gone off line. I tried unpluging everything and tried to start printing but it is still showing it's off line I've been into the setting but am unable to rectify it.
Can you help please.
  • 748 Answers
Go to Printers & Faxes, open your printer (the window where you see the documents being printed), and from the upper menu leftmost item (Printer) uncheck the option "Work offline" or similar. Then try resuming or restarting print.
Posted on Jan 30, 2010
Printer won't work says it is paused
Check your settings , & unpause it !
Mar 17, 2015 | Office Equipment & Supplies
So far answers don't coincide with the directions I've been given, which is "Press the WSB Button for 5 seconds."
The print queue is what is locked up. Try deleting the items in the print queue.
Start by pausing the print queue. Then delete the items in the queue one by one.
When you have the last print job in the queue it will probably be jammed up in the transition between the computer and printer. Switch off the printer. This should cause the printer on the computer to become offline.
Try deleting this job abain. If it dissapears then turn the printer back on making sure the computer understands the printer is back online. Then try printing again.
If it does not dissapear then you will need to restart the computer to free up this job. When the computer is back up and running check the print queue again. If the job is gone then turn the printer back on and try printing again. If it is not gone then try once again to delete the print job and it should dissapear this time.
Once the job is gone and the print queue is empty turn the printer back on and make sure the computer understands it is back online again.
Oct 14, 2014 | Canon Office Equipment & Supplies
My printer refuses to print. The Red Status light came on so I checked and found there was a paper jam - cleared that. Can get green light to come on if I press the job cancel button but still cannot get...
Perform a Factory Reset
Turn the printer power switch OFF on the right side of the printer. Check that the front cover is closed.
Turn the printer power switch ON while holding down the GO button until the Toner, Drum, and Paper LEDs are lit.
Release the GO button. All LEDs will be off.
Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the Ready LED will be lit.
Print a Test Print Page
Print the Print Settings by pressing the GO button three times.
- If the Print Settings pages do not print, check for alarm lights on the printer. Clear the printer error before trying to print again.
- If the Print Settings pages print, the problem is isolated to printing from your computer. Verify the printer cable connects from the back of the computer directly to the printer. If the cable has become disconnected, loose, or connects through another device, the printer may not be able to print.
Check the Printer Driver Properties
Follow the instructions below based on the operating system installed on your computer.
Windows 7:
Click on the Windows icon => Control Panel => View Devices and Printers.
Right mouse click the Brother printer. Left click See What's Printing. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
Click Properties from this Printer menu list.
Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
Click the General tab and Print Test Page button. The Windows test page should now print.
- If the Windows test page prints, try printing from a program.
Windows Vista:
Click on the Windows icon => Control Panel => Printers or under Hardware and Sound click Printer.
Right mouse click the Brother printer. Select Run as administrator and left click Open. The print queue will open. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
Windows XP and 2000:
1. For Windows XP Professional, click on Start => Printers and Faxes.
For Windows XP Home Edition, click on Start => Control Panel =>Printers and other hardware => Printer and Faxes.
For Windows 2000, click Start => Settings => Printers.
2. Double-click the Brother printer to open the print queue. If print jobs are listed in the printer queue, click Printer (at the top of the window) and click Cancel All Documents to delete the pending print jobs. Click Yes to confirm deleting the print jobs.
3. Click Printer at the top of the window again. Make sure that Pause Printing and Use Printer Offline are not check marked. If either setting is marked, click on the check mark to remove it.
4. Click Properties from this Printer menu list.
5. Click the Ports tab. Verify the correct port is selected (LPT1 is using a parallel cable and USB is using a USB cable). Remember to click Apply if you select another port.
6. Click the General tab and Print Test Page button. The Windows test page should now print.
Nov 01, 2010 | Brother HL-5240 Laser Printer
Microphone not working- I have: updated the driver; run the troubleshoot options; gone into All Programs/audio and adjusted the main volume. It is Realtek. I have tried everything using Line In option...
The Print Diagnostic Utility diagnoses and resolves common printing problems and communication problems, including:
If you prefer, you can skip this information and go directly to downloading the tool .
  • Connectivity :
    • USB: Ensures that the USB connection from your computer to the HP product is working correctly.
    • Network: Ensures that the network connection between your computer and your network is working correctly. If the tool detects a network connectivity problem, you will be prompted to run the HP Network Diagnostic Utility for better results.
  • Spooler : Automatically restarts the print spooler, which sends print jobs from the computer to the product, if it has been stopped.
  • Online status : Checks if the product has been paused or set to offline, and then sets the status back to online if necessary.
  • Device manager : Checks for problems in Device Manager that would prevent printing.
  • Print queue : Checks for and clears pending print jobs in the print queue (a log of print jobs waiting to print).
  • Port : Checks the port settings for the HP product.
  • Driver : Checks for alternate-driver settings.
  • Conflicts : Checks for conflicts with other drivers, such as other printer brands.
  • Default printer : Checks the default printer setting and prompts to select the HP product as default (optional).
Oct 26, 2010 | HP Pavilion m7100y (PX189AV) PC Desktop
It is offline and will not print. Last print job
check the printer cable, try to change with other cable, or you can try to reinstall your printer driver.. hope these will help
May 04, 2010 | HP Deskjet F335 All-In-One InkJet Printer
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
I'm unable to delete a job from the queue. And therefore, I'm unable to print anything else. Any ideas of what to do? Thank you!
Open the print Queue, click the print job that is hanging and then from the menu, I believe under file, click pause. Once it is paused tried to delete the print job.
Sep 12, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp 5400 printer continuously shows as offline
If you are one a Mac, I may be able to help, as this happens to me. Sometimes when I send a print job, the printer shows as offline. HP recommends turning the printer off and then back on, but this did not always correct the problem. Go the the Printer Queue, click on the print job and then click on Pause Printer. Count to 10, then click on Resume. This fixes the problem for me and the printer then prints the job. I am running OS X 10.5.7. This same problem occurred using OSX 10.4.x
May 29, 2009 | HP Officejet Pro K5400n - - colour -...
HP Deskjet F380 All-in-one Won't print
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 15, 2008 | HP DeskJet F380 All-In-One Printer
I cannot print but i can scan
Solution:-
Click OK.
Click Start Jobs.
Click Start Jobs.
Jul 09, 2008 | HP DeskJet F380 All-In-One Printer
HP DeskJet F380 All-In-One Printer Logo
323 people viewed this question
Seeker5211
Seeker5211
