Question about Indesit WA 125 Front Load Washer
Getting a real loud noise when spinning - sound like the bearings may have aproblem. How do I check
  • 691 Answers
With the unit empty spin the drum by hand, you should feel the resistance of the drive belt and motor and hear the whine from the motor but nothing else, no grinding or lumpiness.
You can usually tell by excessive dirt at the back of the drum aswell right in the centre where the bearings are. If they are breaking up they tend to make a mess and break up the housing or shaft too
Posted on Jan 30, 2010
Whirlpool cabrio started making a loud noise when spinning. I've replaced the suspension springs before. Is that all I need to order? It's been a while.
Sounds like the bearings are toast. These machines have a poor seal in the tub which allows water to penetrate the bearings, drying/rusting them out. Go on "youtube" and search your problem. I use a 2"X4" and a jack on the center shaft to lift the drum out. Bearing tool and shaft/bearing, seal kit is approx. $150. Should take you approx. 4 hrs. if you're handy.
Nov 28, 2016 | Whirlpool Washing Machines
When it goes into the spin cycle it makes a loud knocking noise like a gear or belt is bad. what can i do, it is only 1 1/2 years old.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle.If the bearing is getting out of its way then its faulty weak motor causing this.Check out both the bearing and the motor. You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 30, 2010 | Washing Machines
Extremely loud noise when spinning. Sounds like dry bearing
If you have loud noises on spin it is quite possibly bearings.
You may also find that the inner drum becomes loose and may contact and wear the outer drum..
Replacing the bearings and possibly the shaft going through them is quite a big job. Best left to an experienced tech..
Get quotes before getting the job done. Check new prices also...
Good luck....Nomess
Aug 03, 2010 | Washing Machines
When spinning making a loud noise
you can check the damage on axis bearing Bosch, exactly is behind close to the fan belt pulley. You have to replace it.
Jul 26, 2010 | LG WM-1480FHD Front Load Washer
When entering spin cycle, making a loud noise. I
Check your belt it may be lose. A lose belt will cause a squealing noise and the machine spin slower or take time to come up to full speed
Oct 09, 2009 | Fisher and Paykel GWL11 Top Load Washer
When spinning washer making an unusually loud sound. Sounds like a bearing. Can you confirm?
Does it make the noise when spinning the drum by hand? If so, chances are you're right, the bearing is shot. No way to confirm without taking it apart and isolating the shaft and bearing then checking for noise or play. Good luck.
Aug 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer noise
probably is the bearing will eventualy start leaking from seal
Mar 12, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Indesit WA 125 Front Load Washer Logo
263 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
