Question about Bosch Dishwashers
Dishwasher not draining at end of cycle - Bosch Dishwashers
    President:
  • 942 Answers
If the water doesn't drain from your dishwasher, check these: Drain line/air gap A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again. Pump Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support. Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them. Drain valve and/or solenoid Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water. Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing. Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it. Motor If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced. Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced. Timer Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
Posted on Jan 30, 2010
Machine won't pump out last water after cycle.
Does not drain the water at the end of cycle - Dishwasher ...
https://www.ifixit.com/.../Does+not+drain+the+water+at+the+end+o...
iFixitThe dishes seem clean, but the water from the last cycle remains in after it has stopped. ..... noticable cracking noise when the machine was triying to drain the water.... to purchase a timer unnecessarily and they usually won't take them back.
Checking a Drain and Circulating Pump in a Dishwasher ...? 4:17www.youtube.com/watch?v=oLPBlkIsB5sMar 26, 2010 - Uploaded by ApplianceHelpOnlineIf your dishwasher doesn't pump out or will not wash watch this video. ... GE Nautilus Dishwasher wont run - fills water and doesnt drain - motor ...How to repair a dishwasher, not draining - troubleshoot ...? 6:18www.youtube.com/watch?v=rO19zoOyNHAFeb 26, 2014 - Uploaded by AdamDIYHow to repair a dishwasher, not draining - troubleshoot Whirlpool ... awhile but now blade on grinder won't spin. what should be my next step? thnx ... from the bottom to access the water pump. but this was much simpler and it worked. thanks. ... If I manage todrain it now, I'll do what this video instructed :).
Oct 19, 2015 | Dishwashers
Why will my dishwasher Electrolux model #EIDW5905JS0A, not drain completely at the end of its cycle.
Good Morning Friend,
I understand your Electrolux dishwasher, model# EIDW5905JS, will not completely drain at the end of the cycle. It is not normal for water to remain in the bottom of the tub at the end of a cycle. If water remains in the bottom of the tub at the end of a cycle, the dishwasher may not be draining properly. Please follow these troubleshooting tips:
    1)If unit is hooked up to a garbage disposal, make sure the disposer is empty.
    2)If unit is hooked up to a new food waste disposer, check to see if the "knockout" plug located inside the disposal inlet has been removed.
    3)Check to see if drain hose is kinked.
    4)Make sure cycle is complete, not in a pause.
    I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
Jul 03, 2014 | Electrolux EIDW5905JS Dishwasher
Why does my dishwasher not drain completely at the end of its cycle.
    -Best Regards-
    WP
New dishwasher will not drain at the end of the cycle
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Jun 06, 2010 | Magic Chef 24 in. DC4000 Free-standing...
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
Dishwasher doesn't pump the water out at the end of the cycle.
clog in the unit . check the drain hose. disconnect the hose then drain machineinto bucket. then check the drain pump to see if the pump is pumping or clogged.
Mar 13, 2010 | Bosch Dishwashers
Water does not drain
Hi
You can :
Check for hose kinks or food plugging drain hose. Start at the drain port exit
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check timer for not letting the dishwasher pause. ( not all dishwashers )
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for further clarifications.
Thanks
Rylee
Jan 27, 2009 | Kenmore 17252 Free-standing Dishwasher
Dishwashers Logo
435 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
