Question about Dell E173FP 17" LCD Monitor
Where can I get a replacement power inverter card for Dell E173FP
Monitor won't power on
    Problem Solver:
  • 6 Answers
Read this it's on how to fix the board
http://www.ccl-la.com/LCDrepair2.htm
Posted on Feb 02, 2010
Monitor cuts out after a few minutes
Sounds to me like a power inverter. Fix it yourself with the parts found on Ebay at a cheap cost to yourself. The entire Dell E173FP 17" power inverter is selling for $29.99 plus shipping.
The fix can be found at: http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Cheers and good luck!!
Nov 05, 2010 | Dell E173FP 17" LCD Monitor
Dell E173FP 17 monitor went dark and not working. I restart the pc it shows for only few second and went out again. I plug in one other monitor in my pc and it work fairly well. So something not right with...
Hi!
There are three possible cause why your monitor went black and start working..
1. If your monitor is dead set.. no reaction or lights turn on after power on.. then it needs to check if there is blown capacitor in its power supply section..
2. The high voltage ballast transformer of the backlight inverter is burned - it needs to be replaced so that it will not have a direct effect on the power supply section of the monitor.
3. The backlight inverters are all busted - the backlight was located at the upper and lower back edge of the monitor.. If these lights are busted then all that will be seen in your monitor is black screen.. It will need to be replaced so that image display will come out from your screen..
These 3 reason and its solutions can only be done by yourself if you have the knowledge, proper skills and the right tools to open the back cover of the monitor and replace the problem parts....
Otherwise, bring your monitor to a credible technician and if there is warranty,, avail of this...
Hope that answer your question..
Much appreciated if you rate this help..thanks..
May 20, 2010 | Dell E173FP 17" LCD Monitor
Monitor power button is blinking and monitor is black
Common problem with Dell are shorted out transistors in the inverter circuits, bad solder joints. See : http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Replacement board: http://www.lcdrepair.us
Post back what you find so it will help out other people also.
Apr 05, 2010 | Dell E173FP 17" LCD Monitor
When I connect the power to the monitor Dell E173FP 17, power bottom commence to turn on and off repeatedly...
Power LED is turning on and off because the power supply is in shutdown-restart mode becuase it sensing over current draw, it can be bad caps in power supply, shorted tramsistors (c5707) in the inverter circuits. See pictures: http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Check the fuse and the transistor out (check Emitter and Collector pin for short circuits)
Mar 04, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
I have a problem with a Dell e173fp monitor. On power up, the power LED goes green and screen flashes on once very dimmly, then goes black.
Look for shorted out transistors (4) (c5706/5707) in the inverter circuits, this is common problem, post back what you see so we can guide you further.
Jan 31, 2010 | Dell E173FP 17" LCD Flat Panel Monitor
Dell e173fp monitorno power at all
If the pwoer indicator is blinking on the Dell monitor, you have shorted out transistors (C5706/5707) in the inverter circuits, also look out for bad capactiors.
Dec 17, 2009 | Dell E173FP 17" LCD Monitor
No Power
Hi...there,
No, power.. Could one things, your backlight inverter are burnt out. Need to replaced a new inverter or repaired it.
Oct 11, 2008 | Dell E173FP 17" LCD Monitor
Has power but no display
Do the flashlight test. Shine flashlight on front of screen at angle and see if you can see an image or lettering. If so, it is probably inverter board. Let me know first if you have an image.
Jan 29, 2008 | Dell E173FP 17" LCD Monitor
Dell E173FP temperature sensitive 17" monitor
No. The best way is to take off the rear panel and insulator cover. Look on the board for "p/n: xxxxxxx" for the exact part number. I've found this to be the best way to ensure the correct board.
Also, once you're inside, you could see how many CCFLs you have.
Nov 06, 2007 | Dell E173FP 17" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
202 people viewed this question
Alun Cox
