Question about Kelvinator Dishwashers
Kelvinator KD12DW2 Dishwasher Machine on switch-on displays Error 4 and starts pumping water out till empty. Machine remains frozen in this mode.
  • ehlersjl Jan 30, 2010
    I followed njvinod's advice and even without allowing a dry-out time, after draining the machine is 100% OK. Thank you very much.
    President:
  • 1,462 Answers
The ERROR 4 indicates that the machine is flodded...
Sounds like the base of the appliance has flooded,Unplug the appliance and drag it out.
Tip it rearward about 45 degrees, water will run out of the rear corners so a couple of towels would be handy.
Once drained, try the machine again.
You'll need to leave the machine switched off and allow it to fully dry out.
Once drained, the machine would work perfect and this should solve your issue
Please leave me comment, if you need further assistance
Rnj VinodKumar
Posted on Jan 30, 2010
  • Monique Nov 30, 2011
    Hi, my dishwasher does exactly the same thing. But after I drained the water out and left it to dry I switched it back on and after 2 min it does the same thing. What else could be the problem?
The machine shows E07 error upon entering the service menu.
Door latching or lock error
·Door not detected closed
·Check door is closed
·Check door catch and latch
·Check door lock wiring
Check door lock
Dec 11, 2015 | Blomberg Washing Machines
I have a adg7560/1. the cycle starts but ends after a few minutes. the light flashes four times
Run the dishwasher through a test mode
Test Mode
Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
Open the door and set the program to the first program. (Normally rinse).
Turn the power off.
Press and hold the start button and while holding turn the power on.
After a little while the start button will flash, release the button.
Press the start button once and close the dishwasher door.
The machine will now run through a diagnostic routine.
Should take about 20 mins.
The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the programme.
To exit diagnostics at any time just press and hold the start button till the programme is cancelled
Error codes
F1. Single flash. NTC Break. NTC open circuit/short circuit or ambient temperature less than 3 Celcius
F2. 2 Flashes. Water leakage. Floater switch LS6 in drip tray has switched.
F3. 3 Flashes. Heating system defect. Heater or relay on control board defect. Chack also cabling.
F4. 4 Flashes. Draining failure. Drain pump, control board OWI or water indicator defect.
F5. 5 Flashes. Sprayarm Blocked (not present on VBL version. On 1 digit display will show as F and flashing start led).
F6. 6 Flashes. Water valve (WV1) is switched on but flow meter (FM) senses no impulses (less than 10 impulses in 10 secs) and the water indicator (WI) is at a low level
Water Valve Closed. Water inlet hose blocked.
Water inlet valve (WV1) defective. Flow meter (FM) defective (leads to FM failure)
F7. 7 Flashes. Flow meter failure. Flow meter defect. Water inlet valve defect or water inlet hose blocked.
F8. 8 Flashes. Water level failure. Sieve strongly dirty or big amount of foam inside to less water.
F9. 9 Flashes. Continuously Water Inlet. Water inlet valve mechanically not closed or control board defect.
FA. 11 Flashes. OWI failure. Dirty OWI lens. OWI defect or control board defect. Check cabling.
FB. 12 Flashes. Motorised Diverter Valve
FC. 13 Flashes. Water Hardness Sensor Failure
A fault with no fault code indication = faulty module
Read more: http://www.diynot.com/forums/viewtopic.php?t=200838#ixzz2zKhYFHxt
Apr 19, 2014 | Whirlpool Dishwashers
Asko advisory center
Try these... -Clean out the drain pump inside and below.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
make sure it is not clogged follow the line from under the sink and disonnect it from under the sink and make sure it is clear
- If all else checks out, replace the pump.
The Duet hides the pump/filter access behind the lower panel. Most LG, Miele and ASKO washers have it right up front for easy access. I guess keeping such a base element out of view helps sales.
Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump
Mar 07, 2018 | Asko D1776 Stainless Steel Built-in...
I've got a Kelvinator dishwasher KD12MM bought second hand, the machine goes on but does not pump water. Please help
Possible that the pump has clogged or is jammed with dirt. you will need to remove the pump and clean the pump assembly for a good spray pressure. If this wont work then the pump is faulty and needs to be replaced.Check this link for tips:
http://www.espares.co.uk/advice/dishwashers/a/3
Mar 12, 2012 | Kelvinator Dishwashers
Whirlpool dishwasher adg 642 not working start light flashhin 4 times
Hello Faye,
The F4 error code is a drainage error and it means that the control board did not detect a drop in the water level in the tub so it thinks it didnt drain.
The things that could cause this are a clooged filter on the pump asm, a blockage in the drain pump or hose or even a defective control board if in fact all the water has seemed to drain out of the tub.This is how ya set the diagnostic test to clear the codes and see if it reoccurs
  • Make sure the appliance is empty of water before running Diagnostics as it does not pump out before starting to fill and therefore you could overfill the appliance.
  • Open the door and set the program to the first program. (Normally rinse).
  • Turn the power off.
  • Press and hold the start button and while holding turn the power on.
  • After a little while the start button will flash, release the button.
  • Press the start button once and close the dishwasher door.
  • The machine will now run through a diagnostic routine.
  • Diagnostic takes about 20 mins.
  • The machine will stop during diagnostics if an error is found and will display the error code. If no error is found it will complete the diagnostics and end the program.
  • To exit diagnostics at any time just press and hold the start button till the program is cancelled.
    GENE
  • Nov 05, 2011 | Whirlpool 24 in. ADG7540 Built-in...
    A KD12DSS-2 KELVINATOR DISHWASHER WITH FAULTY ERROR 4 CODE
    Hi.
    Error 4 is internal leakage (overflow).
    when this happens often the dishwasher starts with the pump running continuously.
    Switch off the power from main circuit breaker, drain the inside of the appliance and clean the drain filter in the bottom panel of the tub. If problem persists, check the drain hose at the back. Ensure that it is not kinked, and that height is as from installation manual.
    If that does not work, then the machine is faulty. Repair is done removing the kickplate at the base of the appliance, checking for water leak in there. Disconnecting pump hose and removing debris, testing the overflow switch by running a cycle with its contacts jumped. The inlet valve must also be checked to ensure that it is not leaking.
    Turn off power and remove water from inside the appliance. Usually that is enough to sort out the problem.
    Regards.
    Ginko
    May 15, 2011 | Watches
    What doe error code CE signify????????..
    4. Troubleshooting
    4-2
    4-2. Service Inspection Mode
    - Press the Delay Start + Normal + Power keys at the same time for two seconds to enter Service Inspection Mode.
    - "ALL" is displayed for the first three (3) seconds and then "t1" is displayed.
    - You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 ? t2 ? t3 ? t4 ? t5 ? t6 ? t7 ? t8.
    - If you want to activate a mode while operating the dishwasher, the door must be closed (The Door switches are ON.)
    - If an "oE", "LE" or "tE1" error occur, make sure to enter Service Inspection Mode after resolving it.
    - Service Inspection Mode is described in the following table.
    Mode Related parts Symptoms Note
    t1
    Inlet Valve
    Flow Meter
    Low Level Sensor
    4E
    9E
    If you press the Delay Start key, water is drained for 45 seconds and then the water supply starts.
    If the pulse count is more than 660, change the mode.
    Make sure to change the mode when the pulse count is more than 660 in t1 mode.
    t2 Circulation Motor A nozzle does not inject
    water.
    1. Press the Delay Start key to start or stop the Circulation Motor.
    2. If a low water level is detected, water is supplied again and the operation continues.
    t3
    Circulation Motor
    Heater
    Thermistor
    HE
    1. Press the Delay Start key to start or stop the heater and the circulation Motor.
    2. If a low water level is sensed, water is supplied again and the operation continues.
    3. The current temperature is shown on the display.
    4. If the water temperature is more than 70?C, the Heater does not operate.
    t4 Fan Motor The Fan Motor does not
    operate. Press the Delay Start key to start or stop the Fan Motor.
    t5 Drain Pump
    Low Level Sensor 5E 1. Press the Delay Start key to start the 2 parts.
    2. When draining is finished, "t5" is blinking on the Display LED.
    t6 Low Level Sensor
    When the Micro Switch
    is turned on/off, there is
    no change on the display
    or a symbol other than
    On/OFF is displayed.
    1. MICRO SWITCH On
    ? The sensing state is displayed as 'On' on the 88 segment display.
    2. MICRO SWITCH Off
    ? The sensing state is displayed as 'OFF' on the 88 segment display.
    t7 Thermistor There is no change in the
    water temperature. The current temperature is displayed.
    t8
    Half Load Position of
    Distributor Motor
    Micro Switch
    (DMR77 Model)
    PE
    1. If you press the Delay Start key, the parts operate just once.
    2. There is no stop function.
    3. While the Distributor Motor is operating, its sensing state is displayed as On/OFF on the 88 segment display.
    4. When the Distributor Motor stops, the sensing state (On/OFF) of the Micro Switch is displayed.
    Caution
    If it has the power problem, you must check the FUSE first.
    This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.
    Try these steps to solve your error there is no CE code listed in the manual
    Dec 12, 2010 | Samsung DMR78AHS Builtin Dishwasher
    I am getting a CE error, what does that mean? Bill
    4. Troubleshooting
    4-2
    - You can change the mode by pressing the Normal key. Each time the Normal key is pressed, the mode changes in the order of t1 → t2 → t3 → t4 → t5 → t6 → t7 → t8.
    t1
    Inlet Valve
    Flow Meter
    Low Level Sensor
    4E
    9E
    water.
    t3
    Circulation Motor
    Heater
    Thermistor
    HE
    4. If the water temperature is more than 70ºC, the Heater does not operate.
    t5 Drain Pump
    t6 Low Level Sensor
    1. MICRO SWITCH On
    → The sensing state is displayed as 'On' on the 88 segment display.
    2. MICRO SWITCH Off
    → The sensing state is displayed as 'OFF' on the 88 segment display.
    t8
    Distributor Motor
    Micro Switch
    (DMR77 Model)
    PE
    Caution
    This dishwasher has the FUSE upon the Base. Refer to the 4-10 page.TRY THESE STEPS AND SEE WHAT HAPPENS THERE IS NO CE FAULT CODE LISTED IN THE MANUAL
    What is causing the drain pump to continue running
    C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
    Oct 30, 2009 | Dishwashers
    E1 error code on my kenwood dishwasher [kwd243a
    Hi
    The E1error code indicates a water inlet error.
    To access test mode: press and hold Normal+Eco, and press Power. Release buttons. Then press Start(display n:01).Press Start again (display shows water level frequency-not important). Press Start again-(display n:03-motor will be running). Press Start again (display n:04-drain pump will run). Press Start again (display n:05-inlet valve will come on and machine should fill with water). You have now tested major components are working-if you keep pressing start you will scroll thru and test other functions, like heater, dispensor etc, but not needed for your fault.
    If Machine didn't fill with water in test mode, you probably have a faulty inlet valve (test resistence should be approx 3.7-4 k ohm).
    If inlet valve has tested OK ie machine filled with water in test mode then:
    Disconnect from power.
    Remove side panels (need to remove top, and bottom front panel to then be able to remove sides)
    - Check no water in base of machine-water in base will indicate machine has leaked and activated the safety device which shuts off inlet valve.
    - If OK, you probably have a faulty flow meter(measures water intake). Located left hand side of machine, large plastic compartment, which has a sensor at the bottom with 3 wires (red,white,black) that go up to control board. Replace entire flow meter assy-relatively inexpensive part.
    - If you still have problem, then control board is faulty, it is much more likely to be flow meter .
    Thanks for contacting fixya.com
    Sep 10, 2009 | Dishwashers
    Dishwashers Logo
    143 people viewed this question
    Top Kelvinator Dishwashers Experts
    P Scarbs
    Level 1 Expert
    paul
    paul
    Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
