Question about Car Audio & Video
FITTING PARROT IN TOYOTA RAV 4 03 ORIGINAL RADIO CD PLAYER.DO I NEED ADAPTER WIRING NO ISO CONNECTORS
    President:
  • 1,564 Answers
All these connectors are available for purchase at any Sound (car)installation store. They will try to talk you into having one of their techs come out but that isn't necessary. Thank you, Dana
Posted on Feb 06, 2010
How to take the radio out and replace it with a cd player
hello,depending on your particular vehicle,as there are a few different ways to remove the radio fitted as standard,but most are usually removed from the dashboard with a 'radio removal' tool,a specially formed thin hooks that are inserted in to the left and right of the radio through tiny slot's,and pressed outwards to unclip the 'locking' mechanism that prevents unwanted removal.fitting a cd player is quite easy,as you can normally get a standard ISO adapter that will fit in to your car's original wiring plug,and then you just simply plug the other end in to your cd player,but you may have to specify to a local radio stockist of your specific vehicle and year of manufacture,as there are quite a few different adapters available,failing that,an auto electrician can usually fit a car radio in about 15 minutes,often without a wiring diagram,so can be quite cost effective to enlist the work to a specialist.hope that helps, cheers.
Oct 17, 2014 | Cars & Trucks
I have a renault espace 2.2dt, 1998. Can i fit a Parrot CK3100 Handsfree Kit Bluetooth kit? if so how?
yes you can , depending on what kind of stereo system is in the car, you will need an iso adapter lead that allows your parrot to be connected in between your car audio and power connectors and the car stereo,Similar to this
You need a SOT ISO lead you can check for an installation guide here
http://www.parrot.com/uk/support/installationdiagrams
Mar 23, 2011 | GPS
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
What kind of adapter to install cd player into 2000 malibu
what you will need is the radio adapter kit for your car make. also you need a wiring connector for the car between car wiring and radio. match the wires to wires on radio, and then the connector will fit car wiring connector, just plug it in to car wiring.
May 07, 2010 | Corvette Chevy Malibu 90-04 Car Radio...
How to install a parrot ck3200 without a adapter harness it is a non aplified radio
What type fo car do you have beacuse if you car does not have iso connectors you will need an SOT adaptor, this will allow the audio to come through the car speakers.
Feb 02, 2010 | Parrot Ck3200ls Lcd Color Display For...
Does anyone know which wire is the mute wire on a Toyota Rav 4 2003. Trying to fit a handsfree parrot into it. Thanks
I think there is no wire called mute wire. Mute can be applied only through the device.
Revert back for more assistance.
Jan 29, 2010 | Buck Toyota Rav4 2003 Stereo/radio...
Will this radio work in a 2005 Ford Focus hatchback
Yes but you will need a Quadlock to ISO harness adaptor and antenna adaptor and facia adaptor, roughly £30 of parts.
Nov 20, 2009 | Pioneer DEH-P5800MP CD Player
Just fitted parrot mki 9200 into a vito van and nothing happened how do you switch it on
You need to add a ignition wire, the vito uses the can bus to turn the radio on. The glove box light is on an ignition. also you may need to change over the perm live and the ignition wire on the parrot iso loom. you can do this at the fuses.
Aug 19, 2009 | Parrot Cell Phones
Up grade 1988 camry radio
Yes, you can.  This is a standard "DIN" opening.  Width and height are specified; but not depth.  The plastic empty space tray immediately below the radio - actually make this a "2 Din space"
If you are electrically savy - carefully remove the black trim bezel (two hidden fasteners in the middle section and a couple at the bottom; and a hidden white plastic tab buried way in the back at the bottom - need a long screwdriver to release - accessed only after removing the ash-tray...
I am not aware of any pre-existing wire harness adapter...
Electrically savy - get the above out -  and then measure the available depth.  You can get several molex connectors from Radio Shack, and cut the current wires - and put connectors on them - so that you can reconnect the original factory radio easily.  Unplug those, and make molex fittings going to the wiring for your new radio connecting to the molex you put on the factory wiring.
I'm currently looking at putting in a satellite navigation radio with screen, dvd player, etc. into my 1988 Camry which I've owned since new.  Only new car we ever bought....  Good luck.
Mar 28, 2009 | 1988 Toyota Camry
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
