Question about Motorola Mobility SLVR L7 Cellular Phone
Blue tooth yes need step by step directions on how to download songs from phone to phone using bluetooth can u help pleeeeeeease
  • elboy1818 Feb 18, 2008
    ddnt work i might have said wrong tpe of phone all i know its a Motorola and when u get into blue tooth it says find me i push that then i get lost thanks for trying
  • 72 Answers
You need first to activate the bluetooth on both phones, then the phone will search for devices, then if it finds one, connect to it, then choose the songs you like to send, then choose send via bluetooth, then if it ask for a pass key to connect, enter the same number on both phones, then the sending of file will resume.
Posted on Feb 18, 2008
I want to know from where i can download my laptop's bluetooth driver.my laptop is compaq presario c700
No need to install the blue tooth driver ,if your OS is XP/VISTA/WIN 7
I can give you an instruction,you can try it. Think you want to connect mobile phone through blue-tooth .
1. just enter your Bluetooth in your pc.
2. when the icon show your task menu bar just
3. double click on icon
4. add>check on my device >next(ensure phone Turn BT on )
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html
you can see the phone model which Bluetooth on.
just select the device >choice any ask code >I will advice you, please select, let me choice> type any 8 digit >next >now the same number > in your mobile >finish
For dial up go r click on my network>properties>create a new connection> connect to internet>next >set up manually>connect using dialup>select your mobile modem>next >type any name >type the exact name and number eg: for Airtel=*99#>next >no user name and password just next >check on add short cut>and finish.
Just double click on the icon, it will connect soon.
Or
you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Double click on phone icon >next>tic on Bluetooth connection >next >select yes the phone mobile>next
Remember always set the mobile for connection select the yes.
Hope it will help you.
Jan 08, 2011 | Computers & Internet
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I USE SONY ERICSSON MODEL P990I, THE SOFT SYSTEM NOT ACTIVE AND AGAIN USING THE BLUETOOTH TO GET INFORMATION, IT WILL GET TO THE MESSAGES IN BOX AND REFUSED TO BE INSTALL IN THE PHONE CARD OR PHONE MEMORY
If you Restore factory setting you can able to do blue tooth set .
Follow the steep ,there is no password need to set factory setteng.
go >setting>security>factory setting.
For blue-tooth set
It is a simply way, Ithink you should can if you follow my instruction. which device do You connectto .If the answer is cell phone ,follow the step.
1. just enter your Blue-tooth in your PC. 2. when the icon show your task menu bar just 3. double click on icon 4. add>check on my device >next(ensure phone Turn BTon ) 5.
http://www.acroname.com/garcia/tutorials/bluetooth/connection/connection.html Or you can download PDF file for details http://www.sena.com/support/downloads/#sd
just select the device >choice any ask code >I will advice you, pleaseselect, let me choice> type any 8 digit >next >now the same number> in your mobile >finish
For dial up go r click on my network>properties>create a newconnection> connect to internet>next >set up manually>connect usingdialup>select your mobile modem>next >type any name >type the exactname and number eg: for Airtel=*99#>next >no user name and password justnext >check on add short cut>and finish.
Or you can install PC suit and set it through the following step.
Setting> Setting >participate tic on yes .Doubleclick on phone icon >next>tic on Bluetooth connection >next >selectyes the phone mobile>next
Remember always set the mobile for connection select the yes. Hope it will helpyou.
Regards,
Shibuda
Jan 05, 2011 | Sony Ericsson P990i Cellular Phone
How to pair Motorolla 550
Please allow me to help you with you Blue tooth head set.
Step 1
First power on the headset you do this by sliding the call button towards the microphone.
After a few moments, the indicator meaning the "light" will be steadily lit in blue to indicate the headset is good to go in pairing mode.
Step 2
1. On your phone press the menu button then locate connection or device "phones are diffrent" at this point you need to turn on the blue tooth on your phone.
2. The phone should find the Motorola H550
3. Select OK or YES to pair you headset with your phone.
4. Enter the pass key: 0000
5. Press ok
Hint: Once the phone is paired with the headset the indicator will flash blue.
Now if the unit does not pair then you might be using another unit with this phone so please make sure you disconnect all blue tooth units and try the steps again.
If you have any questions WE can help please get back with me.
Thanks for using Fixya.com "We have a solutions for everything"
I hope this solution was VERY HELPFUL!
Have a Great day
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 29, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Plsits just that my phone's bluetooth refuse to work. It says 'unable to perform bluetooth operation'. Wat can i do to get this prob solved?
first reset the phone and try to connect again.
If it connects,you can use this step to,But if it doesn't connect that means the blue tooth is corrupted and will need to be flash to restore back blue tooth.
(You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone.
(hubpages.com/hub/How-to-Flash-your-cell-phone)
and
(unlocktotalk.com/UnlockCodeInstructions.htm.)
HOW TO CONNECT BLUE TOOTH,
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jun 28, 2010 | Nokia N73 Cellular Phone
How can i download a free ringtones from the computer using a blue tooth. when my cellphone is panasonicX700
First, you should have a program on your computer that you are giong to use for downloading music. You may install LimeWire for PCs or FrostWire for Mac.
Those programs will allow you to search and download songs. You have to save the downloaded songs into a folder.
Now, in order for you to transfer those songs from the computer to the phone via Bluetooth, your computer should be Bluetooth enabled also.
1. Turn on the Bluetooth on your phone.
2. Pair up the phone with the computer via Bluetooth.
3. The computer will recognized the phone.
4. Select the song, right-click on it and then select Send
5. Select via Bluetooth and select your phone.
It should transfer after doing those steps.
Good luck and have a great day!
May 16, 2009 | Cell Phones
I have a lg cu 920 how can i blue tooth songs from my phone
you have to be so close to a person to be able to send them something. if you hit search new device under your bluetooth menu it will show the people with their bluetooth on around you.
Jan 31, 2009 | LG Vu CU920 Cellular Phone
Blue tooth
1, Press Comm Manager button (Right side middle)
2. Press onscreen Settings...Bluetooth
3. Press onscreen "Add new device" I tend to do this even if I have previously added a device.
4. Searching begins, if device is found follow prompts to finish install.
Sep 18, 2008 | HTC PPC-6800 Smartphone
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
Blue tooth
first of all insert your fone's memory card into your bluetooth. And then plug that bluetooth in computer. It will open with the drive like other drives. Enter the songs and pics u like into the bluetooth. Unplug from computer and put your memory card into your mobile.
Sep 23, 2007 | Motorola Mobility L6 Cellular Phone
Motorola Mobility SLVR L7 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
