Question about Samsung CLX-3160 All-In-One Laser Printer
Blown Power supply Samsung CLX3160FN
Samsung CLX-3160FN, I have just purchased this printer from the states, but you guessed it plugges it in here!! Therefore I believe that I have Blown Power Supply put 240V instead of 110V. Purchased a converter, but went fot 45W one as this was cheapest, there is no Watt information on the printer. However this did not work. I have several clp 300 and 315 samsung laser printers, Is it easy to swap over the power supply from one of these printers, or do you know of any printer repairers that would convert/fix my printer.
  • 1 more comment
  • Chris Welsh Jan 30, 2010
    Thanks a lot. Hmm that means the power converter I have is not powerfull enough as its only 45W. I will try an electrical engineer with who may have a convertor powerfull enough. Would the power supply from a 3175 be the same. I can pick these up in the uk but have not seen another 3160. On another note The samsung 300 printer I have keeps cruching up the paper. The paper is being picked up ok, but crunches up at the back. Its not even getting into the fuser unit. I can see no blockages, And occansionally one does get through, so I know its nothing blocking the rollers etc. I can see nothing wrong with the back, and can even compare it to other cpl300 printers I have.
    Any Suggestions
  • Chris Welsh Feb 21, 2010
    OK - I have purchased a new power board (UK) this time.
    I installed it and the printer now works i.e powers up and I can Print scan etc. My problem now is that After about 2 mins I get a beeping and a message "Overheating recycle power" At which point I immediatly turn the printer off. There is also a strange smell coming from the printer I assume this is the fuser unit. Do I also need to replace this or is there some checks that I should carry out to try to fix the problem.
  • Chris Welsh Mar 08, 2010
    Hmm have just checked that, I have had unit switched off now for 2+weeks just powered on again to try to resolve issue? Now the Printer has different error message, LOW HEAT please cycle power. One minute its to hot and its to cold?
    Any ideas
  • 542 Answers
As per your description you have plugged the printer into 240V power supply instead of 110V as this printer is purchased from US due to which the blown the power supply.
Check the fuse and replace the same if required. Still you are facing the problem, then need to repair/replace the power supply unit for the printer with the help from expert enginner or Service center experts.
Revert back for more assistance.
Posted on Jan 31, 2010
  • Rajesh Pai
    Rajesh Pai Feb 04, 2010
    Sorry for the delay in replying...
    This may due to paper path roller is having the problem. Check/replace the same will resolve your problem.
    Revert back for more assistance. Alsp please provide your valuable feedback/rating on the same.
  • 748 Answers
FYI, laser printers can consume up to 1000W when operating. Your printer is rated at 350W average.
Actually, you might have blown more than just the power supply - many printers have the fuser unit operating directly from the mains voltage for example.
And no, it won't be easy to swap a power supply - your unit has many additional features compared to a typical printer, so the power supply will be different for sure.
An electronics technician should assess the damage and inform you whether a repair would be feasible.
Posted on Jan 30, 2010
Where can I purchase a waste toner tank for my CLX-3160FN Printer?
Simply go to Amazon!
Here's a direct link -- http://www.amazon.com/Samsung-Container-CLX-2160N-CLX-3160FN-CLP-W300A/dp/B000IFTR24/ref=dp_cp_ob_e_title_0
Mar 22, 2011 | Samsung CLX 3160fn All-In-One Printer
The glass on my samsung clx3160fn has fogged up on the inside how do I clean it
I don,t really know to well this model but with some patience and screw drivers start by take apart the top of the printer scanner.If you are lucky to do it you can access the bottom of the glass.
Dec 06, 2010 | Samsung CLX 3160fn All-In-One Printer
My smasung clx3160fn scanner locked
There is a green slider located where the paper exits the machine. It is mounted on the bottom of the scanner. Pull the slider towards the front of the machine to unlock the scanner.
Nov 23, 2010 | Samsung CLX 3160fn All-In-One Printer
Warming up please wait Samsung clx3160fn
This may be due to so many factors. Fuser unit, LSU. Main board. imaging unit consumables etc.
Please take it authorised service center only
Nov 20, 2009 | Samsung CLX 3160fn All-In-One Printer
Poor Printing Quality
The last time I saw that I had to replace the HV power supply and prints went back to normal...If it's out of warranty it'll cost around $150.00
Aug 31, 2009 | Samsung CLX 3160fn All-In-One Printer
CLX-3160FN black ink problem
This is the problem of black developer in the imaging unit. This may be replaced by Authorised service center.
Best Regards,
Aug 02, 2009 | Samsung CLX 3160fn All-In-One Printer
How do I replace the imaging unit in my clx3160fn? getting a warning to replace imaging unit soon. no instructions in the manual on how to do so. help?
The imaging unit is that whole assembly that the toners are plugged into inside the front door of your machine. It a consumable unit available at many office supply stores. The instructions to replace the unit are packed inside the box with the new unit.
Jun 23, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
May 27, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160FN "scanner locked"
Every Samsung multifunctional device has a scanner lock underneath the glass. This is to prevent scanner damage during shipment. Th user's manual in the CD and the unpacking sheet clearly illustrate where this lock is. If you open the top lid and look to the lower left corner of the glass, you will see a small lock-open/lock-closed symbol. Underneath that symbol you will find the lock. I'm including a small visual reference of a similar model. Just remember to turn off and on the unit after the lock is removed.
Sep 28, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX-3160 All-In-One Laser Printer Logo
241 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
