Question about Sony VPL-ES4 Projector
When you plug in power it indicates red but does not start the pr
Sony KP-53V25 when you plug in power it indicates red but does not start.i opened the lamp cover and checked the cover and switch it is OK.i checked the lamp with another projector and it is OK so what do you think??
  • 144 Answers
Circuit board fuse blown?
Posted on Jan 30, 2010
Sony kp-46v15 convergence problem dont know were to start on adjusting main convergence board in front were do i start there is 15 or so red green blue ajustments for horizontal and the same for vertical...
Do not mess with those, they don't just go out. they are also for skew linearity, heighth, width for vertical and horizontal adjustments. If your convergence went out need to find convergence circuit and look on the plugs for your vcc voltages going to the convergence circuit. If missing, trace back to power supply and look for an open low value resistor.
Apr 20, 2011 | Sony KP-46V35 TV
Sony KP-57WS510 red light blinking 5x
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 19, 2010 | Sony Televison & Video
Sony Projection Stand by indicator flashing red
Ur FBT,Fly Back Transformer high voltage is dead, the black block of plastic with a red wire with cap hook to a CRT(Tv Tube).
Sep 14, 2009 | Sony KP-46S25 TV
Sony KP-53V25 Color Rear Video Projector Powering off unexpected
possible crt problem, they have to be reseated, if not then the convergence is failing expect to pay around $300-350
Jul 26, 2009 | Televison & Video
Sony kdf60xs955
A 6 flash shutdown can indicate power supply problems or an open thermal fuse. To be sure, you should have a technician verify your problem.
Oct 19, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51WS500 will not turn on
I believe the problem is either in the G board ( power supply) or the D Board ( high voltage) as the 3 blinks indicate the G board, and 7 indicates the D board and 6 indicates the +5 line a and b boards. So with that many codes its most likely the G board (power supply) You can get a new replacement G board at the following link which comes with free tech support to help you plug the baord in which is very easy. Its listed under the Sony parts category and its the A-1316-566-A sony G board, Here is the link.
http://servicemanuals.vstore.ca/
Aug 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53S35 "pulsating" Power Problem?
Sounds like youre needing a new D board. If you would like a link to where you can get a new board let me know and I will post a link
Jun 14, 2008 | Sony KP-53S35 53" Rear Projection...
COLOR OUT OF ALIGNMENT ON LEFT SIDE OF TELEVISION
are you able to adjust the convergence in all 4 directions for both red and blue? If not the Convergence ICs are bad and need replacing. If you ned more info let me know.
Apr 08, 2008 | Televison & Video
Sony kp-61v35
Unless you can do tv repair your set has more wrong with it then something minor,it more then likely has a shorted Hori out put transistor NTE2973 and maybe open pico fuses.Take set to repair shop. ThankYou for using FixYa. Have a Nice Day.
Feb 08, 2008 | Televison & Video
Sony VPL-ES4 Projector Logo
378 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
