Question about Belling XOU252 Electric Single Oven
How do I set clock on Belling Synergie Multi-funtion oven (xou270)?
  • Sandi Burke
    Sandi Burke Dec 01, 2015
    Thanks! Mine was off by 12 hours and 5 minutes, really messing up my mornings!
  • 5 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To set the clock
hold the cook and stop buttons together at the same time then use the up and down arrows or+/- to set the time in 24 hour format
Posted on Mar 29, 2010
Belling synergie element not working
Hi the bake part in the top oven of my synergie, and how do i get it out? thanks.
Sep 05, 2010 | Belling XOU592 / XOU593 Electric Double...
Belling synergie oven grill comes on oven fan comes on all lights are working but no heat in the oven temp 200 setting on the oven symbol all plugs have been checked.
I suspect tha the oven element is faulty.
To access it, you will find it located at the rear of the oven compartment behind a removeable cover.
Hope this helps you.
Dec 13, 2009 | Belling Ovens
Fan oven option not functioning on main oven, its a Belling synergie multifunction oven, about 5 years old
On my Belling it was the oven multi function switch that was faulty. I replaced it - carefully (lots of coloured wires) and it works fine now. Hope this helps
Oct 24, 2009 | Belling XOU590 Electric Double Oven
Can't get my belling oven to work
Press & hold both the 'Cook Time' and 'Stop Time' buttons together and, while holding both of them down, press either the + or - button (this is the way to set the time of day). Release all buttons simultaneously. This should enable the cooking functions to operate.
Apr 18, 2009 | Belling XOU252 Electric Single Oven
How do I find the model number on belling synergie oven?
I have the same problem. I have inherited a Belling Synergie multifunction double oven. The Model No is worn out - yet there is a specification 492SS which isn't. I am going to purchase the element with this number and hope this works.
Mar 23, 2009 | Belling XOU174 Electric Single Oven
Belling synergie oven - main oven won't come on.
hi
check the timmer clock is not in auto mode as this will stop the oven from turning on. if clock ok then fault could poss be the thermostat
hope this helps you
regards dan
Mar 03, 2009 | Belling XOU174 Electric Single Oven
Replace Bottom Element in Belling XOU270
If this is a fan assisted oven, then there is no bottom element, only the fan element..
Remove the panel at the rear of the oven, there you will see the element, remove any screws that you can see and pull element towards you, disconnect the leads, don't loose them, and replace element.
If no screwws are visible then you will have to remove the oven from housing and do it all from the rear of the oven. Make sure power is off before you do anything.
Good luck.
Plz rate my solution.
Thanks.
Dec 15, 2008 | Belling XOU270 / XOU271 Electric Single...
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Belling Synergie
NEED NEW FAN OVEN ELEMENT THAT CAN BE FOUND HERE
You need Element code AB20 on link below
http://cookerandovenelement.co.uk/bellingfanovenelement.html
element is located on back wall of oven you need to pull oven oven to remove the element element is held by two nuts from back and i screw from front
Dec 22, 2006 | Belling XOU270 / XOU271 Electric Single...
Belling XOU252 Electric Single Oven Logo
1,552 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
