Question about Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher
How long is too long?
The dishwasher runs for three hours, regardless of which cycle it is in. Is this normal? I have never had a dishwasher that ran this long before.
  • 833 Answers
I doubt it. If the unit has a mechanical timer, it is binding. If the shaft cannot be cleaned up, it will have to be replaced. Typical times are 40 minutes to an hour, depending on the cycle.
Posted on Feb 18, 2008
Bosch SHX33A05UC/36 dishwasher seems to run for hours to do a load of dishes. Checked water temperature, drain and hose and all is clean. The rinse and hold cycle times out correctly. Is it a timer or...
No, the problem in not the unit, it is programed to run up to 3-3 1/2 hours for a single cycle. You can select quick wash to shorten this time down, but this is not a problem with the unit. It wants to assure you have clean dishes and hot enough water to complete the program.
In testing one a few days ago, I ran into this same problem, I reread the time charts and cycles and found this to be normal for this manufacture.
I hope this answered your question.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 13, 2011 | Dishwashers
Tip
THANKS!! instant bliss... in my model KUDS01FLSS6, I had to press Sani Rinse,...
The blinking "clean light" is a common problem with some of the Kenmore and Whirlpool models dishwashers. The problem is usually attributed to water supply temperatures being too low when filling. Apparently, there are some issues with the temperature sensing circuits in some dishwashers that causes an error code to be generated if a certain water temperature is not achieved in a specified time interval (this time may differ between models). There is a reset sequence that you can try to clear the fault. Push the NORMAL WASH then HEATED DRY buttons in that sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the CANCEL button. This will clear any existing faults and should return the dishwasher to normal operation.
To keep the fault from returning, it is recommended that you run your hot water faucet in the kitchen until it runs hot BEFORE you start the dishwasher. This will heat the water in the supply line for the dishwasher (most dishwashers are fed from the kitchen sink supply line). The theory is that if you fill the dishwasher with hot water from the start of the wash cycle instead of the cool water that is normally in the lines (especially if you have a hot water tank located far away from the kitchen), this should satisfy the requirements of the temperature sensing circuits. If the fault reappears, there should be a tech sheet located inside the lower panel under the door that explains what the fault is. The flashing light will be a series of flashes, followed by a pause. If you indeed have a component problem, it will depend on the number of flashing lights in the sequence. Refer to the tech sheet to determine WHAT component is affected and how to troubleshoot.
on Nov 01, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Tip
on Oct 21, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
We have a model MBD7601 washer that is not running normal cycles. For the regular washing, which normally takes 2 hours, it fills for 30 seconds, then drains the water and shuts down. It will run the 9...
Hello & Welcome to FixYa
The problem is with the float switch assembly that is bad and needs replacement. A float switch on a dishwasher is designed for one thing, to stop the water flow from the dishwashers water valve. To access the dishwasher float switch regardless of the make or model, 99% of dishwashers are accessed from behind the toe kick panel i.e by removing the front bottom access panel. When the timer or main control call for water, power is sent through the float switch wires, when the dishwasher has filled up raising the plastic mushroom looking piece high enough, the switch will stop power from getting to the water valve. That is the idea behind the switch, to further test this switch with a volt meter you can view this video: Please get back to me if you have any other questions.
Kevin
May 29, 2011 | Maytag 24 in. MDB4651A Built-in Dishwasher
Brand new GE modelGLD4408RWW, runs for avery long time on the normal cycle (3 or 4 hrs.). Did not even flush the detergent out of the cup on the light wash, which ran for about an hour and 30 minutes. The...
is the water hot enough prime the sink first then start the dish washer/make sure its hooked to hot water i know it sounds dumb but i have ran across that
May 14, 2010 | Dishwashers
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Solution for Thermado DW245ub dishwasher
You don't have enough hot water coming into the didhwasher. The element is coming on to heat the water. Are you using the sanitizing cycle? Vitally
May 13, 2009 | Thermador DWU244 Dishwasher
Light flashing
reset the dishwasher by touching heated dry and normal let it run through that cycle then through a normal cycle got the error blink again. Reset dishwasher by touching heated dry and normal, ran the test cycle, next ran a normal cycle but turned off the heated dry. This allowed the dishwasher to run through a complete cycle did not get the error blink and confirmed that the heating element was out.
Aug 30, 2008 | Whirlpool 24 in. GU2500 XTP Built-in...
Open Questions:
Kenmore 24 in. 17462 / 17464 / 17469 Built-in Dishwasher Logo
181 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
