Question about Panasonic PT-47WX53 47" Rear Projection HDTV
The red power LED on my 4 yours old PT-47WX54J
The red power LED on my 6 year old PT-47WX54J rear projection HDTV blinks 3 times between pauses. The power button only responds first
time after power recycle to the TV which leads to 3 blinks. There is
no audio and no video. I was watching tv and it clicked, then started this type of cycle.
    President:
  • 788 Answers
If your Panasonic Television is blinking 3 times then you have a short on your power supply and the most likely suspect is your convergence IC’s.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts, and your will get a repair kit instead of just the IC's.
I hope this information allows you to resolve this issue.
I am doing this for free.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you cannot rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Jan 31, 2010
Sony Wega Tv powers on w/ green power light and
need to know how many time the red light is blinking there should be a pause. 4 blinks is a fan, 3 blinks is the lamp door is not closed 6 blinks is thermal sensor.
Apr 22, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic pt47wx52 will not power on
i have a panasonic pt47wx52 hdtv projection monitor . It will not power on and the red led light flases 3 times pause 3 times. What is my problem.
Feb 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
PT-47WX54J 5-blinks between pasues - no audio or video
IC4511 is defective when the led blinks 5 times. that part is unavailable so you will need the entire circuit board.
Jul 18, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX54J shut off - LED blinks 3x
Your convergence ICs need to be changed. 3 Blinks is a convergence error. I can post a link where you can get new ICs and they include free instructions with pictures so you can do the repair yourself, they also offer instant messaging with a tech while your doing the repair thats a free service when you but their replacement parts. Let me know if you would like the link.
Apr 04, 2008 | Televison & Video
Power LED blinks red
it is a bad fan. it also could be a power supply. Quite often the real problem is dirt clogging up the fan(s) to the point that they need to be replaced. Operation of the set in a dirty environment is not a good idea
Feb 26, 2008 | Sony KDS-60A2000 60" HDTV
Panasonic PT-47WX54J --- Picture Problems
Yes,try cleaning your mirror inside of tv they do get real dirty, also clean dirt off of tube lenses there are 3 of them red,green,blue. these are your picture tubes. Thank You for using FixYa and Have a nice Day.
Feb 05, 2008 | Panasonic PT-47WX53 47" Rear Projection...
No sound, No video, power LED blinking 3 times
had the same problem with mine and I replaced horizontal deflection transistor located by the high voltage tranformer, its the big transistor by the heatsink, check for any shot and replace if you find problem. worked for me
Apr 15, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
319 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
