Question about Bob Mackie SRM350 Main / Stereo Speaker
Karaoke, plenty vocals in floor ,no music without loud humming
I have an 808s I use for karaoke gigs,I use peavey 1015 impulse speakers for mains and srm 450 for floor mon. I run my player through the aux in on front of the 808s, floor mon. to mon.out on front, mains on far left and 3rd holes on back. System use to sound wonderful, I useto have something going from the eq send on the front plugging back into the front somewhere but can't remember,its been awhile. Anyway,with it hooked up like I described I can't get music sound to come out as I need it without humming , I do get plenty of vocals. can anyone help me out here????
    Scholar:
  • 55 Answers
Try a couple things
Try plugging the player directly into one of the stereo channels using correct cables (just go to Radio Shack or someplace like that) - you'll probably have to get a stereo to mono "Y" adapter that terminates in two mono mini or 1/4 inch male jacks ... if mini, then upsize them with another adapter ... it's not as rigged as it "sounds" ...
The benefit is, it is actually simpler and you will be able to use all of the channel strip controls for the player just as you would for a mic or guitar plugged in to a channel, and the volumes will behave more as you expect them to ...
Just be absolutely sure the cable you assemble is correct, meaning stereo single 1/4" (or whatever it is, two RCA's whatever) going into the player, and terminating on the other end with two MONO 1/4 inch jacks ...
I use this kind of "Y" connector to play my iPhone through my 808s and it works very well, and I have full control and no confusion.
I'm not sure what you mean by running your player through the "aux in" on the front of the 808s - there are different versions of this mixer, but mine doesn't have anything labeled "aux in" - if you mean the tape inputs on the right front ... RCA jacks ... that should also work, but I prefer just using the normal input channels ...
For example, use input 8 - it's labeled "mic 8" - but if you use the two 1/4" jacks above the Canon jack the mixer will automatically adjust to line level ... on my 808s these 1/4" jacks say "stereo mic/line" ...
Also, I would bypass the effects section completely unless you need it and understand how it works ... and
Make sure the "Power Amp Routing" switch is in the correct position ... since you are using mains and monitors you probably want the "mono" position, which disables the stereo outputs and instead uses one of the power amps for the mains and the other for the monitors ... on my 808s this is the "in" position
On the back, you'll use the speaker outputs labeled "left/main" to go to the main speakers and "right/monitor" to go to the monitor speakers
It's actually pretty simple - with the Power Amp Routing switch pushed in, you no longer have stereo, so ignore "left and right" on those speaker outputs, and follow the labels for "main" and "monitor" .....
Hope that helps!
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.rexark.com
Posted on Mar 06, 2010
I have a Peavey Impulse 200 speaker. The 12" speaker stopped working, but it and the circuit board look fine. What do I check now?
Disconnect the leads from the 12". Put a voltmeter across the speaker terminals and check for continuity. If it reads open, the speaker is dead.
May 16, 2017 | Peavey Music
Peavey problems
Numerous possible issues with your description. I would start with the tubes, and check if not one or more has faulted.
Jul 19, 2014 | Peavey Valveking 112 - Tube Guitar...
I have a Peavey 8600D can I safely run 1 main
When you unload one amplifier you stand the chance of killing the amp's output transistor. If you must use only one speaker, you have to bridge the amps.
Feb 09, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Serial number 00-06778552, a gig amp manufactured about 1977/78, (used in an American tour in 1978). While running a practice session at low volume, the yellow DDT light blanked altogether (this has been...
The amp has a failure. One side of the power amp is starting to draw excessive current to the point that the filter caps can't sustain the current so the ripple starts to be heard in the speaker. Continued use MAY burn up the speaker by sending DC through it as well as causing additional damage to circuit boards, etc..
May 25, 2011 | Peavey Max 115 1x15 Bass Combo Amplifier,...
How to turn off vocal on Emerson GM527 so that we can only hear the music and sing along.
Note that you MUST use the special Karaoke disks to be able to remove the vocal... it will not do it for plain music CD's. Those devices that CLAIM to remove vocals often do so poorly... they do it by subtracting the left and right channels which ASSUMES the lead vocal is centered between the channels... Those methods don't work very well...
Jan 12, 2011 | Emerson Fans GM527 Karaoke Player w 7 LCD...
I have a pair of Peavey Hysis 2 speakers. At a gig on Saturday night one of the started crackling when loud vocals went through. I set them up in the garage next day and the cab that had been crackling...
You have likely almost but not totally fried a voice coil in your speaker. Most speakers get cooked from underpowering, not from being overdriven. What are the speakers rated for and what are you driving them with?
Nov 17, 2017 | Peavey CH1 Speaker
I have a pair of peavey impulse 200`s one of the horns just crack`s up and I have to keep it lower than the other to stop it popping.Has it gone or is it fixable cheers.
hey, just picked up a pair of used peavey impulse 200p speakers .. one of the speakers is giving out this very loud high pictched hum (obviously not working). can anyone help or advice, thanks
Mar 01, 2009 | Peavey CH1 Speaker
Peavey eurosys 500 watt 4 ohm pa speaker fault.very low volume.
Sounds like the basket has gone on the driver not sure if they are replaceable or if you will have to replace the entire driver, had the same problem on my impulse 1015, cost about £100 from a peavey dealer.
Dec 04, 2008 | Peavey PVM 22 Microphone
Peavey impulse 1015 horn cuts in and out
If the horn cuts out after some usage ...then its probably the limiter lamp that is gone .... the limiter lamp is switched into circuit once the " polyswitch " gets hot .... so at first the horn works ...then when the limiter lamp is switched in ...nothing !
its just a standard 12volt car tail light lamp ...let me know if this helps
Jul 27, 2008 | Peavey CH1 Speaker
Peavey microbass guitar amp
The hum is usually electrical mains hum at 50hz, i wouldn't recommend messing about with the insides of amps!
Jay.D BsC Music Technology
SEO Experts - Optimise your web business and increase traffic
Dec 14, 2007 | Audio Players & Recorders
Bob Mackie SRM350 Main / Stereo Speaker Logo
156 people viewed this question
Top Bob Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Bob Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
