Question about Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator
Fisher Paykel E522B Refrigerator wiring diagram required to resolve defrost function failure
  • 235 Answers
SOURCE: Fisher and Paykel E522B refrigerator is not
Make sure air circulation is getting to the fridge side . Also check the evaporator fan and see if it is blowing.
Posted on Jul 14, 2009
SOURCE: measurement of defrost heater elemnt resistance in E 442B
yes, should be 165
Posted on Aug 06, 2009
reddyanantha
  • 205 Answers
SOURCE: I have a Fisher and Paykel E522B Fridge and the
hello sir/mam
after replacing the tempreture probe have u checked the compressor so that it should get the signals for cutt in and cutt off if not please check it.if this is not happening please change the temperature sensor.
Posted on Sep 14, 2009
Testimonial: "which temerature censor ( there are three )"
BIKER T
  • 909 Answers
SOURCE: Fisher and Paykel Freezer
Very possible the door was accidently left open for a period of time. When that happens, moisture latches on to different areas which inturn creates ice build up. In short, do a good defrost and then restart freezer again.
Posted on Oct 04, 2009
Testimonial: "Thank you. Freezer defrosted and working again!"
  • 215 Answers
SOURCE: I have a fisher and paykel E522B refridgerator and
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Posted on Dec 13, 2009
Testimonial: "I actually found little hex screws at the bottom of each of the handles. Once both are loosened a fair way the handle comes off allowing tightening."
Hi,i have fisher pakel E522B with frezzer on the bottom the fridge goes warm and the frezzer section is all iced up.pulled back cover of frezzer off and removed fan,tested fan across 5v ph charger fan...
HI,CHECK FOR CONTINUITY ON THE DEFROST ELEMENT AND B-METAL IF THOSE COMPONENTS PASS THE TEST MAYBE THE TIMER OR DEFROST CONTROL COULD BE BAD IN YOUR REFRIGERATOR..GOOD LUCK..
Jul 04, 2011 | Fisher and Paykel Active Smart E522B...
Fridge compartment not cooling. Freezer seems OK. Fisher & Paykel - model E522B
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 07, 2011 | Fisher and Paykel Icon E522B Bottom...
Ice building up back of freezer and fridge not cooling this is a fisher and paykel active smart fridge frezzzer
I dont work on that brand, however you describe a typical defrost problem, could be the heater t-stat or defrost control.
Oct 05, 2010 | Fisher and Paykel Active Smart E522B...
Unit is running continuously
Can be a faulty thermostat or failure of the auto defrost timer .
You must shut down fridge and restart to check , check if the frost had made the thermostat connections faulty with a loose connection.
Sep 25, 2010 | Fisher and Paykel Active Smart E522B...
Fisher Paykel E522BRX refrigerator not cooling but freezer is working.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 30, 2010 | Fisher and Paykel Active Smart E522B...
How do you manually start timer on fisher paykel
We disconnected the refrigerator and took the back of the freezer apart. There we noticed ice had built up on the coils. After removing all the food, we let the freezer defrost for 3.5 hours. Then we connected it, and it started to cool down immediately. After 1 1/2 to 2 hours, the refrigerator was down below 40 degrees. All food was replaced, and now the refrigerator is working properly All of this was down to the Fisher Paykel Model E522BRM.
Aug 31, 2009 | Fisher and Paykel Active Smart E522B...
THE TOP PART (FRIDGE) IS NOT COOLING
Your defrost system may be out. There are 3 parts, the heaters, t-stat and timer. Hope this helps! :>)!
Aug 14, 2009 | Fisher and Paykel Active Smart E522B...
Fisher and Paykel E522B Stainless Steel Bottom Freezer Refrigerator Logo
686 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
John Tripp
John Tripp
Colin Stickland
Colin Stickland
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
