Question about Sega Master System Console
I need help setting up my Sega Master System, I am unable to attatch it to the tv.
  • 47 Answers
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or want your console modified to connect to a modern TV via AV inlets or S-video visit www.gameoz.com.au they stock a huge range.
Posted on Mar 31, 2010
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
There are vertical lines on my tv when i am playing whit my sega master console
probably av cables..check them at console and at tv end...if still doin it..find new av cables ..good luck
Apr 16, 2014 | Sega Master System Console
I have just found my old sega master system and would like 2 play it on my plasma tv, however i have found it difficult 2 install. any hits would b helpful
You need to hook it up to one of the inputs and remeber the input being used so you can change your plasma tv to it so when you turn on your sega master system the screen will show up.
Here is a video from youtube that shows you exactly how to do it. Sega Master System plasma hookup.
May 15, 2011 | Video Game Consoles & Games
Black and white Picture Sega Master System 2
Is this one of those much older Sega systems with the RF connector that plugs into the incoming cable from outside and the TV?If it is,there should be a channel selector switch on the back,CH3 or CH4.Try the other channel.If it doesn't go away,your RF connector is on it's last legs.
Good luck and game on!
Jul 26, 2010 | Sega Master System Console
Have just bought a hardly used sega megasystem 2 console but it doesnt seem to work. does anyone know where all the leads etc should go? thanks
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts www.gameoz.com.au stock the a huge range.
Mar 20, 2010 | Sega Master System Console
BOX THINGY
the box is a RF switching box
the lead you require is a phono to ariel lead (megadrive, master system or any old computer will do)
or if you get an old video lead and cut of one end and wire a phono plug to it it will also work.
or you try ebay
http://shop.ebay.co.uk/items/_W0QQ_dmptZUKQ5fVideoGamesQ5fVideoGameAccessoriesQ5fVideoGameAccessoriesQ5fJN?_nkw=sega+rf++Master+System++&_sacat=0&_fromfsb=&_trksid=m270.l1313&_odkw=sega+rf&_osacat=0
a basic lead for £2.50
replacments upto £10
both work
Oct 15, 2008 | Sega Master System Console
Hi, Sega master system 2 are connected to your TV via an RF cable. One end is RCA which connects to your console the other end is Pal which connects to you TV's antenna inlet if your using the sega RF switch then the RF switch connects to your antenna inlet on your TV and you should have a RCA to RCA cable which connects the console to the switch. Please note these cables and power adaptors can in some cases be faulty. These console are manually tune to VHF-1 frequency so make sure your TV has this frequency. some do tune to UHF but most tune to VHF-1 if you need parts or what your console modified to allow it to connect to your TV's AV inlet or S-Video visit www.gameoz.com.au as they stock a huge range of Retro gear.
Jul 27, 2008 | Sega Master System Console
Sega master system 2 setup - can't get picture
most likely problem is that your tv isn't tuned to the sega - you can fix this by going into the tv menu and tuning it manually
Mar 31, 2008 | Sega Master System Console
Sega master system
You need an RF Switch. Any kind will do. Sega model 3035 came with your console. Sega model 1603 or Nintendo NES-003 will also work. The RCA plug goes in the back of the console and the lead that looks like cable tv goes on the tv. If your tv does not have the right connection you can purchase an a/v cable that will work.
Oct 20, 2007 | Sega Master System Console
Sega Master System Console Logo
624 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
