Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Infinite Switch Replacement
I had to replace the infinite switch on jenn air range top. Since then none of the burners or the fan get full power. It appears to be wired correctly.
  • Fred Lyon Feb 20, 2008
    It was actually a wired that loosened inside the range top that effected the fan and all burners.
    President:
  • 1,314 Answers
One switch cant affect them all check for a central power problem low voltage weak breaker loose wires on cord loose terminals in outlet box etc.
Posted on Feb 18, 2008
We have a Bosch ceramic hob model no 9000329649, cooking with rear 2 rings yesterday. They will not switch on, front 2 are OK. Grill and oven fine.
check them with a meter and check the infinite switch's also
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful.
2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires.
3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective.
4.Repeat the step above for the terminals "L2" and "H2".
5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced.
6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance.
7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed.
If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. )
Jan 10, 2017 | Bosch Ovens
Burner surges
You have a faulty "infinite switch" and it needs to be replaced. Here is the switch to order.
Dec 01, 2012 | Magic Chef CES3760 Electric Kitchen Range
Just replaced infinite switch part # 12002125 on Jenn-aire JED8430 cooktop. Now burner will only come on HIGH and does not cycle.
Hello- First of all, congratulations on getting it out, apart, and back together again! There are two types of switches for this cooktop. One for the dual, other three are single. Wires can be a trick sometimes. Replacement switches look different sometimes, but work the same. If part is correct, check wire connections at contact points. Lightly crimp any loose ones. Partselect.com has the wiring diagram for JED8430.  Let me know if this info helps- have more if needed. - Thanks- ED
Mar 05, 2010 | Kitchen Ranges
My glass top with sealed burners Jenn-Air range is having trouble with the burners...the large burner does not come on at sall and the three smaller burners come on but do not maintsin the temperture...
Yes, you can fix this yourself! It is a simple repair thatyou canmake yourself, too.
The large burner needs to be replaced and the other burners need thr infinite swithces replaced on them.
I love the Jenn-Air brand ranges. Contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service from 7 AM until 9 PM CST and we will ship these parts to you overnight along with part removal/installation instructions for you to get cooking ASAP!
Thanks, Ella
Nov 16, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Top burner shorted out and now the indecator light stays on. and the burner will not heat.
Hi, It sounds like the infinite switch has shorted out. You will need to change the burner switch. Did you have the burner tested or replaced?
Make dure everything conected to that burner is ok before changing the burner switch.
Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Jul 22, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Replace knob to turn burner on
u have to replace your infinite switch. easy to do pull out and unplug take back panel off then check to see if its broke if so replace u might get lucky.
Mar 29, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Front right 8'' surface burner dose not light up period.
it could be your burner but most likely your infinite switch for that burner
Mar 21, 2009 | Kitchen Ranges
Tripping breaker
I had the same problem. Mine was caused by liquid seeping into the infinite switch (the switch that gets rotated by the knob to set burner temperature). This caused one of the live wires to short to ground within the switch. Bad Design IMHO. Replacing the switch fixed the problem (you can get replacement parts at Searspartsdirect.com - search using the cooktop model number). To get at the switch you need to remove the top by taking off only the top row of screws all around the unit and also in the down draft cavity.
Sep 20, 2008 | Jenn-Air JED8430 Electric Cooktop
Burner adjustment
After discussing the problem with your advisor it was determined to be a faulty infinite burner control switch. I purchached a replacement and the stove works fine.This service was very halpful to me.
Jul 21, 2008 | Jenn-Air Kitchen Ranges
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
289 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
