Question about Boston Acoustics (BA7800) Computer Speakers
BA7800 hi Gurus! I am trying to make my Boston BA7800 speakers work with my computer... I connect the connector cable the way it says on this page, http://support.gateway.com/s/SOUND/speakers/7003229/700322934.shtml , but I can only get the subwoofer and 2 speakers to work at a time. If I switch the black and green connectors going into the sound card, then the OTHER two speakers work, but not all of them at the same time. What's up with that? laura
  • 13 more comments
  • 37thparallel Feb 17, 2008
    Thanks for the speedy reply...
    Don't know what kind of sound card is in there. The four speakers are connected to the subwoofer like this: http://support.gateway.com/s/SOUND/speak...
    so you think I need a Y-adapter?
    I tried quadrophonic, surround sound, 5.1 surround sound, etc. I doesn't help.
  • 37thparallel Feb 18, 2008
    ok it's downloaded... it wants an access code.
    8292 8357 4047
    Ok so I did that.. I got the request box, clicked OK, but no pop-up blocker, just this box: "Failed to execute the command line: winvnc.exe"
    yes.
    I turned off Messenger...
    It still doesn't work... same message
    It timed out... trying again...
    I am on the phone line. I have Windows XP.
    Same error message. Maybe it's not meant to be?
    I have AOL & Messenger installed.
    Messenger wants me to add your email address, OR search for you by name (first & last)
    Maybe if you try to add my email address...
    THANKS FOR ALL YOUR GREAT HELP!!
    Genius:
  • 3,422 Answers
Please check THIS link and let me know if this is helpful to you..
Goodluck..
Posted on Feb 17, 2008
  • Priya darshan Feb 17, 2008
    Yes. I don't know what you think about it.
    Anyways you can follow IB4G2008's advice if that doesn't solve your problem then i think you must go for the y-adapter..
    Genius:
  • 3,587 Answers
Hmmm...what kind of sound card you using, Laura?
  • 17 more comments
  • Patrick Michaels
    Patrick Michaels Feb 17, 2008
    ok..so you have it set up with the correct connection, right? and you're probably using the sound card that came with the system, yes?
    ok..then you'll need to open the control panel, and go to sound settings, and in the master control, you'll see a variety of options for what kind of speakers you are using. Choose wisely..it's likely that the system is set for default stereo, hence your performance as indicated.
    got backup for your Gateway?
  • Patrick Michaels
    how do you have the other four speakers connected?
  • Patrick Michaels
  • Patrick Michaels
    and finally.
    Windows XP
    Note: If using Microsoft® Windows® XP Professional, the Windows 2000 instructions may need to be used instead.
    1. From the Start menu, click Control Panel.
    2. In Control Panel, click Sounds, Speech and Audio Devices, and then click Change the Speaker Settings.
    3. In the Sounds and Audio Devices Properties dialog box, in the Speaker Settings area, click Advanced.
    4. In the Advanced Audio Properties dialog box, on the Speaker tab, click Quadraphonic.
    5. Click OK.
    6. In the Sounds and Audio Devices Properties dialog box, click OK.
    7. In the Sounds, Speech and Audio Devices window, from the File menu, click Close.
  • Patrick Michaels
    got it..then it's most likely your sound control panel settings, especially if this is a new expansion of your sytem.
  • Patrick Michaels
    nope..if you are connected properly behind woofer and to sound card, then follow my instructions at bottom of my solution, changing sound settings to quadraphonic.
  • Patrick Michaels
    laura,
    if you are connected per the instructions, and your sound settings are on quad, you should be good to go, without the Y connector, which is used when you have two stereo systems, which is NOT the case here.
  • Patrick Michaels
    ok..if you want, I can trouble shoot this one with a shared screen session..
    go here first, and get this application, then send me a note through that screen, if you wish to have this solved quickly.
  • Patrick Michaels
    Patrick Michaels Feb 18, 2008
    ok..paste or type this in exactly with space..DO NOT hit connect. I'll need the same code from your Share panel, to connect the machines.
    2429 6630 1924
  • Patrick Michaels
    ok..hit connect, and then you'll see a request to allow Inbusiness4good to look at your machine..accept that request..you may get a pop up blocker..allow it..
    go now..
  • Patrick Michaels
    it's not allowing me to see your computer..did you accept this and allow me to share your screen?
  • Patrick Michaels
    ok..that's really weird..do you use Yahoo IM or Windows messenger?
  • Patrick Michaels
    will you attempt the crossloop connection once again, please?
  • Patrick Michaels
    ok..is it ok to phone you?
  • Patrick Michaels
    you on xp or vista, by the way?
  • Patrick Michaels
    ok..well..you are doing everything correct, per the instructions..two speakers work fine..do you use Yahoo Instant messenger? We could solve it that way.
  • Patrick Michaels
    ok..my Messenger id is InBusiness4Good add me, and lets solve this thang
  • Patrick Michaels
    bookspeak4him@hotmail.com
  • Patrick Michaels
    you are welcome..remember to close this one out with a vote for who you believe helped the most.
Connect my BA7800 to my laptop that only has a headphone jack
As you stated in your question there are 3 3.5mm headphone jacks connected to the speakers. Green is for headphones, red is for microphone, and black is probably just a line in connector.
plug the green connector from the speakers into your headphone port on your laptop and it should work.
because the speakers are self powered and have a few adjustment knobs on them, you will have to tinker with the volume coming from the laptop and from the speakers, so you don't have distorted, scratchy sound from the speakers when playing music at loud levels.
my suggestions is turn the laptop volume down to a quater of the volume and then turn the speakers up, let the speakers do the hard work and not the laptop..
Jan 04, 2015 | Boston Acoustics Audio Players & Recorders
Adapting Boston Acoustics BA7800 for use with TV
Here's what you need:
http://www.vpi.us/cable-audio.html
Scroll down to the 3.5mm Stereo Jack / RCA Plug x 2 Y-Cable
Converts your TRS connectors to dual RCA plugs. You said you have 3 TRS connectors. Does the TV have 3 sets of RCA plugs you can use with this? If not, you may not be able to get full surround sound, just stereo sound, from your TV - and you'll need some RCA splitters to plug two (or three) cables into one port. I know you can get those at Radio Shack.
-Dyllan
Jan 09, 2008 | Boston Acoustics (BA7800) Computer...
How do I take apart a Boston Acoustics BA7800 subwoofer?
If you've undone the 8 screws on the back panel... I would suggest the only thing holding it in is..... it's an interference fit... try carefully prising it out.
Nov 18, 2014 | Boston Acoustics (BA7800) Computer...
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
Need cable to connect computer to BA7800 speaker system
YES, WHERE CAN I GET THE 3 PRONGED CABLE TO CONNECT MY SOUND CARD TO THE INPUTSON THE BACK OF MY BA7800 SPEAKER SYSTEM, OR JUST MAKE MY OWN WITH 3 GOLD TIPPED 1/8" CONNECTOR WIRES?
Jun 14, 2009 | Boston Acoustics (BA7800) Computer...
Install Boston Acoustic speakers BA7800 to a new Imac?
Partial Solution anyway - I just got a Mac Pro (2.66 Nehalem )and couldn't find the manual from my old Gateway 700XL. This is what I did: Plug the green wire into the analog output, and the pink wire (if you really need an external mic, but you shouldn't since our new computers both have a built-in mic) into the analog input. Just ignore the black wire. You won't have the 2 surround speakers, but I'm still looking for a fix for that. I got tired of the crappy speakers in my new Apple Cinema display (the ONLY crappy thing about my new system). As you know, the sound from the BA7800 is great, even with just the two front speakers and sub-woofer. I'll keep you posted if/when I figure out how to set up the surround speakers! Likewise, if you hear something, please post here and I'll keep checking back.
Apr 10, 2009 | Boston Acoustics (BA7800) Computer...
Broken ''pin'', on system connection chord
CHANGE THE CORD AND TRY WITH AMAZON.COM
Nov 27, 2008 | Audio Players & Recorders
Speakers have no sound.
Have you tried other speakers? If so did they work? You might try updating the sound card drivers.
Jun 11, 2008 | Boston Acoustics (BA7800) Computer...
Boston BA7800 PC speakers
I would not suggest it. PC speakers generally have their own amplifier built into the system and will not handle the power from a home system well.
Jan 30, 2008 | Boston Acoustics (BA7800) Computer...
Boston Acoustics (BA7800) Computer Speakers Logo
954 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
