Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Getting a note on my screen that the "lens not attached" but it is. Auto focus is no longer working.
  • Obertelli
    Obertelli May 11, 2010
    Is the problem with all lenses or just one? It's vital to know as it determines whether the fault lies in the lens or the body.
  • 2,517 Answers
Remove lens clean the dia fream and again slowly attached the lens. Hope you get good reply.
Posted on Jan 30, 2010
My NikonD3100 is no longer focusing, my battery is charged and I am at a loss
Make sure you're using a lens that worked before on this camera.. many consumer bodies lack the built in focus motor, so you must purchase lenses that have the motor built into the lens. If it lacks a motor - no auto focus will be possible.
Remove and re-seat the lens.
Make sure that any Aperture ring on the lens barrel is set to the smallest (largest number f22) possible.
Make sure any and all Auto / Manual Focus switches are set to A or Auto.
Try taking a picture in broad daylight - or other well lit area - if the subject is very dark, the auto focus will struggle or "hunt".
Let me know if these suggestions solve your problem - good luck!
Oct 19, 2014 | Nikon D3100 Digital Camera
Our Canon EOS Rebel XSi no longer works on auto focus. The flash works but the camera just makes clicking noises and the screen says "busy". Any suggestions? The camera works fine in manual...
Optical focus relies on a gear driven motorized system to focus the lens. It sounds like the drive is either frozen by a foreign object (it doesn't take much) has gotten into the system, or a tooth has worn/broken on the gearing.
Try taking the lens off and blowing the camera out with some canned air. If that doesn't do it, it's a trip to the repair center.
Jul 04, 2011 | Canon EOS Rebel XSi Digital Camera
Canon 40D will no longer work if on auto focus. Will only take a picture in manual focus.
When in auto focus does the lens try to focus?
Sounds like your lens is the problem, you can try to clean the gold contacts on both the camera and on the lens with a pencil eraser (Make sure not to get any eraser dust in either the camera or the lens). If you can try a different lens on your camera and see if that one will work.
Please post a comment if you need more help on this.
Jun 13, 2011 | Canon EOS 40D Digital Camera
I put in new batteries in my Pentax ist-D and now the auto focus will not function. I get no beep or light to indicate when it is in focus because even when I move the button from M to Auto, the view...
Remove the lens and clean the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol. Re-attach the lens and make sure the ring (if you have one) is set to "A".
Mar 11, 2011 | Pentax *ist DL Digital Camera
Lamp lights without command no longer open in the minidv box black screen does not play, not record one more thing to do?
Solution 1 • Unlock focus area selector. • Auto-area AF selected for Custom Setting 2 (AFarea mode): choose another mode. • Press shutter-release button halfway to turn monitor o?¬? or activate exposure meter • Memory card is full, locked, or not inserted. • Flash is charging. • Camera is not in focus. • CPU lens with aperture ring attached without locking aperture at highest f/-number. • Non-CPU lens is attached: rotate camera mode dial to M. • Mode dial rotated to S after shutter speed of bulb selected in mode M: choose new shutter speed • P, S, A, and M modes: lower ?¬? ash. • Digital Vari-Program modes: turn ?¬? ash o?¬? Turn long exposure noise reduction o?¬? Turn long exposure noise reduction o?¬? Press multi selector up or down or rotate sub-command dial to choose photo information displayed Select All for Playback folder. Note that Current will automatically be selected when next photo is taken • Select On for Rotate tall. • Photo was taken with O?¬? selected for Auto image rotation. • Camera orientation was changed while shutter-release button was pressed in continuous shooting mode. • Camera was pointed up or down when photo was taken Use Nikon-approved card. • Card may be damaged. Contact retailer or Nikonauthorized service representative. • Delete unwanted ?¬ les or insert new memory car
Jan 26, 2011 | Samsung SC-D103 Mini DV Digital Camcorder
The lens no longer works on auto and as I wear glasses, I can't manually focus it.
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Sep 20, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
Sigma 70-300mm lens defaults to manual focus
It will default to manual through the viewing screen. It will only work on automatic, using the viewfinder. Make sure you also set the focal length (lens to shutter distance). You might also have a mf / af switch on the lens. This also only works through the viewfinder.
Jan 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
My lens quit auto focusing
It's probably broke then. Clean the contacts to the camera and try again. If it still don't work you can probably be sure it is likely to be a bit faulty. Check the camera has auto focus mode enabled if appropriate.
Jul 06, 2008 | Sigma 28-300mm f/3.5-6.3 Macro for Nikon-D...
AF problem with Quantaray 2X adapter
How does it stop working? Do you mean it doesn't auto focus anymore?
Many longer focal length lenses wont auto focus with 2x teleconverters on them.
Nov 27, 2007 | Quantaray 100-300mm F4.5-6.7 Zoom lens for...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
62 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
