Question about Ricoh FT5832 Copier
I have ricoh ft4522 photocopier, i ve E5 on screen kindly solve or describe what is E5?
  • 155 Answers
Pls press dot (.) to be able to find out the last two digit that will appear on the counter.
Posted on Jan 30, 2010
  • 1 more comment
  • Joel Baleta
    Joel Baleta Feb 03, 2010
    E5 is a fuser or heater problem
  • Jamil Butt
    Jamil Butt Jan 26, 2013
    its heater problem just open the heater unit and dissassemble it than chek thermister if this damaged so than change it
  • Jahja Batiu
    Jahja Batiu Jan 04, 2014
    i am getting a e3 error what does this mean pls help me @ jahjabatiu@hotmail.com
Ricoh FT4522 code U6
Check if some door switch in open.
Mar 27, 2012 | Ricoh Aficio 450 Copier
Got a ft4522 without user guide cant get it to work where do i load the paper
Open the paper drawer and load on the right side of the tray.
Mar 06, 2011 | Ricoh Aficio 450 Copier
HOW WILL I SOLVE PROBLEM OF E5 ERROR MESSAGE IN RICOH 4018 AND E11 ERROR MESSAGE IN RICOH 4622 PHOTOCOPIER
e 5** fuser related temperature over/under
e1** optics related
both need service engineer
Oct 04, 2010 | Ricoh Office Equipment & Supplies
We lost the user codes for our ricoh ft4522. how
select user tools, admin , address book you should be able to see the pre programmed user codes. there also should be an option to view or print out the codes
Oct 15, 2009 | Ricoh Aficio 450 Copier
Reset the error code e-5 on a ricoh ft4522
There is no need to use dip switches to reset this error code.Providing that the thermistors are good and they have been installed correctly,here the reset procedure that is done through operation panel: press "Clear Modes" botton,then 107,then press and hold the "Stop" key for 3-5 seconds until you see the screen has changed.After that you need to turn the main power swith off and back on.The error code should be reset at this point.If it comes back,you may have a bad fusing lamp or a bad connector.
Oct 02, 2009 | Ricoh Aficio 450 Copier
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio 1013F
you need to install printer on computer as network printer from the supplied CD.
Mar 27, 2009 | Ricoh Aficio 1013F Copier
ERROR of My Aficio MP1500 Photocopier
Are you sure about the model number? I believe you may mean MP2500? Regardless, sounds like an NVRam Problem. This unit is what controls the electronic counter, as well as most of system settings. This will require a service technician from a dealer with connections to RICOH.
Feb 25, 2009 | Ricoh Aficio 450 Copier
Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Nov 07, 2008 | Ricoh Aficio 250 Copier
Ricoh FT5832 Copier Logo
478 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
