I cant me my sound to work. the onboard sound wasnt working but all off its drivers were there and working properly. i got a pci sound card and installed that and still no sound. all of its drivers are up to date and working properly. i have disabled the onboard sound in bios. everything is connected properly, and my speakers work on other computers. i have also ran a registry cleaner and still nothing.
  • 74 Answers
Maybe your device is in mute,go to control panel click sound and device,click volume
Posted on Jan 30, 2010
Sound problem
First of all try to disable the onboard sound card.
Enter the bios by pressing "del" or F2 during the boot process, navigate to find sound options and disable the onboard audio. Boot the pc normally, go to the device manager and uninstall any audio drivers. Shut down the pc, unplug the power cord and plug-in your new pci audio card. Start the pc and install the drivers for your new audio card.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Mar 04, 2010 | VIA P4MA Motherboard
I have an issue with the Dell PowerEdge 1800 video card. It displayed all the garbages (unreadable words) on the monitor when I first booted up or in the Windows 2003 OS. I went out to buy an EVGA...
Hi ngot01
Not knowing your application or tasking for your server, i cant make a full recommendation. I'm presuming you are not wanting to use this for a gaming machine.
One very determining factor is whether you are running 32bit or 64bit version of 2003. there are some fairly decent choices for cards but some won't support both 32 and 64 bit versions. If you have a particular card in mind, i would recommend first going to the manufacturers website and checking for compatibility with server2003
The geforce 5200 and 5500 from EVGA, PNY both come in PCI version with 128MB or 256MB onboard.
They are getting harder to find but are still to be found for a reasonable price online. i run a 5500 in one of my IBM X series servers dual processor with no hitches and no stability issues.
(32bit/64bit.)
32 bit support using older Nvidia drivers from Nvidia driver archives.
64 bit drivers currently available in latest Nvidia drivers version
The Visiontek Radeon 9250 PCI (ATI chipset) also runs well in both dell and IBM servers from my experience, and comes with 128MB or 256MB onboard.
64 bit support with current ATI drivers
32 bit support from older driver packages found on net.
One of the biggest considerations is whether the card will be properly recognized at first. Video cards and other peripherals behave differently in a server than in a desktop. Just dropping any PCI video card in may cause you some grief in time spent troubleshooting.
Another very important consideration is the video memory on the card.
Your 1800 requires ECC registered memory, but the onboard video memory on the video card can cause a problem when it starts trying to share the system memory. Not always, but this can cause a number problems, most common are blue screens.
Again, without knowing which version of 2003 you are running, i cant offer much more sound advice, because that is the biggest determining factor.
hope this helps, and if i have helped you, please dont forget to rate.
Feb 20, 2010 | Dell PowerEdge 1800 Server
Onboard sound card not working (ASUS A7S333). I had a pci sound card and removed it to go back to the onboard sound.
You have to refresh your system by deleting the old sound card driver in the control panel or add/remove programs . Then restart the pc to detect the old onboard sound card driver. Then install the onboard sound card driver using the supported motherboard cd driver.
Feb 12, 2010 | ASUS A7S333 Motherboard
Onboard LAN detected , drivers properly installed but not responding
The Problem is in your onboard LAN, get PCI LAN card, plug into your PCI slot, install the driver of that PCI LAN Card..
Apr 27, 2009 | Computers & Internet
No audio device
Since your PCI driver is missing, and it does have something to do with it, no PCI device is read by the OS, so the problem will probably be solved by the supply of the correct PCI driver.
Without knowing your exact board, I can only give you this general advice.
Apr 09, 2009 | Compaq Computers & Internet
Sound
i need soundmax for my orange pc
Mar 27, 2008 | HP Compaq d220M (829160054797) PC Desktop
Audio sound driver
i lost my asus drivers cd so i want to isntall this
Mar 24, 2008 | Intel Frontier Design Dakota 24-Bit PCI...
ECS 945GCT-M/1333 System Board
I can see you getting an error with pci.sys but not with pcy.sys.
Did a full system scan in a working WinXP Pro & found not such animal within the system or regestry. After looking through microsoft I did come across pci.sys and what may creat such an error. I would point to your onboard VGA. If intergrated into the board as I suspect. It is a pci device. During install windows found something wrong with it hence your error & blue screen. Suggest using your PCIE card & set bios to same disabling the VGA. Your install should no longer fail.
Good luck & please vote!
Jan 12, 2008 | ECS 945GZT-M (V1.0) Motherboard
PCI-express won't come up.
BIOS Setup Utility; go to Advance Chipset Features
PEG Port is your PCI-EXPRESS…Enable/Disable
Nov 10, 2007 | EliteGroup 915G-M Motherboard
741GX-M Sound not working, sound cards not being recognised
plz check wether u have installed xp service pack 2. if u have done this then go to the cmos settings and check wether the onboard audio is enabled or not. then install the correct driver for that device
Oct 21, 2007 | EliteGroup 741GX-M Motherboard
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
