Question about Panasonic KX-TG3031S Cordless Phone
Phone range is drastically reduced to a mere 1 foot
What is the speaker output per channel for technic se-350?
seems to be 22 watts rms, 35 watts peak at a 4 ohm load. with 8 ohm speakers, the power would be reduced 50%, but the distortion levels would also be drastically reduces
Jan 02, 2015 | Audio Players & Recorders
Cannot unlock phone, want to use different phone and transfer my sim card to different phone. have unlock code from other provider where phone was used.can you help unlock phone, supposed to be permately...
Unlocking a phone is a simple and secure process that frees your phone from carrier restraints placed on it by your provider.
With an unlocked phone you can switch to any other network in order to take advantage of better rates. You can use even Dual SIM Adapters. This can drastically reduce on your cell phone bills. Also you can eliminate Roaming Fees by using local networks SIM cards when travelling.
http://www.htcimeiunlock.com/htc-blog/reduced-prices-unlocking-codes-2013-01-14/
Nov 13, 2012 | consumercellular.com
My motorola fv500 reach only 1/4mile
You may have
1) A low or bad battery.
2) Be holding the radio at an angle and reducing your range. Hold the antenna straight up, perpendicular to the ground, to achieve the best range. Height and placement of the antenna determines range.
3) Or you may be trying to talk in-or-out of a building, which would significantly reduce your range. Obstacles between you and the other radio, as well as the body fluid of a person wearing their radio low on their hip can significantly reduce range.
Best regards.
Jun 08, 2011 | Motorola FV500 2-Way Radio
The 4 wheel wont engage but divers good in 2 wheel
Most of the time its the actuator on the front axel. GM has had a problem with these units. If you put the 4-wd shifter in low range is the transfer case shifting into low? You will notice this because it will feel very torquie but the vehicle speed will be drasticly reduced. If it goes into low range then replace the actuator on the front axel.
Mar 25, 2011 | 2002 Chevrolet Silverado 2500HD
My battery runs down very fast. I have replaced the battery, does not help. I have had a software update done, does not help
1. Change to ORIGINAL nokia battery and charge it for 12 hours for the first time.
2. Reduce the screen brightness.
3. Turn of Bluetooth (if on)
4. Check if any of the keys got stuck and pressed all the time as this will drastically drain your battery.
I hope this will solve your problem.
Thanks
Oct 11, 2010 | Nokia 6230i Cellular Phone
Kenwoodtk360 would have what kind of range vehicle to vehicle
This is impossible to predict since the UHF frequency often involves line-of-sight range and things like trees and other things can drastically affect the range. You could pretty well guarantee communication within a half mile most places with an external antenna. This is about the same guarantee as one has with cell phones, although most don't realize and observe this stringent a limit in practice.
Jan 11, 2010 | Radio Communications
Swimming with iphone
well dropping into water reduces its life drastically. I hope its tym 2 change ur set and nothing can be done
Aug 20, 2008 | Apple iPhone Smartphone
Kx-t7453
Let's see if I understand you correctly. You want to lift the handset and automatically have it pick up line 1 to make an outside call but it's picking up your last phone line first (example: line 8 if you have 8 lines) This feature cannot usually be changed unless you restrict what lines the specific phone is allowed to use. This is because there is always a chance that a call is coming in but it has not had a chance to ring yet. In an office environment where people are constantly using the phones people would end up answering calls more than you think before the call had a chance to ring. The phone system would think the line is still free. Systems are set up to use the last available line to drastically reduce the chance of that happening.
May 10, 2007 | Panasonic KX-T7453 Corded Phone
Range
All wireless products are subject to radio interference. The performance is a direct result of the operating environment. Other products that use the same frequency can drastically reduce the performance of the wireless product. Try changing the operating channel or moving the wireless Access Point.
Feb 16, 2006 | Belkin (F5D72304F5D7000) Router
Panasonic KX-TG3031S Cordless Phone Logo
20 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
