Question about Video Cameras
I've just taken several pix and some of them look as if they've been sliced vertically and put back together unevenly. No idea if this fault is with the camera, the memory card (a Sony, I've had it less than three years, with moderate use), or my pc software. Any ideas?
  • ann4576 Jan 30, 2010
    You ask for samples but how am I to send them?
    The problem is with a Sony DSC P200 not a camcorder. Pictures are slicing vertically.
  • Video Cameras Master
  • 2,517 Answers
Can you please send me a sample of a good and a bad photo. i will give your the solution then.
Posted on Jan 30, 2010
  • RAJDEEP DUTTA
    RAJDEEP DUTTA Jan 30, 2010
    Ok . no problem if you know how to use abobe photoshop then u can fix it in pc. if not then just submit your mamory card in a photo lab then will arrange all the photo in proper allinment and make the printout. Its very common matter for a photo printing lab house. Dont warry. good day.
Vertical line and loud sound
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 21, 2015 | Televison & Video
Vertical lines on left side of pn50c450b1dxza
Line, faults to both LCD & Plasma TVs are given with illustrations. You can get an idea about the fault to an extent.
Sep 02, 2015 | Samsung PN50C450 50 in. TV
Stator rubs against rotor
Go to YouTube with your model number,make,bearings change.
Apr 25, 2013 | Kenmore HE2 Plus Front Load Washer
Cold power up, colored vert lines, (rainbow) audio perfect. When warms up, pix returns, slight black horizontal lines in top forth of screen which go away when warmer.
All Plasma and LCD ts have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them, Good luck in rectifying the problem.....
May 17, 2011 | Sanyo DP46848 LCD TV
After power outage, my sony kdf-e60a20 turn back on to find veritcal colored lines. shut off, left off for 30 mins, turned back on and it took forever to turn back on and veritical lines still there
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken . Good luck in handling the fault.....
May 14, 2011 | Sony KDF-E60A20 60 in. LCD HDTV
Several lines run across the top of the screen
Several lines acroos the screen at the top along with picture is a typical fault. You are seeing vertical retrace lines. Either the supply smoothing capacitor to the power supply given to vertical output Ic or vertical output capacitor connected to the vertical output pin of that Ic may faulty. Usually the supply smoothing capacitor seen faulty. It may be over 1500Mfd eletrolytic capacitor used there. It may get value reduced by 40 percent or so, this falult will occur. Please replace the two capacitors together and will get the result.
Oct 15, 2010 | Toshiba 27A34 27" TV
42 inch mower cuts uneven, what is the problem?
Several things here could be the problem. Check to see if mower deck is level, measure distance on both side on a level surface. Check tire's for low air. If you've replace the mandrel's lately, some have a left & right side & if not put back together properly this will cause uneven cutting
Aug 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Vertical Height Problem
I work with electronics, too, and I don't have the exact schematics, but I would say that you are on the right track with thinking the capacitor is going bad. What put onto that idea how you mentioned that it had gotten worse over time. I don't think that it's the veritcal driver.
Jan 25, 2008 | Samsung TXM2756 27" TV
Video Cameras Logo
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
