Remote control is not working how can I start from the unit
  • 22 Answers
What type of system is it? if it's a mini split tgher is a button on the air ahndler itself but I dont think you can control Temp.
Posted on Feb 01, 2010
My dvd remote does not work when i try to start movies
Greetings! Does your TV front panel works? If so, the problem lies surely on the remote control portion. But make sure first that the RC unit batteries are new ones. Turn on any portable FM radio receiver and point the RC unit near its antenna. Turning the dial knob very slowly, press any remote control keypads permanently. The moment you hear an oscillating sound from the receiver speaker, stop turning the dial and start to play with the RC unit keypads to find out if there is any sound changes, that means your remote control unit is emitting an infrared signal and its a healthy sign.! Then the defect is on your TV's remote receiver section, mechanically i. e. cold solder or electrically (defective components). Good luck!
Jul 04, 2011 | Televison & Video
Fault E3 Have same problem, fan works fine but will not turn on cold air. Display shows "e3". I have a remote, but do not see a button "c".
Try this : Start the unit using the remote control, after that push the C button of remote control if C display at the unit then off the unit and plug out the power supply. Then plug in again and "on" the unit using the remote control.
Aug 09, 2008 | Kenwood KW85 Air Conditioner
Not working
If the circuit breaker tripped,then the unit is trying to work and the remote is certainly telling the unit operate, otherwise it could never trip the breaker if it did not receive a signal from the remote. Your problem may be with the outside unit that te compressor is stalled (having a hard time starting ) and this will cause the breaker to trip. You need a porfessional to diagnose if it is the starter control, or relay, or capacitor, or bad compressor, or bad terminals.
Nov 28, 2009 | Coffee Makers & Espresso Machines
Suddenly stopped working, green light on remote works, but no response from car. No locks, trunk, or start.
Could be many things, loose ground or power wire on the 561, there is an inline power fuse on the red wire leading to the control unit that may be blown. It may just need to have the remotes reprogrammed to the control unit, sometimes the control unit just stops recognizing the remotes. If you have recently had the cars battery replaced, or jump started the car, check the fuse at the control unit first.
Aug 17, 2009 | Directed Dei Valet 561r Remote...
Chamberlain Whisper drive remote control unit not working
THE NEW REMOTE MAY NOT BE THE CORRECT SYSTEM FOR THE UNIT YOU HAVE.
THE ONE THAT DOESN'T WORK MOST LIKELY NEEDS A NEW BATTERY.
NOTE IT MUST BE REPROGRAMED AFTER CHANGING THE BATTERY
HOPE THIS HELPS
May 14, 2009 | Chamberlain 950CB Remote Control
LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Feb 15, 2009 | LG LSC121PMA Split System Air Conditioner
Control seems to be working but unit not responding.
Check your remote control by using a camera or cellphone camera as your eyes to confirm if the remote control is ok. Point the remote control transmitter to your camera and check if a light emits in your remote control transmitter. If no light then the remote control is defective, but if the light is present then the remote is ok and the unit receiver board itself is defective.
Check also if there is a reset or rst button on the remote control, press the button and test the remote.
Jan 21, 2009 | Fujitsu 24C1 Air Conditioner
Remote Control Unit
Get a digital camera or mobile phone with the camera and the remote,watch trough the camera the remote( aim the remote to the camera like its the sub) and start pushing buttons on the remote.If the remote is OK you'll see flashing light of its IR led on your camera display.If there is no light the remote is broken
Mar 08, 2008 | Durabrand HT-3915 System
Heating & Cooling Logo
82 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
